Takker for svar fra dere begge!
Det ser ut som at det gikk greit nok, men jeg valgte å kjøre en client fra systray og nummer to fra command.
Dette er klippet fra installasjonen av console clienten via dos prompt:
--- Opening Log file [November 23 21:42:26 UTC]
# Windows CPU Console Edition ###############################################
Folding@Home Client Version 6.20
http://folding.stanford.edu
Launch directory: C:\Folding@home-86_2
Executable: C:\Folding@home-86_2\[email protected]
[21:42:26] Configuring Folding@Home...
User name [Anonymous]? -alias-
Team Number [0]? 37651
Passkey []?
Ask before fetching/sending work (no/yes) [no]?
Use proxy (yes/no) [no]?
Acceptable size of work assignment and work result packets (bigger units
may have large memory demands) -- 'small' is <5MB, 'normal' is <10MB, and
'big' is >10MB (small/normal/big) [normal]?
Change advanced options (yes/no) [no]? y
Core Priority (idle/low) [idle]?
CPU usage requested (5-100) [100]?
Disable highly optimized assembly code (no/yes) [no]?
Pause if battery power is being used (useful for laptops) (no/yes) [no]?
Interval, in minutes, between checkpoints (3-30) [15]?
Memory, in MB, to indicate (6141 available) [6141]?
Set -advmethods flag always, requesting new advanced
scientific cores and/or work units if available (no/yes) [no]?
Ignore any deadline information (mainly useful if
system clock frequently has errors) (no/yes) [no]?
Machine ID (1-16) [1]? 2
Launch automatically, install as a service in this directory (yes/no) [no]?
The following options require you to restart the client before they take effe
Disable CPU affinity lock (no/yes) [no]?
Additional client parameters []?
IP address to bind core to (for viewer) []?
[21:45:13] - Ask before connecting: No
[21:45:13] - User name: -alias- (Team 37651)
[21:45:13] - User ID: 7984E07A1322581B
[21:45:13] - Machine ID: 2
[21:45:13]
[21:45:13] Work directory not found. Creating...
[21:45:13] Could not open work queue, generating new queue...
[21:45:13] - Preparing to get new work unit...
[21:45:13] + Attempting to get work packet
[21:45:13] - Connecting to assignment server
[21:45:16] - Successful: assigned to (171.64.122.72).
[21:45:16] + News From Folding@Home: Welcome to Folding@Home
[21:45:17] Loaded queue successfully.
[21:45:23] + Closed connections
[21:45:23]
[21:45:23] + Processing work unit
[21:45:23] Core required: FahCore_81.exe
[21:45:23] Core not found.
[21:45:23] - Core is not present or corrupted.
[21:45:23] - Attempting to download new core...
[21:45:23] + Downloading new core: FahCore_81.exe
[21:45:32] Trying to unzip core FahCore_81.exe
[21:45:32] Decompressed FahCore_81.exe (2396160 bytes) succes
[21:45:37] + Core successfully engaged
[21:45:42]
[21:45:42] + Processing work unit
[21:45:42] Core required: FahCore_81.exe
[21:45:42] Core found.
[21:45:42] Working on queue slot 01 [November 23 21:45:42 UTC
[21:45:42] + Working ...
[21:45:42]
[21:45:42] *------------------------------*
[21:45:42] Folding@Home Gromacs Simulated Tempering Core
[21:45:42] Version 1.10 (Oct 4, 2007)
[21:45:42]
[21:45:42] Preparing to commence simulation
[21:45:42] - Looking at optimizations...
[21:45:42] - Created dyn
[21:45:42] - Files status OK
[21:45:42] - Expanded 240074 -> 1167683 (decompressed 486.3 p
[21:45:42] - Starting from initial work packet
[21:45:42]
[21:45:42] Project: 4418 (Run 55, Clone 1, Gen 157)
[21:45:42]
[21:45:42] Assembly optimizations on if available.
[21:45:42] Entering M.D.
[21:45:48] Protein: p4418_Seq_50_nat_AMBER_Native
[21:45:48]
[21:45:48] Writing local files
[21:47:36] Extra SSE boost OK.
[21:47:36] Writing local files
[21:47:36] Completed 0 out of 150000 steps (0%)
[21:49:03] Writing local files
[21:49:11] Completed 1500 out of 150000 steps (1%)
[21:50:29] Writing local files
[21:50:29] Completed 3000 out of 150000 steps (2%)
[21:52:00] Writing local files
[21:52:00] Completed 4500 out of 150000 steps (3%)
[21:53:29] Writing local files
[21:53:29] Completed 6000 out of 150000 steps (4%)
[21:55:05] Writing local files
[21:55:05] Completed 7500 out of 150000 steps (5%)
[21:56:44] Writing local files
[21:56:44] Completed 9000 out of 150000 steps (6%)
klipp slutt
Loggen fra systray clienten ser omtrent lik ut bortsett fra at der benyttes machine ID 1 og at det benyttes andre tallstørrelser i checkpoint files, slik:
[21:49:37] Completed 3150000 out of 5000000 steps (63%)
[21:49:37] Writing checkpoint files
[22:04:39] Writing checkpoint files
Kan det gjøres slik og ser klippene fra loggene rimelige ut?
Begge CPU cores kjører nå i området 70 - 100% load. Core #0 noe høyere enn #1. Temperaturen holder seg likevel under 50 grader.
Endret av -alias-
Ja, det ser bra ut. Ingen tvil om at det virker. Men du kunne valgt big WUs, de små gir ikke så veldig mye poeng og det går mye tid til venting på server. Project summary.
Hvorfor ikke logge litt oftere enn 15 min, hvis du avbryter ofte er det fint med tette logger, ned til 3 min. I systray kommer du også til innstillingene vet du vel, høyreklikk på ikon, velg config å sjekk at du har satt CPU til Slightly higher og 100% då får du dem kanskje opp i sum 100 %. ?
Der det står Acceptable size of WUs... der skulle du skrevet big, du klikket vel enter for normal er. Men da må du kjøre hele config omigjen etter at du først sletter clientconfig i mappa (til konsollclienten). Noen tekstbehandlere kan rette clientkonfig, men det er som regel best å lage ny (starte konsollen på nytt og skrive inn de nye verdiene).
8800GTS512MB kan gi godt over 5000PPD, men ikke 320 og 640 utgavene. Vel muligens rev2 av 640.
Derimot har det kommet større prosjekter som senker PPD et godt stykke på en del kort.
Grr... kom hjem etter å ha vært borte hele helgen og fant at halve maskinparken hadde stått uten produksjon siden fredag formiddag.
Endret av Theo343
Har hørt flere snakke om å få opptil 5000ppd på 8800gts. Men jeg får bare maks 2-2,500.
Hvis det er hardwaren du har i signaturen er det definitivt for lite, som nevnt ovenfor burde det greit gi 3800 PPD eller noe mer med klokking. Sjekk i windows oppgavebehandling at kun er en Fahcore_11 kjører. Og så spørs det om du har satt igang andre clienter eller programmer som krever mye CPU, da kan det også senke GPUproduksjonen.
Du kunne jo nevnet hvilke prosjekt du kjører når du får denne verdien.
Endret av kjellms
De konsollklientene jeg har brukt har da hatt -configonly som tilgjengelig parameter... :hmm:
Bare å stoppe konsollklienten det og starte den på nytt med -configonly som parameter, så er det bare å trykke Enter for valg en ikke vil endre siden valg en gjorde forrige gang er default valg for alle instillingene.
hvorfor får jeg dette i loggen min?:
[00:11:46] Folding@home Core Shutdown: UNSTABLE_MACHINE
[00:11:51] CoreStatus = 7A (122)
[00:11:51] Sending work to server
[00:11:51] Project: 5741 (Run 3, Clone 21, Gen 7)
[00:11:51] - Read packet limit of 540015616... Set to 524286976.
[00:11:51] - Error: Could not get length of results file work/wuresults_09.dat
[00:11:51] - Error: Could not read unit 09 file. Removing from queue.
[00:11:51] - Preparing to get new work unit...
[00:11:51] + Attempting to get work packet
[00:11:51] - Connecting to assignment server
[00:11:52] - Successful: assigned to (171.64.65.103).
[00:11:52] + News From Folding@Home: GPU folding beta
[00:11:52] Loaded queue successfully.
[00:11:54] + Closed connections
GUI Server hos meg klarer ikke å sende over resultatene fra Project: 5506 (Run 6, Clone 138, Gen 375) til Folding@Home Jeg bruker Folding@Home GPU Core - Beta Version 1.19 (Mon Nov 3 09:34:13 PST 2008)
Jeg får denne feilmeldingen gjentakende:
[15:25:47] + Attempting to send results [November 26 15:25:47 UTC]
[15:25:48] - Couldn't send HTTP request to server
[15:25:48] + Could not connect to Work Server (results)
[15:25:48] (171.64.65.106:8080)
For ordens skyld legger jeg ved hele loggen før ny jobb ble påbegynt.
15:16:19] Completed 99%
[15:25:30] Completed 100%
[15:25:31] Successful run
[15:25:31] DynamicWrapper: Finished Work Unit: sleep=10000
[15:25:41] Reserved 1129200 bytes for xtc file; Cosm status=0
[15:25:41] Allocated 1129200 bytes for xtc file
[15:25:41] - Reading up to 1129200 from "work/wudata_01.xtc": Read 1129200
[15:25:41] Read 1129200 bytes from xtc file; available packet space=261014288
[15:25:41] xtc file hash check passed.
[15:25:41] Reserved 34800 34800 261014288 bytes for arc file=<work/wudata_01.trr> Cosm status=0
[15:25:41] Allocated 34800 bytes for arc file
[15:25:41] - Reading up to 34800 from "work/wudata_01.trr": Read 34800
[15:25:41] Read 34800 bytes from arc file; available packet space=260979488
[15:25:41] trr file hash check passed.
[15:25:41] Allocated 560 bytes for edr file
[15:25:41] Read bedfile
[15:25:41] edr file hash check passed.
[15:25:41] Allocated 130974 bytes for logfile
[15:25:41] Read logfile
[15:25:41] GuardedRun: success in DynamicWrapper
[15:25:41] GuardedRun: done
[15:25:41] Run: GuardedRun completed.
[15:25:43] - Writing 1296046 bytes of core data to disk...
[15:25:44] ... Done.
[15:25:44] - Shutting down core
[15:25:44]
[15:25:44] Folding@home Core Shutdown: FINISHED_UNIT
[15:25:47] CoreStatus = 64 (100)
[15:25:47] Sending work to server
[15:25:47] Project: 5506 (Run 6, Clone 138, Gen 375)
[15:25:48] + Retrying using alternative port
[15:25:52] - Couldn't send HTTP request to server
[15:25:52] + Could not connect to Work Server (results)
[15:25:52] (171.64.65.106:80)
[15:25:52] - Error: Could not transmit unit 01 (completed November 26) to work server.
[15:25:52] Keeping unit 01 in queue.
[15:25:52] Project: 5506 (Run 6, Clone 138, Gen 375)
[15:25:52] + Attempting to send results [November 26 15:25:52 UTC]
[15:25:54] - Couldn't send HTTP request to server
[15:25:54] + Could not connect to Work Server (results)
[15:25:54] (171.64.65.106:8080)
[15:25:54] + Retrying using alternative port
[15:25:57] - Couldn't send HTTP request to server
[15:25:57] + Could not connect to Work Server (results)
[15:25:57] (171.64.65.106:80)
[15:25:57] - Error: Could not transmit unit 01 (completed November 26) to work server.
[15:25:57] + Attempting to send results [November 26 15:25:57 UTC]
[15:26:21] - Server does not have record of this unit. Will try again later.
[15:26:21] Could not transmit unit 01 to Collection server; keeping in queue.
[15:26:21] - Preparing to get new work unit...
[15:26:21] + Attempting to get work packet
[15:26:21] - Connecting to assignment server
[15:26:25] - Successful: assigned to (171.64.65.20).
[15:26:25] + News From Folding@Home: GPU folding beta
[15:26:26] Loaded queue successfully.
[15:26:30] Project: 5506 (Run 6, Clone 138, Gen 375)
[15:26:30] + Attempting to send results [November 26 15:26:30 UTC]
[15:26:32] - Couldn't send HTTP request to server
[15:26:32] + Could not connect to Work Server (results)
[15:26:32] (171.64.65.106:8080)
[15:26:32] + Retrying using alternative port
[15:26:48] - Couldn't send HTTP request to server
[15:26:48] + Could not connect to Work Server (results)
[15:26:48] (171.64.65.106:80)
[15:26:48] - Error: Could not transmit unit 01 (completed November 26) to work server.
[15:26:48] + Attempting to send results [November 26 15:26:48 UTC]
[15:26:51] - Couldn't send HTTP request to server
[15:26:51] (Got status 503)
[15:26:51] + Could not connect to Work Server (results)
[15:26:51] (171.67.108.25:8080)
[15:26:51] + Retrying using alternative port
[15:27:32] - Server does not have record of this unit. Will try again later.
[15:27:32] Could not transmit unit 01 to Collection server; keeping in queue.
[15:27:32] + Closed connections
[15:27:32]
[15:27:32] + Processing work unit
[15:27:32] Core required: FahCore_11.exe
[15:27:32] Core found.
[15:27:32] Working on queue slot 02 [November 26 15:27:32 UTC]
[15:27:32] + Working ...
[15:27:32]
[15:27:32] *------------------------------*
[15:27:32] Folding@Home GPU Core - Beta
[15:27:32] Version 1.19 (Mon Nov 3 09:34:13 PST 2008)
[15:27:32]
[15:27:32] Compiler : Microsoft ® 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[15:27:32] Build host: amoeba
[15:27:32] Board Type: Nvidia
[15:27:32] Core :
[15:27:32] Preparing to commence simulation
[15:27:32] - Looking at optimizations...
[15:27:32] - Created dyn
[15:27:32] - Files status OK
[15:27:32] - Expanded 44211 -> 244433 (decompressed 552.8 percent)
[15:27:32] Called DecompressByteArray: compressed_data_size=44211 data_size=244433, decompressed_data_size=244433 diff=0
[15:27:32] - Digital signature verified
[15:27:32]
[15:27:32] Project: 5013 (Run 0, Clone 6, Gen 188)
[15:27:32]
[15:27:33] Assembly optimizations on if available.
[15:27:33] Entering M.D.
[15:27:41] Working on 576 p5005_supervillin_e1
[15:27:42] Client config found, loading data.
[15:27:42] Starting GUI Server
[15:30:54] Opening http://fah-web.stanford.edu/cgi-bin/main.p...username=-alias-...
[15:37:22] Completed 1%
[15:46:28] Completed 2%
[15:55:27] Completed 3%
Noen som kan fortelle meg hvor feilen ligger?
Løst! Tror serveren hos Folding@Home var nede. Alle data er sendt nå.
Endret av -alias-
