Hmm... prøver å få gpu klienten til å køyre her...
Litt usikker på kor bra det egentlig går...
utdrag fra loggen:
[15:04:58] Completed 10%
[15:06:29] Completed 11%
[15:08:01] Completed 12%
[15:09:32] Completed 13%
[15:11:04] Completed 14%
[15:12:35] Completed 15%
[15:14:06] Completed 16%
[15:15:38] Completed 17%
[15:17:09] Completed 18%
[15:18:41] Completed 19%
[15:20:12] Completed 20%
[15:21:43] Completed 21%
[15:23:15] Completed 22%
[15:24:46] Completed 23%
[15:26:13] Gromacs cannot continue further.
[15:26:13] Going to send back what have done.
[15:26:14] logfile size: 0 info=0 bed=0 hdr=23
[15:26:14] - Writing 556 bytes of core data to disk...
[15:26:14] Done: 44 -> 87 (compressed to 197.7 percent)
[15:26:14] ... Done.
[15:26:14]
[15:26:14] Folding@home Core Shutdown: UNSTABLE_MACHINE
[15:26:17] CoreStatus = 7A (122)
[15:26:17] Sending work to server
[15:26:17] Project: 5015 (Run 4, Clone 115, Gen 8)
[15:26:17] - Read packet limit of 540015616... Set to 524286976.
[15:26:17] + Attempting to send results [August 14 15:26:17 UTC]
[15:26:18] + Results successfully sent
[15:26:18] Thank you for your contribution to Folding@Home.
[15:26:22] - Preparing to get new work unit...
[15:26:22] + Attempting to get work packet
[15:26:22] - Connecting to assignment server
[15:26:23] - Successful: assigned to (171.64.65.20).
[15:26:23] + News From Folding@Home: GPU folding beta
[15:26:23] Loaded queue successfully.
[15:26:25] + Closed connections
[15:26:30]
[15:26:30] + Processing work unit
[15:26:30] Core required: FahCore_11.exe
[15:26:30] Core found.
[15:26:30] Working on queue slot 03 [August 14 15:26:30 UTC]
[15:26:30] + Working ...
[15:26:31]
[15:26:31] *------------------------------*
[15:26:31] Folding@Home GPU Core - Beta
[15:26:31] Version 1.09 (Fri Aug 1 11:46:54 PDT 2008)
[15:26:31]
[15:26:31] Compiler : Microsoft ® 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[15:26:31] Build host: amoeba
[15:26:31] Board Type: Nvidia
[15:26:31] Core :
[15:26:31] Preparing to commence simulation
[15:26:31] - Looking at optimizations...
[15:26:31] - Created dyn
[15:26:31] - Files status OK
[15:26:31] - Expanded 44087 -> 244433 (decompressed 554.4 percent)
[15:26:31] Called DecompressByteArray: compressed_data_size=44087 data_size=244433, decompressed_data_size=244433 diff=0
[15:26:31] - Digital signature verified
[15:26:31]
[15:26:31] Project: 5015 (Run 0, Clone 568, Gen 2)
[15:26:31]
[15:26:31] Assembly optimizations on if available.
[15:26:31] Entering M.D.
[15:26:37] Working on 576 p5005_supervillin_e1
[15:26:37] Client config found, loading data.
[15:26:38] Starting GUI Server
[15:28:09] Completed 1%
[15:29:40] Completed 2%
[15:31:12] Completed 3%
[15:32:43] Completed 4%
[15:34:15] Completed 5%
[15:35:46] Completed 6%
[15:37:17] Completed 7%
[15:38:49] Completed 8%
[15:40:20] Completed 9%
[15:41:30] + Working...
[15:41:52] Completed 10%
[15:43:23] Completed 11%
[15:44:55] Completed 12%
[15:46:26] Completed 13%
[15:47:57] Completed 14%
[15:49:29] Completed 15%
[15:51:00] Completed 16%
[15:52:32] Completed 17%
[15:54:03] Completed 18%
[15:55:34] Completed 19%
[15:57:06] Completed 20%
[15:58:37] Completed 21%
[16:00:09] Completed 22%
[16:00:26] Gromacs cannot continue further.
[16:00:26] Going to send back what have done.
[16:00:27] logfile size: 11576 info=11576 bed=0 hdr=23
[16:00:27] - Writing 12112 bytes of core data to disk...
[16:00:27] Done: 11600 -> 4073 (compressed to 35.1 percent)
[16:00:27] ... Done.
[16:00:27]
[16:00:27] Folding@home Core Shutdown: UNSTABLE_MACHINE
[16:00:29] CoreStatus = 7A (122)
[16:00:29] Sending work to server
[16:00:29] Project: 5015 (Run 0, Clone 568, Gen 2)
[16:00:29] - Read packet limit of 540015616... Set to 524286976.
[16:00:29] + Attempting to send results [August 14 16:00:29 UTC]
[16:00:30] + Results successfully sent
[16:00:30] Thank you for your contribution to Folding@Home.
[16:00:34] - Preparing to get new work unit...
[16:00:34] + Attempting to get work packet
[16:00:34] - Connecting to assignment server
[16:00:35] - Successful: assigned to (171.64.65.20).
[16:00:35] + News From Folding@Home: GPU folding beta
[16:00:35] Loaded queue successfully.
[16:00:36] + Closed connections
[16:00:41]
[16:00:41] + Processing work unit
[16:00:41] Core required: FahCore_11.exe
[16:00:41] Core found.
[16:00:41] Working on queue slot 04 [August 14 16:00:41 UTC]
[16:00:41] + Working ...
[16:00:42]
[16:00:42] *------------------------------*
[16:00:42] Folding@Home GPU Core - Beta
[16:00:42] Version 1.09 (Fri Aug 1 11:46:54 PDT 2008)
[16:00:42]
[16:00:42] Compiler : Microsoft ® 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[16:00:42] Build host: amoeba
[16:00:42] Board Type: Nvidia
[16:00:42] Core :
[16:00:42] Preparing to commence simulation
[16:00:42] - Looking at optimizations...
[16:00:42] - Created dyn
[16:00:42] - Files status OK
[16:00:42] - Expanded 44130 -> 244433 (decompressed 553.8 percent)
[16:00:42] Called DecompressByteArray: compressed_data_size=44130 data_size=244433, decompressed_data_size=244433 diff=0
[16:00:42] - Digital signature verified
[16:00:42]
[16:00:42] Project: 5015 (Run 3, Clone 107, Gen 9)
[16:00:42]
[16:00:42] Assembly optimizations on if available.
[16:00:42] Entering M.D.
[16:00:48] Working on 576 p5005_supervillin_e1
[16:00:48] Client config found, loading data.
[16:00:49] Starting GUI Server
[16:02:20] Completed 1%
[16:03:51] Completed 2%
[16:05:23] Completed 3%
[16:06:54] Completed 4%
[16:08:25] Completed 5%
[16:09:57] Completed 6%
[16:11:28] Completed 7%
[16:13:00] Completed 8%
[16:14:31] Completed 9%
Får dere det også slik? At den avbryter midt inni?
Har foldet en god stund nå, med de pc'ene jeg har kommet over, begynte i det små med en gammel stasjonær som stod på døgnet rundt uansett. Dette gikk veldig treigt, var en gammel Athlon om jeg husker riktig.
Nå folder jeg med en Dell maskin med E6400 CPU, en PS3, min nåværende stasjonær som folder med en E6600 CPU og et 8800 GTX kort, og tilslutt en bærbar som med en T7300 CPU, noe CPU forbruk skrudd ned pga varmeutvikling.
Dell'n kjører CPU 5.03 klienten, finnes det en bedre klient til denne? Den nye 6.20? SMP klienten, funker de best til Quad?
På min nåværende stasjonære kjører jeg GPU klienten og 6.20 CPU klienten, bra kombo dette?
Takk for alle svar :)
Quoter deler av et gammelt innlegg her, noen meninger om hvilke klienter jeg burde kjøre?
Steike, temmelig mange GPUer på en mann, han tar det skikkelig alvorlig ja. Tør ikke tenke på strømregninga da, hehe. :p
Viss du bruker dette til sentralfyring så er det vel i utganspunktet ikke fult så ulønsomt =)
Noen som vet om det snart er løst problemet i Vista at du må ha en skjerm på hvert skjermkort for å få brukt det til folding?
Skulle hatt det greit til høsten :p bruker pcen til oppvarming :p
Endret av VikinGz
Har en duo prosessor som går på 2Ghz på min bærbare. Denne gir 260ppd??? Kan dette stemme, før fikk jeg ca. 1000 ppd på denne når jeg kjørte 2 klienter.
Kjører 2 kilenter v 6.20 i Vista.
Endret av brg
det stemmer nok.
FOr å få mer nytte av prosessoren kan du installere smp klienten og teste denne ;)
det stemmer nok.
SMP har jeg prøvd, men gir for mye varme på denne som i utgangspunktet er ganske varm. Men en reduksjon på 700ppd ved bruk av klient i løpet av 3 måneder syntes jeg var rart.
Altså når jeg foldet på denne i vår, så hadde jeg en ppd på ca 1000, nå 260.
Kordan er det med PPD på ps3'n for tida?
Synes at den kanskje får noke superstore pakker for tida, men også godt betalte med poenger også.
Er litt usikker på kor masse, har så mange klienter på min bruker for tida.
Tror de pakkene gir 1250 poeng, er det jeg har fått.
Bare litt headsup på SMP klient.
Alternativ SMH basert Beta 6.22 SMP klient, for de som opplever mye problemer med 6.22.
http://foldingforum.org/viewtopic.php?f=46&t=4609
Dette er en SMH versjon som har en annerledes minnehåndtering enn den orginale klienten.
Ellers finnes den Orginale "SMP Beta 6.22" nå R2 og R3 utgave om du skulle ha problemer med den orginale over tid.
Release3 og Release2
Vil du legge inn R2 eller R3 i etterkant av original 6.22 er det bare å erstatte exe filen.
NB!
Ellers har de hatt store strømproblemer på hele "campus" siden sent i går kveld og de sliter med varme på serverrommet akkurat nå så det kan ta tid før vi får opp servere igjen.
EDIT:
Datakjeden har nå 10 stk 8800GS til 509,-! Løp og kjøp!
http://www.datakjeden.no/PartDetail.aspx?q...bc:36132%3br:pg
Ingen kort gir bedre PPD per krone og watt. Med litt klokk gjør disse kortene oppimot 5100PPD og standard 4100-4400 PPD.
Endret av Theo343
