Theo343 Skrevet 24. mai 2008 Rapporter Del Skrevet 24. mai 2008 (endret) Er det flere som har problemer med at GPU2 på HD3850 med 8.5 driver på WinXP32 ikke vil kjøre som den skal? Den prøver 5 ganger og går i sleep. Her er loggen. Noen som vet hva jeg kan gjøre? [13:53:03] Trying to unzip core FahCore_11.exe [13:53:03] Decompressed FahCore_11.exe (3506176 bytes) successfully [13:53:03] + Core successfully engaged [13:53:03] Deleting current work unit & continuing... [13:53:07] - Preparing to get new work unit... [13:53:07] + Attempting to get work packet [13:53:07] - Connecting to assignment server [13:53:08] - Successful: assigned to (171.64.65.103). [13:53:08] + News From Folding@Home: GPU folding beta [13:53:08] Loaded queue successfully. [13:53:09] + Closed connections [13:53:14] [13:53:14] + Processing work unit [13:53:14] Core required: FahCore_11.exe [13:53:14] Core found. [13:53:14] Working on Unit 00 [May 24 13:53:14] [13:53:14] + Working ... [13:53:19] CoreStatus = FFFFFFFF (-1) [13:53:19] Client-core communications error: ERROR 0xffffffff [13:53:19] Deleting current work unit & continuing... [13:53:23] - Preparing to get new work unit... [13:53:23] + Attempting to get work packet [13:53:23] - Connecting to assignment server [13:53:24] - Successful: assigned to (171.64.65.103). [13:53:24] + News From Folding@Home: GPU folding beta [13:53:24] Loaded queue successfully. [13:53:25] + Closed connections [13:53:30] [13:53:30] + Processing work unit [13:53:30] Core required: FahCore_11.exe [13:53:30] Core found. [13:53:30] Working on Unit 01 [May 24 13:53:30] [13:53:30] + Working ... [13:53:34] CoreStatus = FFFFFFFF (-1) [13:53:34] Client-core communications error: ERROR 0xffffffff [13:53:34] Deleting current work unit & continuing... [13:53:38] - Preparing to get new work unit... [13:53:38] + Attempting to get work packet [13:53:38] - Connecting to assignment server [13:53:39] - Successful: assigned to (171.64.65.103). [13:53:39] + News From Folding@Home: GPU folding beta [13:53:39] Loaded queue successfully. [13:53:41] + Closed connections [13:53:46] [13:53:46] + Processing work unit [13:53:46] Core required: FahCore_11.exe [13:53:46] Core found. [13:53:46] Working on Unit 02 [May 24 13:53:46] [13:53:46] + Working ... [13:53:50] CoreStatus = FFFFFFFF (-1) [13:53:50] Client-core communications error: ERROR 0xffffffff [13:53:50] Folding@Home will go to sleep for 1 day as there have been 5 consecutive Cores executed which failed to complete a work unit. [13:53:50] (To wake it up early, quit the application and restart it.) [13:53:50] If problems persist, please visit our website at http://folding.stanford.edu for help. [13:53:50] + Sleeping... EDIT: For å være sikker på at det ikke er maskinen det er noe galt med la jeg inn SMP591Beta6 klienten og den kjører helt smertefritt. Er det serveren som har problemer ift. GPU2 klienten? Logg for SMP591B6 på samme maskin: [14:14:36] - User ID: 38B23657E116BF2 [14:14:36] - Machine ID: 6 [14:14:36] [14:14:36] Work directory not found. Creating... [14:14:36] Could not open work queue, generating new queue... [14:14:36] - Preparing to get new work unit... [14:14:36] - Autosending finished units... [14:14:36] Trying to send all finished work units [14:14:36] + Attempting to get work packet [14:14:36] + No unsent completed units remaining. [14:14:36] - Will indicate memory of 1500 MB [14:14:36] - Autosend completed [14:14:36] - Connecting to assignment server [14:14:36] Connecting to http://assign.stanford.edu:8080/ [14:14:38] Posted data. [14:14:38] Initial: 40AB; - Successful: assigned to (171.64.65.64). [14:14:38] + News From Folding@Home: Welcome to Folding@Home [14:14:38] Loaded queue successfully. [14:14:38] Connecting to http://171.64.65.64:8080/ [14:14:43] Posted data. [14:14:43] Initial: 0000; - Receiving payload (expected size: 4294366) [14:15:34] - Downloaded at ~82 kB/s [14:15:34] - Averaged speed for that direction ~82 kB/s [14:15:34] + Received work. [14:15:34] + Closed connections [14:15:34] [14:15:34] + Processing work unit [14:15:34] Core required: FahCore_a1.exe [14:15:34] Core not found. [14:15:34] - Core is not present or corrupted. [14:15:34] - Attempting to download new core... [14:15:34] + Downloading new core: FahCore_a1.exe [14:15:34] Downloading core (/~pande/Win32/x86//Core_a1.fah from www.stanford.edu) [14:15:35] Initial: AFDE; + 10240 bytes downloaded [14:15:35] Initial: AD21; + 20480 bytes downloaded [14:15:35] Initial: CC38; + 30720 bytes downloaded [14:15:35] Initial: 8501; + 40960 bytes downloaded [14:15:36] Initial: F56A; + 51200 bytes downloaded [14:15:36] Initial: ABAE; + 61440 bytes downloaded [14:15:36] Initial: B6B0; + 71680 bytes downloaded [14:15:36] Initial: 783A; + 81920 bytes downloaded [14:15:36] Initial: B2A6; + 92160 bytes downloaded [14:15:37] Initial: 1409; + 102400 bytes downloaded [14:15:37] Initial: BBF0; + 112640 bytes downloaded [14:15:37] Initial: 1861; + 122880 bytes downloaded [14:15:37] Initial: 5950; + 133120 bytes downloaded [14:15:37] Initial: 1081; + 143360 bytes downloaded [14:15:38] Initial: 26BC; + 153600 bytes downloaded [14:15:38] Initial: FE4A; + 163840 bytes downloaded [14:15:38] Initial: C1C3; + 174080 bytes downloaded [14:15:38] Initial: 9B49; + 184320 bytes downloaded [14:15:38] Initial: 9EE5; + 194560 bytes downloaded [14:15:38] Initial: D79D; + 204800 bytes downloaded [14:15:38] Initial: 7801; + 215040 bytes downloaded [14:15:39] Initial: 8B51; + 225280 bytes downloaded [14:15:39] Initial: E26E; + 235520 bytes downloaded [14:15:39] Initial: EDB0; + 245760 bytes downloaded [14:15:39] Initial: 0919; + 256000 bytes downloaded [14:15:39] Initial: CDDE; + 266240 bytes downloaded [14:15:39] Initial: 7A7E; + 276480 bytes downloaded [14:15:39] Initial: 034E; + 286720 bytes downloaded [14:15:40] Initial: 88D0; + 296960 bytes downloaded [14:15:40] Initial: D66D; + 307200 bytes downloaded [14:15:40] Initial: 6A52; + 317440 bytes downloaded [14:15:40] Initial: B478; + 327680 bytes downloaded [14:15:40] Initial: CF8A; + 337920 bytes downloaded [14:15:40] Initial: 8407; + 348160 bytes downloaded [14:15:40] Initial: 2246; + 358400 bytes downloaded [14:15:40] Initial: 1C69; + 368640 bytes downloaded [14:15:40] Initial: 1287; + 378880 bytes downloaded [14:15:40] Initial: 19B3; + 389120 bytes downloaded [14:15:41] Initial: 1AD1; + 399360 bytes downloaded [14:15:41] Initial: 5791; + 409600 bytes downloaded [14:15:41] Initial: 76C5; + 419840 bytes downloaded [14:15:41] Initial: 9B77; + 430080 bytes downloaded [14:15:41] Initial: E82F; + 440320 bytes downloaded [14:15:41] Initial: D0D3; + 450560 bytes downloaded [14:15:41] Initial: 0F5E; + 460800 bytes downloaded [14:15:41] Initial: D743; + 471040 bytes downloaded [14:15:41] Initial: 0B7C; + 481280 bytes downloaded [14:15:42] Initial: FAFD; + 491520 bytes downloaded [14:15:42] Initial: 0E14; + 501760 bytes downloaded [14:15:42] Initial: 4048; + 512000 bytes downloaded [14:15:42] Initial: 21A5; + 522240 bytes downloaded [14:15:42] Initial: C1A5; + 532480 bytes downloaded [14:15:42] Initial: F716; + 542720 bytes downloaded [14:15:42] Initial: DD98; + 552960 bytes downloaded [14:15:42] Initial: 9F7B; + 563200 bytes downloaded [14:15:42] Initial: 1CC0; + 573440 bytes downloaded [14:15:43] Initial: 4D37; + 583680 bytes downloaded [14:15:43] Initial: 222A; + 593920 bytes downloaded [14:15:43] Initial: 8E33; + 604160 bytes downloaded [14:15:43] Initial: D3C9; + 614400 bytes downloaded [14:15:43] Initial: 9821; + 624640 bytes downloaded [14:15:43] Initial: 236E; + 634880 bytes downloaded [14:15:43] Initial: 1A7A; + 645120 bytes downloaded [14:15:43] Initial: 6D64; + 655360 bytes downloaded [14:15:43] Initial: 4ADC; + 665600 bytes downloaded [14:15:43] Initial: 3854; + 675840 bytes downloaded [14:15:44] Initial: CB5C; + 686080 bytes downloaded [14:15:44] Initial: 2A88; + 696320 bytes downloaded [14:15:44] Initial: 1199; + 706560 bytes downloaded [14:15:44] Initial: 0512; + 716800 bytes downloaded [14:15:44] Initial: 316E; + 727040 bytes downloaded [14:15:45] Initial: D89D; + 737280 bytes downloaded [14:15:45] Initial: E6A3; + 747520 bytes downloaded [14:15:45] Initial: B488; + 757760 bytes downloaded [14:15:45] Initial: BAFD; + 768000 bytes downloaded [14:15:46] Initial: 34A0; + 778240 bytes downloaded [14:15:46] Initial: DD6C; + 788480 bytes downloaded [14:15:46] Initial: D2E9; + 789667 bytes downloaded [14:15:46] Verifying core Core_a1.fah... [14:15:46] Signature is VALID [14:15:46] [14:15:46] Trying to unzip core FahCore_a1.exe [14:15:46] Decompressed FahCore_a1.exe (2035712 bytes) successfully [14:15:46] + Core successfully engaged [14:15:51] [14:15:51] + Processing work unit [14:15:51] Core required: FahCore_a1.exe [14:15:51] Core found. [14:15:51] Working on Unit 01 [May 24 14:15:51] [14:15:51] + Working ... [14:15:51] - Calling 'mpiexec -channel auto -np 4 FahCore_a1.exe -dir work/ -suffix 01 -checkpoint 15 -verbose -lifeline 3164 -version 591' [14:15:51] [14:15:51] *------------------------------* [14:15:51] Folding@Home Gromacs SMP Core [14:15:51] Version 1.74 (March 10, 2007) [14:15:51] [14:15:51] Preparing to commence simulation [14:15:51] - Looking at optimizations... [14:15:51] - Created dyn [14:15:51] - Files status OK [14:15:51] this execution. [14:15:51] - Files status OK [14:16:11] ompressed 577.8 percent) [14:16:11] 10145 (decompressed 577.8 percent) [14:16:11] [14:16:11] [14:16:11] Project: 2665 (Run 2, Clone 456, Gen 0) [14:16:11] [14:16:11] t: 2665 (Run 2, Clone 456, Gen 0) [14:16:11] [14:16:13] Entering M.D. [14:16:13] M.D. [14:16:19] Rejecting checkpoint [14:16:21] Protein: HGG with glycosylations [14:16:21] Writing local files [14:16:32] Extra SSE boost OK. [14:16:32] Writing local files [14:16:32] Completed 0 out of 250000 steps (0 percent) Endret 24. mai 2008 av Theo343 Lenke til kommentar
WheelMan Skrevet 25. mai 2008 Rapporter Del Skrevet 25. mai 2008 http://www.xtremesystems.org/forums/showthread.php?t=188781 Dette virker lovende Lenke til kommentar
foffle Skrevet 25. mai 2008 Rapporter Del Skrevet 25. mai 2008 (endret) Lover bra for F@H det der ja Jeg har forresten ombestemt meg. Nå går X3220 på 75% og GPU2 kjører på HD3850 likevel. Jeg fikk fiksa viftebråket. Fahmon viser over 3000ppd på dette oppsettet, men det kan da ikke stemme... Til Theo: 8.5 funka ikke på mitt HD3850 heller. Gikk tilbake til 8.4 og det går som en drøm. Kjører xp pro x86. Endret 25. mai 2008 av foffle Lenke til kommentar
Theo343 Skrevet 25. mai 2008 Rapporter Del Skrevet 25. mai 2008 (endret) foffle: Tusen takk for tilbakemeldingen, da skal jeg prøve 8.4 driveren Bare la den kjøre ferdig SMP WU'en først. Endret 25. mai 2008 av Theo343 Lenke til kommentar
Snorre Skrevet 25. mai 2008 Rapporter Del Skrevet 25. mai 2008 (endret) Tenkte å innstaller F@H til tross for at jeg kun har en bærbar med Intel C2D. Men jeg vil nå hjelpe med det lille jeg har. Eneste som bekymrer meg er selvsagt at maskinen blir overopphetet om prosessoren står og jobber 100% flere timer i strekk. Dermed lurte jeg på om det var mulig å begrense CPU-bruken til la oss si 50%. Sitter på Linux, så det er naturligvis Linux-versjonen jeg trenger hjelp til. Ellers burde det gå greit å innstallere. :-) Edit: En ting til. Må jeg skrive inn brukernavn hver eneste gang jeg kjører F@H-klienten eller er det en lettere måte å gjøre dette på? Har forstått det slik at det er mulig å kjøre F@H-klienten som en"service" som starter når maskinen startes opp. Vil brukernavn og lagnummer isåfall huskes når maskinen våkner til live igjen? Endret 25. mai 2008 av Snorre Lenke til kommentar
Xell Skrevet 25. mai 2008 Rapporter Del Skrevet 25. mai 2008 Under installasjonen (konfigurasjonen egentlig) er ett av spørsmålene om hvor stor cpu-last man vil benytte. Default er 100, men det er bare å skrive inn hva som helst der (0-100). Under linux anbefaler jeg å benytte Ivo Sarak sitt finstall-script.. Jeg har aldri hatt noen problemer med den. Si i fra om du vil ha "full oppskrift" for en installasjon under linux. Lenke til kommentar
Tordenflesk Skrevet 25. mai 2008 Rapporter Del Skrevet 25. mai 2008 Laptopen min har flere ganger stått og foldet flere uker i strekk uten noe som helst overoppheting. Prøv med 100% først før du senker. Lenke til kommentar
Snorre Skrevet 26. mai 2008 Rapporter Del Skrevet 26. mai 2008 (endret) Under installasjonen (konfigurasjonen egentlig) er ett av spørsmålene om hvor stor cpu-last man vil benytte. Default er 100, men det er bare å skrive inn hva som helst der (0-100). Under linux anbefaler jeg å benytte Ivo Sarak sitt finstall-script.. Jeg har aldri hatt noen problemer med den. Si i fra om du vil ha "full oppskrift" for en installasjon under linux. Siden jeg er relativt ny med Linux kan en oppskrift være ok ja. Og skal F@H være innstallert før man benytter seg av Finstall-script eller må jeg avinnstallere F@H-installen jeg har nå? Edit: Glem det. Gikk egentlig veldig greit å innstallere dette her. Men, fikk fortsatt ikke noe alternativ for å endre CPU-begrensning ved konfirgurering av programmet. Og ja, jeg svarte ja til å endre avanserte innstillinger. Så hvordan gjør man isåfall dette? Endret 26. mai 2008 av Snorre Lenke til kommentar
VikinGz Skrevet 26. mai 2008 Rapporter Del Skrevet 26. mai 2008 Og du vil ikke få flere WU-er etter 2. juni.Hva skjer da? Har akkurat kjøpt et HD3850 jeg skulle sette opp med GPU2 :/ Slapp av GPU2 med de nye kortene 2xxx og 3xxx vil jo fortsette. Han mener det blir slutt på prosjekter til GPU1 og de gamle 18xx 19xx kortene. Det vill si at det ikke er mulig å bruke gamle 18xx og 19xx kort lengre? eller vil disse også støttes i GPU2 klienten? Lenke til kommentar
Fruktkake Skrevet 26. mai 2008 Rapporter Del Skrevet 26. mai 2008 Hva tror noen om en t-skjorte til sommeren som står "Proteinbretter for Hardware.no" med en logo? Vi kunne vel organisert noe slikt. Lenke til kommentar
Gjest Slettet+9871234 Skrevet 26. mai 2008 Rapporter Del Skrevet 26. mai 2008 I'd buy it. Lenke til kommentar
Theo343 Skrevet 26. mai 2008 Rapporter Del Skrevet 26. mai 2008 Så lenge det ikke er et type trykk som flasser av i vaska så er jeg med på ideen. Men den må være litt stilfull så det ikke ser ut som man reklamerer for en nettside på hele ryggen el. Lenke til kommentar
VikinGz Skrevet 26. mai 2008 Rapporter Del Skrevet 26. mai 2008 også kan overskudde gå til egen server til hardware som folder Lenke til kommentar
WheelMan Skrevet 26. mai 2008 Rapporter Del Skrevet 26. mai 2008 også kan overskudde gå til egen server til hardware som folder i'd agree on that! Lenke til kommentar
Xell Skrevet 26. mai 2008 Rapporter Del Skrevet 26. mai 2008 Under installasjonen (konfigurasjonen egentlig) er ett av spørsmålene om hvor stor cpu-last man vil benytte. Default er 100, men det er bare å skrive inn hva som helst der (0-100). Under linux anbefaler jeg å benytte Ivo Sarak sitt finstall-script.. Jeg har aldri hatt noen problemer med den. Si i fra om du vil ha "full oppskrift" for en installasjon under linux. Siden jeg er relativt ny med Linux kan en oppskrift være ok ja. Og skal F@H være innstallert før man benytter seg av Finstall-script eller må jeg avinnstallere F@H-installen jeg har nå? Edit: Glem det. Gikk egentlig veldig greit å innstallere dette her. Men, fikk fortsatt ikke noe alternativ for å endre CPU-begrensning ved konfirgurering av programmet. Og ja, jeg svarte ja til å endre avanserte innstillinger. Så hvordan gjør man isåfall dette? Vel hvis du allerede har installert så trenger du ikke finstall. Finstall er et script som laster ned alt du trenger og klargjør for å kjøre ting automatisk ved oppstart. Det gjør ting utrolig enkelt og man får med noen enkle overvåkningsverktøy på kjøpet. Neste gang du skal installere FaH på en linux-maskin gjør du følgende; 1: åpne et komandovindu 2: cd ~ (hcis du ikke allerede står i hjemmeonrådet 3: mkdir foldingathome 4: cd foldingathome 5: wget http://www.vendomar.ee/~ivo/finstall (alternativt curl eller likndende hvis ikke du har dette må du installere først; sudo apt-get install wget curl) 6: chmod a+x finstall 7: ./finstall (dette kjører scriptet og går gjennom konfugirasjonen. Du må svare på en del spørsmål underveis det meste er intuitivt) Dersom du kommergjennom installasjon og konfigurasjon uten prooblemer så vil det ligge et script som heter InstallService i samme katalog. kjør dette ved; 8: ./InstallService så blir ting lagt inn som automatisk oppstart og man kan starte å stoppe foldingen ved: cd /etc/init.d ./folding stop eller ./folding start eller ./folding restart Dersom du kjører en 64bits dirstor må du i tillegg ha noen 32-bits biblioteker som kans istalleres ved sudo apt-get install ia32lib Dersom du har 64-bits linux og flerkjerneprosessor kan du velge å installere SMP ved å skrive ./finstall smp (istede for bare ./finstall) i pt 7. Angåedne CPU-load så skal det være et spørsmål under advanced settings. Då får du først spørsmål om "Core Priority (idle/low) [idle]?" Da er det greit å godta idle. Neste spørsmål skal være; "CPU usage requested (5-100) [100]? I stede for å trykke enter her og godta 100 (% load) taster du inn ett tall mellom 5 og 100. Men dersom alt annet ser ut til å virke som det skal trenger du ikke å gå gjennom konfigurasjone bare for å endre CPU-load. Du kan stoppe prosessen (hvordan den må stoppes avhenger av hvordan den er startet), og så editere client.cfg. Husker ikke akkurat hvordan den linja for CPU-load skla se ut men jeg kan skjekke det i morgen på laptopen. Lenke til kommentar
Theo343 Skrevet 27. mai 2008 Rapporter Del Skrevet 27. mai 2008 (endret) Fin linuxguide, jeg bytter kanskje ut noen av mine maskiner med linux og smp vs win og smp. Er det noen som vet hvordan man får GPU2 trayklienten til å starte automatisk ved oppstart før man logger seg på? Den har ingen exefil såvidt jeg kan finne så jeg får ikke schedulert den til å starte ved oppstart , samt at det ikke er noen opsjon for å gjøre den til en service i configuration. Noen ideer? EDIT: Jeg fant ut av det med GPU2 oppstart, jeg bare blandet data og program folder . Fikk schedulert den til å kjøre ved systemoppstart med riktig datafolder uten å manuelt måtte logge på maskinen for oppstart. Maskinen starter opp automatisk fra bios hvor morgen etter at de som sover på rommet har forlatt det og folder til sengetid igjen. Funker greit. Den gir meg ca. 1800-2200PPD(- søvntiden) på mitt "Club3D HD3850 OC" med X2 6000+, dog lar jeg ene kjernen være uvirksom, får ikke mye med en 5.04. Endret 27. mai 2008 av Theo343 Lenke til kommentar
Fruktkake Skrevet 27. mai 2008 Rapporter Del Skrevet 27. mai 2008 Den starter da automatisk hos meg. Lenke til kommentar
Theo343 Skrevet 27. mai 2008 Rapporter Del Skrevet 27. mai 2008 (endret) Den starter da automatisk hos meg. Ja men først når man har logget på skrivebordet. Jeg fikk den til å starte før man kommer til skrivebordet som også var ønsket. EDIT: Ah.. frack it.. den likte ikke å bli avbrutt for å teste oppstart ved reboot. den fikk EUE på 67% [13:27:25] Completed 67%[13:27:49] o send back what have done. [13:27:50] logfile size: 51467 info=51467 bed=23 hdr=1 [13:27:50] - Writing 52003 bytes of core data to disk... [13:27:50] Done: 51491 -> 6449 (compressed to 12.5 percent) [13:27:50] ... Done. [13:27:50] [13:27:50] Folding@home Core Shutdown: EARLY_UNIT_END Dvs. den taklet ikke reboot og startet på en ny enhet når den kom opp igjen :/ Endret 27. mai 2008 av Theo343 Lenke til kommentar
foffle Skrevet 27. mai 2008 Rapporter Del Skrevet 27. mai 2008 Det samme skjer hos meg med GPUv2. Reboot er uaktuelt, hehe. Lenke til kommentar
Arthemax Skrevet 28. mai 2008 Rapporter Del Skrevet 28. mai 2008 Jepp. Da har jeg avinstallert den gamle grafiske klienten min og starta med to tekstbaserte service-klienter, så jeg får brukt begge kjernene. Har utsatt dette altfor lenge, føler jeg.. Lenke til kommentar
