1 hour ago, Jetfighter said:
Hvordan vil PPD være på gamle Xeon'r i dag? I dag har jeg bare en i5 4690k og tenkte på å kjøpe noe brukt med Xeon. Hvordan yter eksempelvis X5690 i dag? Selvfølgelig er forstår jeg at GPU er tingen, men ikke alt foldes på GPU.
Rundt 50K PPD
Fikk kortene i dag, 11min til wu er ferdig. 14411 2.4 mill ppd. 2080s.
Her ser dere hvor lang tid denne wu tok å laste opp. Har 100/100 her.
18:57:18:WU00:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
18:57:18:WU00:FS01:Sending unit results: id:00 state:SEND error:NO_ERROR project:14411 run:0 clone:155 gen:4 core:0x22 unit:0x000000050d5262775e7e46f9f571c728
18:57:18:WU00:FS01:Uploading 124.42MiB to 13.82.98.119
18:57:18:WU00:FS01:Connecting to 13.82.98.119:8080
18:57:24:WU00:FS01:Upload 2.46%
18:57:30:WU00:FS01:Upload 5.22%
18:57:36:WU00:FS01:Upload 7.38%
18:57:42:WU00:FS01:Upload 9.34%
18:57:48:WU00:FS01:Upload 11.80%
18:57:54:WU00:FS01:Upload 14.37%
18:58:00:WU00:FS01:Upload 16.98%
18:58:06:WU00:FS01:Upload 19.74%
18:58:12:WU00:FS01:Upload 22.40%
18:58:18:WU00:FS01:Upload 25.17%
18:58:24:WU00:FS01:Upload 27.78%
18:58:30:WU00:FS01:Upload 30.54%
18:58:36:WU00:FS01:Upload 33.25%
18:58:42:WU00:FS01:Upload 35.87%
18:58:49:WU00:FS01:Upload 37.77%
18:58:55:WU00:FS01:Upload 39.28%
18:59:01:WU00:FS01:Upload 41.99%
18:59:07:WU00:FS01:Upload 44.46%
18:59:13:WU00:FS01:Upload 47.17%
18:59:19:WU00:FS01:Upload 49.73%
18:59:25:WU00:FS01:Upload 52.44%
18:59:31:WU00:FS01:Upload 55.00%
18:59:37:WU00:FS01:Upload 57.16%
18:59:43:WU00:FS01:Upload 59.53%
18:59:49:WU00:FS01:Upload 61.89%
18:59:55:WU00:FS01:Upload 64.55%
19:00:01:WU00:FS01:Upload 67.31%
19:00:07:WU00:FS01:Upload 70.02%
19:00:13:WU00:FS01:Upload 72.54%
19:00:19:WU00:FS01:Upload 74.85%
19:00:25:WU00:FS01:Upload 77.51%
19:00:31:WU00:FS01:Upload 79.92%
19:00:37:WU00:FS01:Upload 82.58%
19:00:43:WU00:FS01:Upload 85.09%
19:00:49:WU00:FS01:Upload 87.86%
19:00:55:WU00:FS01:Upload 90.22%
19:01:01:WU00:FS01:Upload 92.78%
19:01:07:WU00:FS01:Upload 95.44%
19:01:13:WU00:FS01:Upload 98.20%
19:01:17:WU00:FS01:Upload complete
19:01:18:WU00:FS01:Server responded WORK_ACK (400)
19:01:18:WU00:FS01:Final credit estimate, 378698.00 points
19:01:18:WU00:FS01:Cleaning up
Endret av Kjetil Lura
Det er ikke så ille det der da. 4 minutter fra start til work_ack. Jeg ligger normalt rundt det samme når serverene er i godt humør og jeg har 500/500. Det virker som om de har satt en max hastighet pr. upload for å sørge for at det er mer fair. Før var det hit and miss, med uendelig lang ventetid mellom hver connection. Når den først fikk lastet opp var det unnagjort på ett sek eller to, men innen den tid hadde det stort sett gått 10-40% av estimated points på det ferdige arbeidet.
Edit: men hvorfor de ikke bare kan gi poengene som blir estimert når filen blir lagret lokalt må du ikke spørre meg om. IOM at "feilen" med at de ikke kan ta imot arbeid ligger hos deres servere så virker det litt merkelig på meg at det skal gå ut over poengene som blir gitt.
Endret av AveMORphine
Henger meg på bølgen og fyrer opp her også igjen, nå. Har ikke plass til servere hjemme lengre (leilighet nå), men har 2x 1080ti på island som kverner og går på 3mill ppd, + 600k ppd her i stua. Fin varmeovn :)
Blir litt påvirket av poengracet da, sitter og klikker igjennom finn og facebook etter skjermkort.. og jeg er permittert, og trenger noe å gjøre. Dette går aldri bra ?
Fix for installasjon av FAControl Ubuntu 19.10 og dependency issues:
ar x fahcontrol_7.5.1-1_all.deb
tar xf control.tar.gz
sed -i 's/7.5.1-1/7.5.1-2/g' control
sed -i 's/python-gnome2/python-gtk2/g' control
rm control.tar.gz
tar cf control.tar.gz control md5sums
ar rcs fahcontrol_7.5.1-2_all.deb debian-binary control.tar.gz data.tar.xz
sudo dpkg -i fahcontrol_7.5.1-2_all.deb
Jeg prøver å laste ned sertifikatet mitt for å ha passert 3 milliarder ppd, men får kun ned det for antall wu's. Why?
Bare dette jeg får ned uansett hvilken link jeg klikker på for tallene : FoldingAtHome-wus-certificate-98175.jpg
15 minutes ago, Jetfighter said:
Har sett litt på den et par dager nå, men er usikker om det finnes bedre alternativer. Hva bør en se etter hvis man vurderer cpu folding?
Du får langt mer PPD på en nyere ryzen CPU, den der er derimot spot on for de som vil folde på GPU og ha ett billig system under
