Genialt av Elkjøp å bidra med F@H og ja, hadde vært knall om de hadde blitt med i hardware.no laget. :D Jo fler jo bedre.
Her har jeg ikke tenkt å stoppe med å folde etter at Covid-19 pandemien er over, det er så mye mer viktig forskning vi bidrar med!
08:24:20:WU00:FS00:Started FahCore on PID 21501
08:24:20:WU00:FS00:Core PID:21505
08:24:20:WU00:FS00:FahCore 0xa7 started
08:24:20:WU00:FS00:0xa7:*********************** Log Started 2020-03-27T08:24:20Z ***********************
08:24:20:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
08:24:20:WU00:FS00:0xa7:       Type: 0xa7
08:24:20:WU00:FS00:0xa7:       Core: Gromacs
08:24:20:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 704 -lifeline 21501 -checkpoint 15 -np
08:24:20:WU00:FS00:0xa7:             5
08:24:20:WU00:FS00:0xa7:************************************ CBang *************************************
08:24:20:WU00:FS00:0xa7:       Date: Nov 5 2019
08:24:20:WU00:FS00:0xa7:       Time: 06:06:57
08:24:20:WU00:FS00:0xa7:   Revision: 46c96f1aa8419571d83f3e63f9c99a0d602f6da9
08:24:20:WU00:FS00:0xa7:     Branch: master
08:24:20:WU00:FS00:0xa7:   Compiler: GNU 8.3.0
08:24:20:WU00:FS00:0xa7:    Options: -std=c++11 -O3 -funroll-loops -fno-pie -fPIC
08:24:20:WU00:FS00:0xa7:   Platform: linux2 4.19.0-5-amd64
08:24:20:WU00:FS00:0xa7:       Bits: 64
08:24:20:WU00:FS00:0xa7:       Mode: Release
08:24:20:WU00:FS00:0xa7:************************************ System ************************************
08:24:20:WU00:FS00:0xa7:        CPU: Intel(R) Core(TM) i5-9600K CPU @ 3.70GHz
08:24:20:WU00:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 158 Stepping 13
08:24:20:WU00:FS00:0xa7:       CPUs: 6
08:24:20:WU00:FS00:0xa7:     Memory: 15.49GiB
08:24:20:WU00:FS00:0xa7:Free Memory: 269.86MiB
08:24:20:WU00:FS00:0xa7:    Threads: POSIX_THREADS
08:24:20:WU00:FS00:0xa7: OS Version: 5.3
08:24:20:WU00:FS00:0xa7:Has Battery: false
08:24:20:WU00:FS00:0xa7: On Battery: false
08:24:20:WU00:FS00:0xa7: UTC Offset: 1
08:24:20:WU00:FS00:0xa7:        PID: 21505
08:24:20:WU00:FS00:0xa7:        CWD: /var/lib/fahclient/work
08:24:20:WU00:FS00:0xa7:******************************** Build - libFAH ********************************
08:24:20:WU00:FS00:0xa7:    Version: 0.0.18
08:24:20:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
08:24:20:WU00:FS00:0xa7:  Copyright: 2019 foldingathome.org
08:24:20:WU00:FS00:0xa7:   Homepage: https://foldingathome.org/
08:24:20:WU00:FS00:0xa7:       Time: 06:13:26
08:24:20:WU00:FS00:0xa7:   Revision: 490c9aa2957b725af319379424d5c5cb36efb656
08:24:20:WU00:FS00:0xa7:************************************ Build *************************************
08:24:20:WU00:FS00:0xa7:       SIMD: avx_256
08:24:20:WU00:FS00:0xa7:********************************************************************************
08:24:20:WU00:FS00:0xa7:Project: 14346 (Run 1, Clone 3, Gen 1)
08:24:20:WU00:FS00:0xa7:Unit: 0x0000000325bb0c305e728be8f208ec62
08:24:20:WU00:FS00:0xa7:Digital signatures verified
08:24:20:WU00:FS00:0xa7:Reducing thread count from 5 to 4 to avoid domain decomposition by a prime number > 3
08:24:20:WU00:FS00:0xa7:Calling: mdrun -s frame1.tpr -o frame1.trr -cpt 15 -nt 4
08:24:20:WU00:FS00:0xa7:Steps: first=0 total=250000
08:24:21:WU00:FS00:0xa7:Completed 1 out of 250000 steps (0%)
08:24:21:WU00:FS00:0xa7:ERROR:
08:24:21:WU00:FS00:0xa7:ERROR:-------------------------------------------------------
08:24:21:WU00:FS00:0xa7:ERROR:Program GROMACS, VERSION 5.0.4-20191026-456f0d636-unknown
08:24:21:WU00:FS00:0xa7:ERROR:Source code file: /host/debian-stable-64bit-core-a7-avx-release/gromacs-core/build/gromacs/src/gromacs/mdlib/pme.c, line: 754
08:24:21:WU00:FS00:0xa7:ERROR:Fatal error:
08:24:21:WU00:FS00:0xa7:ERROR:7 particles communicated to PME rank 1 are more than 2/3 times the cut-off out of the domain decomposition cell of their charge group in dimension x.
08:24:21:WU00:FS00:0xa7:ERROR:This usually means that your system is not well equilibrated.
08:24:21:WU00:FS00:0xa7:ERROR:For more information and tips for troubleshooting, please check the GROMACS
08:24:21:WU00:FS00:0xa7:ERROR:website at http://www.gromacs.org/Documentation/Errors
08:24:26:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
Det var jo kjedelig
Ett spørsmål til dere som har holdt på en stund.
Jeg ser at produksjonen fremdeles går nedover. Er det noe å hente på å få mer hardware i drift ved f.eks kronerulling ell?
Og ett åpent spørsmål.
Nå som elkjøp har gjort dette PR stuntet med sitt eget team, er det noen som kan dra i kontakter hos f.eks power for å få de til å danne en bruker i dette teamet istedet for å danne eget team?
Endret av AveMORphine
b-real skrev (10 timer siden):
Ingen GUI (eller jeg orker ikke koble til skjerm osv again på serveren)
Det er mulig å kjøre FAHControl på en annen pc og kople til serveren for å styre den (pause av/på, endre instillinger osv.)
HawP skrev (5 minutter siden):
Det du spør om her vet jeg knopflerbruce er kompetent til å svare på.
Jeg har benyttet tredjepart som TeamViewer eller remote desktop etc for å tipse om ett alternativ.
Takk for ditt og alle andres bidrag nok en gang ❤️
Kolvrick er jo en av de som har travet sammen med oss i dette sporet i årenes løp. Stor takk til deg også :love:
Som sagt de kjører uten passkey, så deres siste totale point update kunne jeg matche med 2xCPU og 2xGPU som er ett par generasjoner gamle.
De har også produsert mer enn 10 WU units, så om de hadde lagt inn passkey, så ville det vært synlig.
F@H clienten har innebygget remote støtte. Har lånt tastatur fra pc'en nede som kona bruker på sitt hjemmekontor. Sitter på laptoppen i stua og sjekker Folding status på gamer laptoppen min med 90m Geforce kort + også 1060 GPU'en på stasjonære nede.
Var ganske greit å sette opp for i "hovedmaskinen" du vil styre fra så har du helt til venstre klienter, der kan du trykke add og legge til IP/Hostname etc og evt username og password etc for den du skal remote styre. På den andre maskinen som skal styres så må du evt på forhånd aktivere det, så 1 gangs med mus og tastatur og sett opp der. Vipps kan man styre mange F@H klienter fra en PC. :)
Jeg måtte bare trikse litt frem og tilbake med Firewallen i Eset antivirusen min.
  • Innsiktsfullt 1
Til de som vil følge med.
Sett ip i config på remote til 0.0.0.0/0 og reboot klienten.
Så legger man inn HFM.NET og adder klientene med ip.
Bare klienten på maskinen hfm er på trenger 127-adressen, og på ppd-siden til extreemeckokkers har du iden din til hfm i nettadressen på ditt navn ?
