Core 18, 004 funker bra:
Fermi/Core_21.fah/FahCore_21.exe" -dir 00 -suffix 01 -version 704 -lifeline 5048 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
16:41:31:WU00:FS00:Started FahCore on PID 4436
16:41:31:WU00:FS00:Core PID:3504
16:41:31:WU00:FS00:FahCore 0x21 started
16:41:32:WU00:FS00:0x21:*********************** Log Started 2017-02-01T16:41:32Z ***********************
16:41:32:WU00:FS00:0x21:Project: 9431 (Run 244, Clone 0, Gen 5)
16:41:32:WU00:FS00:0x21:Unit: 0x00000005ab436c9d586fdd35a7be49d0
16:41:32:WU00:FS00:0x21:CPU: 0x00000000000000000000000000000000
16:41:32:WU00:FS00:0x21:Machine: 0
16:41:32:WU00:FS00:0x21:Reading tar file core.xml
16:41:32:WU00:FS00:0x21:Reading tar file integrator.xml
16:41:32:WU00:FS00:0x21:Reading tar file state.xml
16:41:32:WU00:FS00:0x21:Reading tar file system.xml
16:41:32:WU00:FS00:0x21:Digital signatures verified
16:41:32:WU00:FS00:0x21:Folding@home GPU Core21 Folding@home Core
16:41:32:WU00:FS00:0x21:Version 0.0.18
16:41:37:WU00:FS00:0x21:ERROR:Force RMSE error of 646.444 with threshold of 5
16:41:37:WU00:FS00:0x21:Saving result file logfile_01.txt
16:41:37:WU00:FS00:0x21:Saving result file log.txt
16:41:37:WU00:FS00:0x21:Folding@home Core Shutdown: BAD_WORK_UNIT
16:41:37:WARNING:WU00:FS00:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
16:41:37:WU00:FS00:Sending unit results: id:00 state:SEND error:FAULTY project:9431 run:244 clone:0 gen:5 core:0x21 unit:0x00000005ab436c9d586fdd35a7be49d0
16:41:37:WU00:FS00:Uploading 7.00KiB to 171.67.108.157
16:41:37:WU00:FS00:Connecting to 171.67.108.157:8080
16:41:37:WU00:FS00:Upload complete
16:41:37:WU00:FS00:Server responded WORK_ACK (400)
16:41:37:WU00:FS00:Cleaning up
16:41:37:WU01:FS00:Connecting to 171.67.108.45:80
16:41:38:WU01:FS00:Assigned to work server 171.64.65.84
16:41:38:WU01:FS00:Requesting new work unit for slot 00: READY gpu:1:GP104 [GeForce GTX 1080] from 171.64.65.84
16:41:38:WU01:FS00:Connecting to 171.64.65.84:8080
16:41:39:ERROR:WU01:FS00:Exception: Server did not assign work unit
16:41:39:WU01:FS00:Connecting to 171.67.108.45:80
16:41:40:WU01:FS00:Assigned to work server 171.67.108.159
16:41:40:WU01:FS00:Requesting new work unit for slot 00: READY gpu:1:GP104 [GeForce GTX 1080] from 171.67.108.159
16:41:40:WU01:FS00:Connecting to 171.67.108.159:8080
16:41:40:WU01:FS00:Downloading 20.01MiB
16:41:45:WU01:FS00:Download complete
16:41:45:WU01:FS00:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:9151 run:0 clone:29 gen:100 core:0x18 unit:0x0000006fab436c9f566253cf9da8f8b7
16:41:45:WU01:FS00:Starting
16:41:45:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" "C:/Users/Kjetil Lura/AppData/Roaming/FAHClient/cores/fahwebx.stanford.edu/cores/Win32/AMD64/NVIDIA/Fermi/Core_18.fah/FahCore_18.exe" -dir 01 -suffix 01 -version 704 -lifeline 5048 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
16:41:45:WU01:FS00:Started FahCore on PID 7572
16:41:46:WU01:FS00:Core PID:5652
16:41:46:WU01:FS00:FahCore 0x18 started
16:41:47:WU01:FS00:0x18:*********************** Log Started 2017-02-01T16:41:46Z ***********************
16:41:47:WU01:FS00:0x18:Project: 9151 (Run 0, Clone 29, Gen 100)
16:41:47:WU01:FS00:0x18:Unit: 0x0000006fab436c9f566253cf9da8f8b7
16:41:47:WU01:FS00:0x18:CPU: 0x00000000000000000000000000000000
16:41:47:WU01:FS00:0x18:Machine: 0
16:41:47:WU01:FS00:0x18:Reading tar file core.xml
16:41:47:WU01:FS00:0x18:Reading tar file integrator.xml
16:41:47:WU01:FS00:0x18:Reading tar file state.xml
16:41:47:WU01:FS00:0x18:Reading tar file system.xml
16:41:47:WU01:FS00:0x18:Digital signatures verified
16:41:47:WU01:FS00:0x18:Folding@home GPU core18
16:41:47:WU01:FS00:0x18:Version 0.0.4
16:42:11:WU01:FS00:0x18:Completed 0 out of 2500000 steps (0%)
16:42:11:WU01:FS00:0x18:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
16:43:09:WU01:FS00:0x18:Completed 25000 out of 2500000 steps (1%)
16:44:00:WU01:FS00:0x18:Completed 50000 out of 2500000 steps (2%)
16:44:51:WU01:FS00:0x18:Completed 75000 out of 2500000 steps (3%)
16:45:42:WU01:FS00:0x18:Completed 100000 out of 2500000 steps (4%)
16:46:42:WU01:FS00:0x18:Completed 125000 out of 2500000 steps (5%)
16:47:33:WU01:FS00:0x18:Completed 150000 out of 2500000 steps (6%)
16:48:24:WU01:FS00:0x18:Completed 175000 out of 2500000 steps (7%)
16:49:15:WU01:FS00:0x18:Completed 200000 out of 2500000 steps (8%)
Aner ikke om jeg har problemer fortsatt med foldingen. Får ikke sjekket før jeg kommer hjem. Hvilken 37X.XX driver funker med folding?
378.49 funker både med 980Ti og 1080 her.
Er det på c21 v 0018 :hmm: Gidder du se i loggen din :)
Core 21 funker ja.
Har ikke fått flere problemer idag enn så lenge. Men fikk en 0x18 P9151 som gir en PPD på usle 55K. Håper den endrer seg etter hvert, gjort ca 0,5%...
Jeg får prøve ny driver hvis jeg får flere problemer.
Kjører samme jobb på evga sc, gir meg 760938 ppd.
PS: Sammen med nacl, og det er bra. Kjører slik til i morgen.
Endret av Kjetil Lura
980Ti her, ikke 1080. Den gikk opp etterhvert. Så ble en 600-700K PPD tror jeg.
Har noen problemer med den ene maskinen min, men det er nok p.g.a maskinen som lager krøll og ikke på PGs side.   Trodde jeg fiksa det i går, men på morran her så hadde jeg masse bad WU-meldinger.  Hadde ikke tid til å se på det før jeg løp på jobb, får ta det når jeg kommer meg heim igjen.
