Får litt trøbbel nå med foldingen. Den hopper mellom Ready og Running. Fikk deretter Failed.
Logg
20:14:55:WU01:FS00:0x21:*********************** Log Started 2016-04-18T20:14:55Z ***********************
20:14:55:WU01:FS00:0x21:Project: 13105 (Run 7, Clone 7, Gen 145)
20:14:55:WU01:FS00:0x21:Unit: 0x000000a4ab436c9056ccc0154621f3cf
20:14:55:WU01:FS00:0x21:CPU: 0x00000000000000000000000000000000
20:14:55:WU01:FS00:0x21:Machine: 0
20:14:55:WU01:FS00:0x21:Reading tar file core.xml
20:14:55:WU01:FS00:0x21:Reading tar file integrator.xml
20:14:55:WU01:FS00:0x21:Reading tar file state.xml
20:14:57:WU01:FS00:0x21:Reading tar file system.xml
20:14:57:WU01:FS00:0x21:Digital signatures verified
20:14:57:WU01:FS00:0x21:Folding@home GPU Core21 Folding@home Core
20:14:57:WU01:FS00:0x21:Version 0.0.17
20:14:57:WU01:FS00:0x21:ERROR:Bad platformId size.
20:14:57:WU01:FS00:0x21:Saving result file logfile_01.txt
20:14:57:WU01:FS00:0x21:Saving result file log.txt
20:14:57:WU01:FS00:0x21:Folding@home Core Shutdown: BAD_WORK_UNIT
20:14:58:WARNING:WU01:FS00:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
20:14:58:WU01:FS00:Sending unit results: id:01 state:SEND error:FAULTY project:13105 run:7 clone:7 gen:145 core:0x21 unit:0x000000a4ab436c9056ccc0154621f3cf
20:14:58:WU01:FS00:Uploading 2.03KiB to 171.67.108.144
20:14:58:WU01:FS00:Connecting to 171.67.108.144:8080
20:14:58:WU00:FS00:Connecting to 171.67.108.45:80
20:14:58:WU01:FS00:Upload complete
20:14:58:WU01:FS00:Server responded WORK_ACK (400)
20:14:58:WU01:FS00:Cleaning up
20:14:59:WU00:FS00:Assigned to work server 140.163.4.242
20:14:59:WU00:FS00:Requesting new work unit for slot 00: READY gpu:0:GK106 [GeForce GTX 650 Ti] from 140.163.4.242
20:14:59:WU00:FS00:Connecting to 140.163.4.242:8080
20:14:59:WU00:FS00:Downloading 4.05MiB
20:15:03:WU00:FS00:Download complete
20:15:04:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:11401 run:2 clone:9 gen:97 core:0x21 unit:0x000000d48ca304f255de8eca3fcd42ec
20:15:04:WU00:FS00:Starting
20:15:04:WU00:FS00:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/web.stanford.edu/~pande/Linux/AMD64/NVIDIA/Fermi/Core_21.fah/FahCore_21 -dir 00 -suffix 01 -version 704 -lifeline 18306 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
20:15:04:WU00:FS00:Started FahCore on PID 22262
20:15:04:WU00:FS00:Core PID:22266
20:15:04:WU00:FS00:FahCore 0x21 started
20:15:04:WU00:FS00:0x21:*********************** Log Started 2016-04-18T20:15:04Z ***********************
20:15:04:WU00:FS00:0x21:Project: 11401 (Run 2, Clone 9, Gen 97)
20:15:04:WU00:FS00:0x21:Unit: 0x000000d48ca304f255de8eca3fcd42ec
20:15:04:WU00:FS00:0x21:CPU: 0x00000000000000000000000000000000
20:15:04:WU00:FS00:0x21:Machine: 0
20:15:04:WU00:FS00:0x21:Reading tar file core.xml
20:15:04:WU00:FS00:0x21:Reading tar file system.xml
20:15:04:WU00:FS00:0x21:Reading tar file integrator.xml
20:15:04:WU00:FS00:0x21:Reading tar file state.xml
20:15:05:WU00:FS00:0x21:Digital signatures verified
20:15:05:WU00:FS00:0x21:Folding@home GPU Core21 Folding@home Core
20:15:05:WU00:FS00:0x21:Version 0.0.17
20:15:05:WU00:FS00:0x21:ERROR:Bad platformId size.
20:15:05:WU00:FS00:0x21:Saving result file logfile_01.txt
20:15:05:WU00:FS00:0x21:Saving result file log.txt
20:15:05:WU00:FS00:0x21:Folding@home Core Shutdown: BAD_WORK_UNIT
20:15:05:WARNING:WU00:FS00:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
20:15:05:WU00:FS00:Sending unit results: id:00 state:SEND error:FAULTY project:11401 run:2 clone:9 gen:97 core:0x21 unit:0x000000d48ca304f255de8eca3fcd42ec
20:15:05:WU00:FS00:Uploading 2.03KiB to 140.163.4.242
20:15:05:WU00:FS00:Connecting to 140.163.4.242:8080
20:15:05:WU01:FS00:Connecting to 171.67.108.45:80
20:15:05:WU00:FS00:Upload complete
20:15:06:WU00:FS00:Server responded WORK_ACK (400)
20:15:06:WU00:FS00:Cleaning up
20:15:06:WU01:FS00:Assigned to work server 171.64.65.92
20:15:06:WU01:FS00:Requesting new work unit for slot 00: READY gpu:0:GK106 [GeForce GTX 650 Ti] from 171.64.65.92
20:15:06:WU01:FS00:Connecting to 171.64.65.92:8080
20:15:07:WU01:FS00:Downloading 3.07MiB
20:15:13:WU01:FS00:Download 32.57%
20:15:16:WU01:FS00:Download complete
20:15:16:WU01:FS00:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:9160 run:33 clone:0 gen:180 core:0x18 unit:0x000000c9ab40415c567464618039361a
20:15:16:WU01:FS00:Starting
20:15:16:WU01:FS00:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/web.stanford.edu/~pande/Linux/AMD64/NVIDIA/Fermi/Core_18.fah/FahCore_18 -dir 01 -suffix 01 -version 704 -lifeline 18306 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
20:15:16:WU01:FS00:Started FahCore on PID 22277
20:15:16:WU01:FS00:Core PID:22281
20:15:16:WU01:FS00:FahCore 0x18 started
20:15:17:WU01:FS00:0x18:*********************** Log Started 2016-04-18T20:15:16Z ***********************
20:15:17:WU01:FS00:0x18:Project: 9160 (Run 33, Clone 0, Gen 180)
20:15:17:WU01:FS00:0x18:Unit: 0x000000c9ab40415c567464618039361a
20:15:17:WU01:FS00:0x18:CPU: 0x00000000000000000000000000000000
20:15:17:WU01:FS00:0x18:Machine: 0
20:15:17:WU01:FS00:0x18:Reading tar file core.xml
20:15:17:WU01:FS00:0x18:Reading tar file system.xml
20:15:17:WU01:FS00:0x18:Reading tar file integrator.xml
20:15:17:WU01:FS00:0x18:Reading tar file state.xml
20:15:17:WU01:FS00:0x18:Digital signatures verified
20:15:17:WU01:FS00:0x18:Folding@home GPU core18
20:15:17:WU01:FS00:0x18:Version 0.0.4
20:15:17:WU01:FS00:0x18:ERROR:exception: Bad platformId size.
20:15:17:WU01:FS00:0x18:Saving result file logfile_01.txt
20:15:17:WU01:FS00:0x18:Saving result file log.txt
20:15:17:WU01:FS00:0x18:Folding@home Core Shutdown: BAD_WORK_UNIT
20:15:17:WARNING:WU01:FS00:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
20:15:17:WU01:FS00:Sending unit results: id:01 state:SEND error:FAULTY project:9160 run:33 clone:0 gen:180 core:0x18 unit:0x000000c9ab40415c567464618039361a
20:15:17:WU01:FS00:Uploading 1.92KiB to 171.64.65.92
20:15:17:WU01:FS00:Connecting to 171.64.65.92:8080
20:15:17:WU00:FS00:Connecting to 171.67.108.45:80
20:15:18:WU01:FS00:Upload complete
20:15:18:WU01:FS00:Server responded WORK_ACK (400)
20:15:18:WU01:FS00:Cleaning up
20:15:18:WU00:FS00:Assigned to work server 171.64.65.61
20:15:18:WU00:FS00:Requesting new work unit for slot 00: READY gpu:0:GK106 [GeForce GTX 650 Ti] from 171.64.65.61
20:15:18:WU00:FS00:Connecting to 171.64.65.61:8080
20:15:19:WU00:FS00:Downloading 3.19MiB
20:15:25:WU00:FS00:Download 39.20%
20:15:28:WU00:FS00:Download complete
20:15:28:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:9137 run:35 clone:0 gen:352 core:0x18 unit:0x0000019c0a3b1e61556647d0cd289bd9
20:15:28:WU00:FS00:Starting
20:15:28:WU00:FS00:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/web.stanford.edu/~pande/Linux/AMD64/NVIDIA/Fermi/Core_18.fah/FahCore_18 -dir 00 -suffix 01 -version 704 -lifeline 18306 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
20:15:28:WU00:FS00:Started FahCore on PID 22291
20:15:28:WU00:FS00:Core PID:22295
20:15:28:WU00:FS00:FahCore 0x18 started
20:15:28:WU00:FS00:0x18:*********************** Log Started 2016-04-18T20:15:28Z ***********************
20:15:28:WU00:FS00:0x18:Project: 9137 (Run 35, Clone 0, Gen 352)
20:15:28:WU00:FS00:0x18:Unit: 0x0000019c0a3b1e61556647d0cd289bd9
20:15:28:WU00:FS00:0x18:CPU: 0x00000000000000000000000000000000
20:15:28:WU00:FS00:0x18:Machine: 0
20:15:28:WU00:FS00:0x18:Reading tar file core.xml
20:15:28:WU00:FS00:0x18:Reading tar file system.xml
20:15:28:WU00:FS00:0x18:Reading tar file integrator.xml
20:15:28:WU00:FS00:0x18:Reading tar file state.xml
20:15:29:WU00:FS00:0x18:Digital signatures verified
20:15:29:WU00:FS00:0x18:Folding@home GPU core18
20:15:29:WU00:FS00:0x18:Version 0.0.4
20:15:29:WU00:FS00:0x18:ERROR:exception: Bad platformId size.
20:15:29:WU00:FS00:0x18:Saving result file logfile_01.txt
20:15:29:WU00:FS00:0x18:Saving result file log.txt
20:15:29:WU00:FS00:0x18:Folding@home Core Shutdown: BAD_WORK_UNIT
20:15:29:WARNING:WU00:FS00:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
20:15:29:WU00:FS00:Sending unit results: id:00 state:SEND error:FAULTY project:9137 run:35 clone:0 gen:352 core:0x18 unit:0x0000019c0a3b1e61556647d0cd289bd9
20:15:29:WU00:FS00:Uploading 1.91KiB to 171.64.65.61
20:15:29:WU00:FS00:Connecting to 171.64.65.61:8080
20:15:29:WU01:FS00:Connecting to 171.67.108.45:80
20:15:30:WU00:FS00:Upload complete
20:15:30:WU00:FS00:Server responded WORK_ACK (400)
20:15:30:WU00:FS00:Cleaning up
20:15:30:WU01:FS00:Assigned to work server 171.67.108.144
20:15:30:WU01:FS00:Requesting new work unit for slot 00: READY gpu:0:GK106 [GeForce GTX 650 Ti] from 171.67.108.144
20:15:30:WU01:FS00:Connecting to 171.67.108.144:8080
20:15:44:WU01:FS00:Downloading 8.23MiB
Byttet tilbake til CPU og alt ble i orden igjen. Byttet igjen tilbake til GPU og den kjører fortsatt foldingen.
Den skal vistnok bruke GPU nå, men i følge nvidia-smi så brukes det ikke noe av GPU.
Jeg måtte starte PC på nytt og når den begynte med foldingen fikk jeg samme problem den gikk fram og tilbake med Ready/Running og fikk til slutt Failed. Kanskje den ikke får til å bruke GPU til folding. Bytter jeg til CPU så går det fint.
Endret av DJViking
Er det noen som kjører folding på OpenSUSE med Nvidia GPU?
Jeg har undersøkt på forumet til Folding@Home, men fortsatt ikke funnet ut hvorfor folding med GPU ikke vil virke.
Ble fortalt at jeg trengte å installere OpenCL med pakken libOpenCL, men pakken nvidia-computeG04 skal vist nok tilby det samme. Får uansett konflikt mellom disse dersom jeg forsøker å installere libOpenCL.
Nå er ikke jeg så veldig godt kjent med disse, men hva med CUDA brukes ikke den til folding?
https://foldingforum.org/viewtopic.php?f=61&t=28751
Edit: Jeg fant ut hvorfor FAHClient ikke kunne bruke GPU. Brukeren fahclient hadde ikke tilgang. Dersom jeg kjørte som min egen bruker gikk det fint å folde med GPU.
Endret av DJViking
Jeg har satt folding på 5 rigger. Derav 4 står folding på 24/7. På min folder den alltid med mindre jeg ikke spiller/bruker GPU.
På min pauser jeg, på de andre pauser jeg ikke.
Lettere å trykke pause, enn at den skal folde kun på idle. ^
Dette gjelder 3x 980Ti og 2x 980.
Endret av Snusmumr1kk1
Begge deler, skjønt folderiggen har vært nede en stund og jeg har mye annet å gjøre på tapeten så jeg har ikke fått sett skikkelig på den ennå.
Jeg folder på hovedriggen som jeg ogå spiller på, men selvsagt ikke samtidig. Jeg bruker "on idle" fremfor "pause" for å unngå mye dødtid om jeg glemmer å unpause - og så fjerner jeg "on idle" når jeg er ferdig med spillingen. Til det meste annet enn spilling fungerer det tålelig fint å folde samtidig, men noe avhengig av prosjektet som foldes hender det det lagger når jeg ser video. Da havner foldingen fort "on idle" igjen.
På min gamle rigg har jeg kun et enkelt GeForce GTX 650 Ti. I så tilfelle hvis man folder på GPU kan systemet gå tregt. Tror det nok vil gå fint å folde på et SLI oppsett på en GPU, mens systemet bruker en annen GPU.
Endret av DJViking
jeg folder på begge GPUene jeg har og merker ikke noe treghet i mitt system...
