Vel, da er en era over:
https://folding.stanford.edu/home/big-adv-program-ends-january-31/
As we have previously announced, the bigadv (BA) program will reach end-of-life on January 31, 2015. We would like to thank all the donors who have contributed to the program. Throughout the history of Folding@home, donor participation has enabled us to tackle hard problems and engage in bold experiments. The BA program is an example of both of these––the projects in BA are one that simply could not have been addressed otherwise. We are still analyzing the results of these projects, but the preliminary data already yields some exciting results that we are comparing to experiments.
Although the BA program is ending, we recognize that the many-core systems previously used to run BA may not perform optimally on all work units in the Folding@home ecosystem (although they will do quite well on most). In an ideal world, we would have each project performance-benchmarked on a wide variety of systems and a dynamic allocation scheme that matches clients to projects that perform well on their hardware while ensuring a distribution of client capability across Folding@home scientific priorities. However, this sort of matching is more technically involved (and places larger demands on the assignment server) than we are able to offer at this time. At BA end-of-life, in order to make sure that these many-core get WUs best suited for them, clients continuing to use the BA flags will be directed to large work units, although these will carry the normal Folding@Home points scheme rather than a BA scheme. We are planning to expand the diversity of these work units to include a variety of “large” simulation problems, but at this point we are not making statements as to the anticipated longevity of this scheme.
Thank you once again for contributing to Folding@home, whether the BA program or any of our other initiatives. All our past and future scientific achievements are due to your participation and generosity.
Det er vel ikke for mange BA-maskiner i aktivitet i gruppa, så utfallet på PPD blir forhåpentligvis ikke så stort.
Har stort sett bare BA-servere, så da forsvinner nok jeg stille og rolig hvis det ikke kommer noen erstatning.
Siden vi trenger deg i foldetråden , også som mental støtte.
Hvor mye kan du selge de for tror du? Legge på finn, fiske osv.
Du har jo ikke tunge kjølere på den, veldig sendbare.
Luftkjølere demonteres og sendes i egen eske osv.
alternativ 2, hvor mange pci-e-spor er det på hovedkortene dine? Dvs hvor mange dual-slot-kort får du.
Tenk bussbredde her med 4x cpuer :rofl:
Nå har vi hatt de en god stund, heldigvis er de "nedbetalt" over tid pga vi fikk brukt de mye.
4x 780ti eller 3,3 970 osv erstatter riggene ppd-messig
Da var varmekablene på for første gang siden jeg flyttet inn her, august 2008.
Etter at serverne har levert sin siste BA får de ikke lenger kontakt med workserver og blir bare stående å mase om ny WU. De 2 siste maskinene (på hytta) vil være ferdige omkring kl. 10.00 i dag, og da blir bare GPU-riggen værende i gang enn så lenge. Nå skal jeg lytte til den totale stillheten på kontoret noen dager før jeg bestemmer meg for hva jeg gjør videre.
NB. Egentlig så forstår jeg lite av at de bare kutter BA programmet tvert. Da er det ikke mye snakk om å gjøre ferdig sakene, som de argumenterer for ved foreks. core15 prosjektene som var annonsert slutt november 2013, men fremdeles kjører!
Endret av -alias-
Helt enig. Dette går langt over min fatteevne. Men det er logisk tenkning som tilsier at alle forklaringer relatert til Core 15 evige fortsettelse også skulle gjelde andre prosjekter.
De har sikkert en forklaring. Skal prøve å være åpen for den. Ser for meg at det vil være umenneskelig å "kjøpe" den forklaringen for de største BA folderene.
Men denne gangen ble det faktisk slik de hadde varslet. Enn om det kunne bli en ny trend ;)
Vi trenger deg på laget -alias- så håper du finner motivasjonen til å fortsette, enn om i en mindre skala
Det kan jo tenkes at dette er et resultat av informasjonen de får inn - at det viser seg at for noen prosjekter er det nødvendig med mer data for å gi et godt forskningsgrunnlag. Synd BA er borte, men de skriver jo at det vil kunne komme WUer som er nyttige for den type maskiner senere - men om de vil ha best PPD/watt-ratio eller lignende er et annet spørsmål.
Nå¨har man WCG også, som utelukkende kjører på CPU såvidt jeg har forstått.
Jepp og det har vi gjort de siste 2 ukene hvor vi har hatt større produksjon enn curecoin.Tipper at curecoin vil bli betydelig redusert nå siden de har hatt flere BA-foldere som nå får senket sin produksjon til omkring 40% av tidligere, hvis de i det hele tatt får ned nye jobber. Alle mine servere ble bare stående uten å få ned nye prosjekter, hvorpå jeg stengte de ned av samme årsak. Siste døgn satte vi også ny rekord med over 41 millioner poeng.
Klipp fra loggen på en av dem:
--- Opening Log file [February 1 13:42:01 UTC]
[13:44:13] + Attempting to get work packet
[13:44:13] Passkey found
[13:44:13] - Will indicate memory of 31161 MB
[13:44:13] - Connecting to assignment server
[13:44:13] Connecting to http://assign.stanford.edu:8080/
[13:44:13] Posted data.
[13:44:13] Initial: 0000; + Could not authenticate Assignment Server response
[13:44:13] Connecting to http://assign2.stanford.edu:80/
[13:44:14] Posted data.
[13:44:14] Initial: 0000; + Could not authenticate Assignment Server 2 response
[13:44:14] + Couldn't get work instructions.
[13:44:14] - Attempt #5 to get work failed, and no other work to do.
Waiting before retry.
[13:45:38] + Attempting to get work packet
[13:45:38] Passkey found
[13:45:38] - Will indicate memory of 31161 MB
[13:45:38] - Connecting to assignment server
[13:45:38] Connecting to http://assign.stanford.edu:8080/
[13:45:39] Posted data.
[13:45:39] Initial: 0000; + Could not authenticate Assignment Server response
[13:45:39] Connecting to http://assign2.stanford.edu:80/
[13:45:40] Posted data.
[13:45:40] Initial: 0000; + Could not authenticate Assignment Server 2 response
[13:45:40] + Couldn't get work instructions.
[13:45:40] - Attempt #6 to get work failed, and no other work to do.
Endret av -alias-
Ny måneds rekord.
Ny rekord for dags produksjon
Avslutningen av BigAdv vil mest sannsynlig være godt synlig på statistikken neste mnd.
Men trøsten er at vårt lag ikke blir like rammet som enkelte av de andre :hm:
Samtidig er GPU virkelig veien å gå. Det er bedre PPD pr watt for 970 enn BigAdv.
Jeg trenger å frigjøre PCI-e slots ...
Kan noen foreslå en god pris på et
Gainward GeForce GTX 780Ti 3GB PhysX
https://www.komplett.no/k/ki.aspx?sku=804118
Det kostet 5995,- for et år siden.
Jeg ønsker å selge dette til en god pris til noen på laget. Alle kan foreslå en pris, laveste pris vinner. Den som hadde lavest PPD 1. feb som er villig til å betale denne prisen får kjøpe.Det kan ikke være samme person som foreslo pris som får kjøpe til den prisen.
Jeg håper dette ikke bare gir støy i denne tråden, så jeg starter budrunden på 2 000,- Alle som har lagt inn bud trenger ikke bekrefte når prisen går ned.
Prisen inkluderer frakt.
Frister litt faktisk, Hadde blitt en fin økning i PPD det^^
Endret av Snusmumr1kk1
Det er 250 watt også. Det er 100 watt mer enn GTX 970, det.
Strømforbruk ved drift 375 watt. Så er ikke aktuelt og 500w psu er i det minste laget sn1ken. Eller hva :green:
De som spiller, og som kjører CPU og GPU med mye OC (dette skjer jo uten at du har klokket selv, maskinen gasser på under Bench osv..) kommer sikkert til kort med 500W, men jeg tenker som en ren foldemaskin ;)
Edit:
AMD belaster ikke CPU slik Nvidia gjør, så blir under 100W for systemet + GPU.
500W er jo ikke ideelt, men det vil ganske sikkert holde (dersom det ikke er en ekstremt dårlig PSU).
Endret av Sn1ken
