Åja, tolket posten som fra loggen jeg.
Åja kaller du dette en nyttig info? Jeg kjører på 3:
21:20:33:WU01:FS00:0x17:Completed 25000 out of 2500000 steps (1%)
21:22:29:WU01:FS00:0x17:Completed 50000 out of 2500000 steps (2%)
21:24:32:WU01:FS00:0x17:Completed 75000 out of 2500000 steps (3%)
21:26:27:WU01:FS00:0x17:Completed 100000 out of 2500000 steps (4%)
21:28:30:WU01:FS00:0x17:Completed 125000 out of 2500000 steps (5%)
21:30:26:WU01:FS00:0x17:Completed 150000 out of 2500000 steps (6%)
21:32:29:WU01:FS00:0x17:Completed 175000 out of 2500000 steps (7%)
21:34:25:WU01:FS00:0x17:Completed 200000 out of 2500000 steps (8%)
21:36:28:WU01:FS00:0x17:Completed 225000 out of 2500000 steps (9%)
21:38:24:WU01:FS00:0x17:Completed 250000 out of 2500000 steps (10%)
21:40:27:WU01:FS00:0x17:Completed 275000 out of 2500000 steps (11%)
21:42:23:WU01:FS00:0x17:Completed 300000 out of 2500000 steps (12%)
21:44:26:WU01:FS00:0x17:Completed 325000 out of 2500000 steps (13%)
21:46:22:WU01:FS00:0x17:Completed 350000 out of 2500000 steps (14%)
21:48:25:WU01:FS00:0x17:Completed 375000 out of 2500000 steps (15%)
21:50:20:WU01:FS00:0x17:Completed 400000 out of 2500000 steps (16%)
21:52:23:WU01:FS00:0x17:Completed 425000 out of 2500000 steps (17%)
21:54:19:WU01:FS00:0x17:Completed 450000 out of 2500000 steps (18%)
21:56:22:WU01:FS00:0x17:Completed 475000 out of 2500000 steps (19%)
Jeg sitter igrunnen med 1 god laptop som kan levere 10K PPD, 2x 560Ti som kan levere rundt 40-50K tilsammen - men 4 pcer som kan knapt levere 5K PPD og bruker dobbelt så mye strøm som de overnevnte..
Alias? Kan min HP ProLiant ML350 G5 med 2 sockets levere noe nyttig? Eventuelt, hvilken Xeon CPU er best for denne?
Socketen er enten LGA771 eller PLGA771. Er usikker, men det kan sjekkes imorgen!
Det er vel denne serien som støttes vil jeg tro, http://ark.intel.com/products/series/33905#@All Men serien støtter ikke Hyper-Threading så max antall kjerner du ender opp med er 8 som best kan folde smp-prosjekter (ikke BA). De beste av disse har en TDP på 150W som vil utgjøre et voldsomt strømsluk sett i forhold til den PPD du får tilbake. Serien er av Intel gitt status EOL og hadde sitt siste produksjonsår i 2008. Jeg ville ikke satset / eller brukt kronene på dette, men som smp-server vil den jo fungere helt greit hvis det er forskningen alene man hensyntar!
Du finner oppgraderings-sett som inkluderer 2 x CPU ++ for under 1000 kroner på ebay, eksempel: http://www.ebay.com/sch/CPUs-Processors-/164/m.html?item=161278087103&_ssn=friendly-computers-usa&_dcat=164&Number%2520of%2520Cores=4&rt=nc og pr. enhet her http://www.ebay.com/ctg/Intel-Xeon-E5450-3-GHz-Quad-Core-EU80574KJ080N-Processor-/74066102
Endret av -alias-
Her på min.
Det var visst ikke nødvendig, tolket bare feilmeldingene dine som om de var fra loggen noe de ikke var.
Synes det var kort med info i den og trudde da at en større logg hadde gjort susen,men det var vel tekst du hadde hentet fra ppd-siden.
Ah.. der ja. Okey jeg skjønte at det var særs sjeldent en trengte å se videre ned i loggnivåene. Ja jeg hentet ppd og wu fra stat sida. Generelt tenkte jeg det var merkelig med 20 wu og 0 poeng, men det kan vel oppstå(?). Tror det var når gpu stod som ready og hadde feilmld "GPU_MEMTEST_ERROR" at den lasta ned oppgaver mange ganger.
+50 kjører jeg på de fleste bare for en boost, men halvparten av kortene har høyere pga superclocked, oc ol.
core15 sliter mer med bad work på oc en core 17.
Edit: Ser jeg ligger på 3plass i brukere som leverer mest pr dag, alias ligger på 3plass over brukere som har levert mest totalt. (aktive brukere idag)
Endret av War
Takk takk! :3
Hvor mye PPD tror du disse to cpu'ene ville gitt? Og holder 4GB RAM?
Ser iallefall at jeg kanskje bør satse på nye kjølere også i disse varme sommerdager, eventuelt flytte alle serverene ned til garasjen hvor det er godt og kaldt - samt ventilasjon.
Takk takk! :3
Vanskelig å si hvor mye PPD de vil gi siden jeg ikke kan huske å ha sett noen folde med dem, men de bør vel kunne sammenlignes med ytelsen til 1 stk. i7-2600K 3.4GHz, hvor sistnevnte yter ganske mye bedre enn foreks. 2 stk. Xeon 5450 3.0GHz.. Ut fra sammenligningen tipper jeg du da får noe mellom 15 - 20K PPD og et strømforbruk fra veggen på omkring 350W, og det er dårlig butikk spør du meg. i7-2600K OC til 4.6GHz har et strømforbruk fra veggen på omkring 200W og gir mellom 25 - 35K PPD med standard smp. Jeg solgte 4 - 5 stk. i7-2600K for 500 pr. stk. da den første omleggingen av BA kom tidlig i 2012. Før denne omleggingen kunne i7-2600K gi omkring 40 - 80K PPD ved å fake antall kjerner/tråder fra 8 til 12 og folde den gamle 69xx BA-serien, avhengig av type WU. Tror jeg har noen gamle bilder ett eller annet sted hvis jeg leter.
post-53451-0-73308000-1398012787_thumb.jpg post-53451-0-74279400-1398013244_thumb.jpg
Klikk på bildene for å forstørre!
4GB RAM vil holde godt tror jeg, hvis hver CPU får 2GB.
Endret av -alias-
Takk takk! :3
Vel, tror ikke jeg satser på det. Kan få mer PPD med alt annet til 2000 kroner :p
Uff, har ikke HW eller penger til å folde. Får bli noe i fremtiden en gang..
:thumbup:
Funnet en plass du skal varme opp eller skal den stå ved kontoret?
Den skal stå på loft som ikke er i bruk, så det blir tapt varme fra denne maskinen. Men det spiller liten trille nå i sommersesongen, da det blir varmt nok med de maskinene som allerede står på :D Den kan flyttes ned om varmen trengs. Det blir en kamp om amperene på denne kursen, men jeg har målt litt på watt fra vegguttak.
edit: jeg er foresten overasket over hvor lite kreditt det er å kjøre i7-2600k nå om dagen, før låg jeg oppmot 50k på denne. Nå ser jeg ikke over 22k. Dette er på kontor pcen.
edit2: Noen som vet om et bra wireless kort / usb adapter. Har svært lavt signal der jeg har planer om å plassere en pc på 2.4GHz hjemmenettet.
Endret av Crawler123
Det går uansett om det er samme sikringskap, men da resuseres evt hastigheten bare.
Er boden i samme hus ol, eller blir kabel mye styr?
Nå eller når du skaffer deg en wifi-pinne så last ned inSSIDer på en laptop og se på signalkurven ved routeren mens du går til loftet.
Da ser du hvordan det blir ca og om det er mulig.
Finnes jo også pci-x-wifi-kort som har antennene bak evt forlenget med kabel også.
Alternativ X er jo å koble en gammer router med dhcp disablet i routeren og sette ny ssid fra den og sette den et par rom nærmere loftet om det skull være svake signal, evt en vegg-repeater.
Det er ikke samme sikringsskap. Boden er i eget hus. Kabel er uaktuelt, må bli wifi eller 4g.
Har testet signalkurven og ligger på rundt -80/-90 dBm, får ustabilt nettverk når jeg tester med mobil på stedet. Har nettopp satt opp ny hovudruter.
Har vært inne på tanken om repeater, men er usikker på effekten av det, i og med at routeren står nesten ideelt plassert mtp signalrekkevidden dithen. Derfor har jeg lurt på bare en skikkelig mottaker, og evt. med egen kablet antenne.
Vet ikke om dere har hatt oppe følgende til diskusjon tidligere, så jeg hiver meg på en post.
Det jeg lurer på er om dere bruker noen smarte programmer til pc og mobil for overvåking av oppetid og temperatur på ulike rigger. Evt andre smarte måleinstrument og viktigheter. For min egendel merker jeg nå med flere pcer som står på døgnet rundt at noe overvåking er viktig. Spesielt temperatur og "Hallo er du frisk og oppe og går?"
Jeg fant en fin app til android som heter "Ping Host". Den gir meg lyd om noen pcer faller ut av en eller annen grunn.
Jeg er fortsatt på let etter en god temp overvåking. Både romtemp og samleplass for alle viktige hardware temp.
Pc-programmer:
- Hfm. net (statestikk)
App:
- Ping Host (overvåke oppetid)
Edit: Jeg laget en ny tråd ang. --> LINK
