Er dette riktig oppsett av GPU, CPU og aiiinitet?
Configure folding slot GPU:
open-index = -1
cuda-index = -1
Name = client-type
Value = beta
Configure folding slot CPU:
open-index = -1
cuda-index = -1
Name =
Value =
Prossessor affinitet
Hvilke prossessorer kan				 Hvilke prossessorer kan
kjøre FahCore_a4.exe *32?			 kjøre FahCore_15.exe *32
N Prossessor  0 (node 0)			 J Prossessor 0 (node 0)
N Prossessor  1 (node 0)			 J Prossessor 1 (node 0)
N Prossessor  2 (node 0)			 J Prossessor 2 (node 0)
N Prossessor  3 (node 0)			 J Prossessor 3 (node 0)
N Prossessor  4 (node 0)			 J Prossessor 4 (node 0)
N Prossessor  5 (node 0)			 J Prossessor 5 (node 0)
N Prossessor  6 (node 0)			 J Prossessor 6 (node 0)
N Prossessor  7 (node 0)			 J Prossessor 7 (node 0)
N Prossessor  8 (node 0)			 J Prossessor 8 (node 0)
N Prossessor  9 (node 0)			 J Prossessor 9 (node 0)
N Prossessor 10 (node 0) 			 J Prossessor 10 (node 0)
N Prossessor 11 (node 0)			 J Prossessor 11 (node 0)
N Prossessor 12 (node 0)			 J Prossessor 12 (node 0)
N Prossessor 13 (node 0)			 J Prossessor 13 (node 0)
N Prossessor 14 (node 0)			 J Prossessor 14 (node 0)
J Prossessor 15 (node 0)			 N Prossessor 15 (node 0)
N Prossessor 0 (node 1)				 J Prossessor 0 (node 1)
N Prossessor 1 (node 1)				 J Prossessor 1 (node 1)
N Prossessor 2 (node 1)				 J Prossessor 2 (node 1)
N Prossessor 3 (node 1)				 J Prossessor 3 (node 1)
N Prossessor 4 (node 1)				 J Prossessor 4 (node 1)
N Prossessor 5 (node 1)				 J Prossessor 5 (node 1)
N Prossessor 6 (node 1)				 J Prossessor 6 (node 1)
N Prossessor 7 (node 1)				 J Prossessor 7 (node 1)
N Prossessor 8 (node 1)				 J Prossessor 8 (node 1)
N Prossessor 9 (node 1)				 J Prossessor 9 (node 1)
N Prossessor 10 (node 1)			 J Prossessor 10 (node 1)
N Prossessor 11 (node 1)			 J Prossessor 11 (node 1)
N Prossessor 12 (node 1)			 J Prossessor 12 (node 1)
N Prossessor 13 (node 1)			 J Prossessor 13 (node 1)
N Prossessor 14 (node 1)			 J Prossessor 14 (node 1)
J Prossessor 15 (node 1)			 N Prossessor 15 (node 1)
open-index = -1
cuda-index = -1
Name = client-type
Value = beta
open-index = -1
cuda-index = -1
Name =
Value =
Hvor mange kjerner har du totalt? 16? I mine øyne ville det kanskje være bedre å kjøre a4 på en kjerne som ikke blir brukt, men ikke stol helt på meg før noen andre har svart ^^
Det er det jeg har forsøkt i oppsettet over, men får regelmessige crash på skjermkortdriveren.
Mulig jeg misforstår her, men du har en SMP slot som kjører SMP:14 og ønsker å binde denne til 14 kjerner (altså Fahcore_a4.exe/Fahcore_a3.exe) og la skjermkortet (Fahcore_15.exe/Fahcore17.exe siden du har beta) bli bundet til de to resterende?
What, kan man folde i SLI?
Du må fortsatt ha en klient (edit: en slot) per kort, men det gjør ikke noe om kortene står i SLI :) Det ble prøvd under intern beta-testing av FAHCore17, men gå for dårlig skalering. Kanskje senere ;) Det ser ut som FAHBench støtter CF/SLI 54370.png (http://www.anandtech.com/show/6915/amd-radeon-hd-7990-review-7990-gets-official/15) Endret av Arve1234567890
Du må fortsatt ha en klient per kort, men det gjør ikke noe om kortene står i SLI :) Det ble prøvd under intern beta-testing av FAHCore17, men gå for dårlig skalering. Kanskje senere ;) Det ser ut som FAHBench støtter CF/SLI
(http://www.anandtech...ets-official/15)
Huff, ja. Hadde vært stilig med skikkelig skalering da, da blir det virkelig snakk om bonus-ppd!
Jeg må si at jeg er imponert over Titan SLI når de folder, normalt ligger de på 310K til 325K PPD med P8900. :eek:Hadde ikke trodd at det skulle bli så stor forskjell på GTX 580 til GTX Titan.
2 x Titan + kabinett, PSU, etc som hører med representerer vel omkring 20K kroner. For den prisen får man en 4P G34 som i snitt gir PPD på omkring 450 - 550K. Strømforbruk ca. 500 - 600W, litt avhengig av hva man velger.
Edit: Leste helt nylig at nå selges E5-4650 chipper for så lite som $475 pr. enhet. En slik rigg vil da ikke koste mer enn 25K og den gir mellom 875 - 1000K for 675W.
Endret av -alias-
2 x Titan + kabinett, PSU, etc som hører med representerer vel omkring 20K kroner. For den prisen får man en 4P G34 som i snitt gir PPD på omkring 450K. Strømforbruk ca. 500 - 600W, litt avhengig av hva man velger.
Bah, kabinett og alt det der hadde jeg fra tidligere, så ble kun 2 x Titan til ca 14K kroner. Dessuten driver jeg med mer enn kun folding, blir myyyye spilling også. Og strømforbruket blir nok ikke så mye over 600W selv med 2 x Titan da jeg kun kjører GPU folding.
Endret av Chavalito
2x titan til spilling :p Da har du vel skjerm over hele veggen antar jeg :)
Niks, en liten 27" med 2560x1440 er alt jeg har, for øyeblikket. Forresten team Hardware har passert 4 miiliarder poeng i F@H. Ikke verst det. :w00t:
Endret av Chavalito
Leste bittelitt feil og husket ganske feil.
Hvis du prøver å kjøre a4 (AKA CPU folding) på prosessor 0-14 thread 0 og 1, og setter _15 (GPU) til prosessor 15, thread 0 og 1 så kanskje det funker bedre. Du må nesten prøve deg fram..
Hva slags GPU og CPU'er har du?
Noen som har noen tips til hvordan jeg kan få Ubuntu maskinen min inn i HFM.net på en Windows maskin?
Bruker V7 på alle maskiner, er på samme nettverk.
For min del var oppsettet helt likt som på en Windows-maskin. Måtte bare huske å restarte klienten etter konfiggen. sudo /etc/init.d/FAHclient restart eller bare boote maskina.
Komplett hardware i profilen min, mer 1 stk titan og 2 stk xeon cpu.
Dvs at jeg er inne på rett oppsett. Burde fått mer en 60000 ppd på dette oppsettet.
Du burde ha ca 120K til 160K med P8900 med 1 stk Titan, pluss CPU'ene dine. Med P7663 ca 65K med Titan, tror det var det eller var det ca 135K?
Jeg kjører kun GPU folding og ligger på ca 130K til 165K pr Titan kort, totalt opptil 330K har jeg sett.
Endret av Chavalito
