Hvordan lage CS-film i CS 1.5 og CS 1.6
  • 1 måned senere...
her er forklaring på noen av programmene... det står på engelsk men.. dere kan vel det :p
Video Mach. It is a very easy program to use.
Once you have downloaded it, load Video Mach up. Go to "File" "Open". Select all of bitmaps
(from first to last) and click open. If none of them get imported, try selecting less at one time.
Once you have all of the bitmaps imported, you can go through and delete and move all the
scenes you want.
Now that you have all of the bitmaps in the order you want, click on the little disk icon above
the middle box. First Create an output name, and select avi in the dropdown box (it might do
that automatically though). Then click on the video tab. Find the Frame Rate box, and unselect
"automatic", then unselect "keep original duration". I suggest using 15 fps (standard avi format).
Now go to "Format Options". Video Mach already has some compression, but if you want to
cut the file size in half, you can use DivX encoding. You'll want to use The "High-motion" encoding.
In order for you to do this, and for you and others to view it, you will need the "DivX Codec",
which you can find at www.divx.com. Click OK to save the changes. Now click on the lighting
bolt above the second box, it will start to create the movie. Once that is done you have a playable
avi movie.
Virtual Dub:
Because there's no sound in the avi, I would suggest using a program called Virtual Dub.With this
freeware you're able to open your previously saved avi and mix in a wav file (if you desire to use
an mp3 you must first convert it into wav format first). When you've opened the video, select
"Audio" and choose "WAV Audio" to locate your file. Now select "Video" "Compression" and be
sure that it is on DIVX Fast Motion (if you previously chose that in Video Mach).
Now simply go to "File" "Save As AVI" and you're done.
har en måte å løse den store plassen det tar å lagre filmen.. her kan u få 50mb til å bli 1mb..
etter du har lagd en film, tar du den inn i videomach.
gå inn på disket ikonet midt på skjermen, så velger du avi.
så trykker du på
så codec settings på fanekortet video.
så velger du DivX.
da tar den MYE mindre plass, og det blir litt dårligere kvalitet...
håper dere får det til :thumbup:
  • 2 uker senere...
Det er fordi VideoMach ikke støtter .dem filmer, så det du gjør er at du konverterer .dem fila til en .avi fil ol. (Hvordan du gjør det finner du svar på i guiden wink.gif )
greit nok det men jeg finner ikke vor i guiden du har skrevet hvordan jeg jør dete.. :blush:
gadd ikke å lese gjennom alt her, så det kan hende dette er sagt før.. men hvis jeg skal lage film, så kobler jeg pcen til tven og tven til videokameraet mitt. har ikke brukt det på cs, men på Joint ops. er resultatet knallgodt. Etter at du har filmet redigerer du bare i et redigeringsprog. på pcen(adobe premiere, avid eller pinnacle ol. hvis det er det du har for hånden..) thumbup.gif thumbup.gif
hvordan gjør du dette??? :blush:
aLLi[-' date=30/06/2005 : 01:01] greit nok det men jeg finner ikke vor i guiden du har skrevet hvordan jeg jør dete.. :blush:
Altså:
Når du spiller CS, så tar du opp en .dem fil ved å skrive "record demonavn" i console.
.dem filen kan IKKE konverteres til .avi eller film som kan spilles av i Mediaplayer uten å ha vært til "behandling" i CS.
To måter:
Last ned FRAPS 1.9D fra www.fraps.com
Start opp fraps og velg 30 fps og sjekk at "hotkey" og F9.
Start CS -> Skriv "viewdemo demonavn" i console. Når du har kommet til et punkt i filmen din i CS som du gjerne vil ha til .avi så trykker du på F9, og på F9 en gang til når du er ferdig. Da er snutten blitt lagret som .avi i fraps installasjonsmappe.
Du kan også lage 1000-vis av .bmp bilder og konvertere til .avi med et program, men det vil ikke jeg anbefale til "noobs" pga det er så mye slit. (Min mening)
Er ikke helt sikker på hvordan du gjør det, men det står i guiden. (noe med startmovie 30 og endmovie elns)
Til slutt: Fraps 1.9D er en GAMMEL versjon som egentlig er forferdelig dårlig. Jeg har fullversjonen og den er mye bedre. Du får med lyd, bedre oppløsning og en tanke bedre "kompresjon" av "raw" .avi fila di. (Det er jo ikke raw når det er komprimert)
Mulig jeg har svart på feil spørsmål men det får så være...
Lykke til!
Men, FRAPS 1,9D ligger ikke på hjemme siden men det ligger en ny versjon der nemlig: 2.6.1 :cry: og når jeg trykker F9 tar den bare opp noen få sekunder :(
  • 3 uker senere...
Hvis du har Frags 99 da kan du lage film.....Da kan du f.eks. skrive på 1,6; Record 26( eller 99, 35, 67, osv.) Da begyner det og ta opp....Da skriver du "stop" når du vil stoppe filmen..... Også kan du redigere etterpå.......Skjønner?????
  • 3 uker senere...
  • 3 uker senere...
  • 3 uker senere...
