Fordeler med uberbios.
Fordeler med Uberbios er mange .
Her er beskrivelsene av uber endringer for A7N8X-Deluxe versjon 1.x og versjon 2.0
Uber Bios 1007 For A7N8X-Deluxe v1.04 - 1.06
Thanks for downloading my Asus A7N8X Deluxe bios mod.
Its based on the Asus A7N8X-Deluxe 1007 final bios.
Its for the A7N8X-Deluxe v1.04 - 1.06 only, and not for use in v2.0 mobos
The latest versions of this bios are always availavble in the Asus forums on www.nforcershq.com
These are based on the Asus release notes
Change log :-
1) Update SATA ROM to 4.2.15
2) Improve system stability with Hynix and PSC memory modules
3) Added PCI latency option
OPtions in this Uber bios release
1)This revision has more AGP voltage and Q-fan options to select.
2)There are also more options for the UART2 connector like 'smart card' and 'ASKIR'.
3)Also the AUTO mode for the printer port IO/IRQ allocation has been made selectable.
4)S3(STR) is now selectable for option 'ACPI Suspend to RAM'.
5)Additional Power On By PS/2 Keyboard/Power On By PS/2 Mouse options are available.
6)2.9V is now available in the DDR Reference Voltage selection choices.
7)1.8V is now available in the AGP VDDQ Voltage selection choices.
Flash this like you would the normal Asus supplied bios.
Here is a list of what I re-enable that Asus have hidden form the users.
Legacy Diskette
Video
CHIP Voltage Control
OnChip IDE Channel
Primary Master
Primary Slave
Primary Master
Primary Slave
OnChip IDE Channel
Secondary Master
Secondary Slave
Secondary Master
Secondary Slave
IDE Prefetch Mode
IDE HDD Block Mode
ACPI function
Power Management
HDD Power Down
Reset Configuration
MPS Version Contol
Small Logo(EPA)
Machine MAC(NV)
MAC(NV) Address
KB Power ON Pass
Hot Key Power ON
UR2 Duplex Mode
For definitions for most of these options visit the bios guide at
http://www.rojakpot.com/Speed_Demonz/BIOS_...Guide_Index.htm
Have fun!
- Demoulous
Legal disclaimer:-
I take NO RESPONSIBILITY FOR YOU FRYING YOUR MOBO WITH THIS!
In fact I take no responsibility for anything you do at all :D
Uber Bios 1007 for A7N8X Deluxe V2.0
Thanks for downloading my Asus 'A7N8X Deluxe v2.0' bios mod.
Its based on the 'Asus A7N8X-Deluxe V2.0' 1007 final bios.
The latest versions of this bios are always available in the Asus forums on www.nforcershq.com
Also from my site @ http://homepage.ntlworld.com/michael.mcclay/ <- home of the Uber bios project.
Change log :-
1) This revision has more Q-fan options to select.
2) There are also more options for the UART2 connector like 'smart card' and 'ASKIR'.
3) Also the AUTO mode for the printer port IO/IRQ allocation has been made selectable.
4) S3(STR) is now selectable for option 'ACPI Suspend to RAM'.
5) Additional Power On By PS/2 Keyboard/Power On By PS/2 Mouse options are available.
6) DDR Reference Voltage selection choices now range from 2.6V - 2.9V.
7) AGP VDDQ Voltage selection choices now range from 1.5v - 1.8V.
8) CHIP Voltage Control selection choices now range from 1.6V - 1.9V
Legacy Diskette
Video
OnChip IDE Channel
Primary Master
Primary Slave
Primary Master
Primary Slave
OnChip IDE Channel
Secondary Master
Secondary Slave
Secondary Master
Secondary Slave
IDE Prefetch Mode
IDE HDD Block Mode
ACPI function
Power Management
HDD Power Down
Reset Configuration
MPS Version Control
Small Logo(EPA)
Machine MAC(NV)
MAC(NV) Address
KB Power ON Pass
Hot Key Power ON
UR2 Duplex Mode
Have fun!
- Demoulous
Legal disclaimer:-
http://www.nforcershq.com/forum/viewtopic.php?t=15505
Takk for den :thumbup:
Edit: har støtt på et "lite" problem her! Det ser nemlig ut til at jeg ikke får flashet biosen med beta-filer :cry: Eller, vet ikke om det har noe med det å gjøre, men de funker hvertfall ikke! Noen som vet hva dette kan bety? (sorry for off-topic i min egen topic)
Endret av ManagHead
uberbiosene jeg kikket på har en autoexec.bat fil .
Så det skal kun være å plukke riktig uberbios .
Pakke den ut til en formattert floppy som har blitt
formattert som startup disk og overskrive autoexec.bat
med den som er i uberbios zip filen.
Og kopiere inn awdflash.exe til den .
Boote pc'n med floppy som 1'st boot device ,så
går det av seg selv.
Hva du mener med "autoexec.bat fil"?
Prøvde et par ganger nå og.. gang nr1: fikk startet awdflash, men det kom opp at filnamnet jeg skrev ikke fantes på disketten
gang nr2: forandret filnavnet til bare 1007 og startet opp igjen. Da fikk jeg skrevet inn alt, men så kom det opp at filen ikke "passet" med systemet eller noe sånt :mad:
Hvilken versjon ASUS kort er det du har da :roll:
Har du A7N8X Deluxe Rev 2.00 :
Skal du ha denne:
http://homepage.ntlworld.com/michael.mccla...7Dv2.0-Uber.rar
Denne må pakkes ut med winrar under windows , den inneholder 3 filer :
readme.txt
autoexec.bat
uberd_r2.bin
Disse 3 filene legger du på disketten som er formattert som startup disk.
Så flash programmet Awdflash v8.24b :
ftp://ftp.asus.com.tw/pub/ASUS/mb/socka/n...xe/awdflash.zip
Pakkes ut i windows og kopieres til disketten .
Har du A7N8X Deluxe Rev 1.xx :
Skal du ha denne biosen :
http://homepage.ntlworld.com/michael.mccla.../1007D-Uber.rar
readme.txt
autoexec.bat
uberd_r1.bin
Endret av syar2003
Det står Uber bios 1007 når jeg starter opp å sånt hvertfall, å så kan jeg justere litt flere ting, men jeg gjorde ikke noe såesielt da jeg flashet.. det var ferdig utfylt så jeg måtte bare vente til det var ferdig, så da ordnet det seg selv det da sikkert :)
Takk igjen!
