alex100 Skrevet 1. juni 2004 Rapporter Del Skrevet 1. juni 2004 Hei. Er det mulig at jeg kan legge til støtte for Æ, Ø og Å i dette scriptet her? <?php // Free script to search your site // Copyright 2004, Digital Point Solutions // version 1.0 - January 22, 2004 // // Feel free to format the results however you see fit, the only thing we ask is that you leave a link to us in case others would like to add it to their site. // Links will be checked, and removal of the link could result it your website being blocked from using the service. // Other than that, have fun! :) - Shawn // Set your parameters here $key = "12345678901234567"; // This is your Google API key, if you don't have one, get one for free at: // https://www.google.com/accounts/NewAccount?continue=http://api.google.com/createkey&followup=http://api.google.com/createkey $site = "www.eksempel.no"; // This is the site you wish to search within // If Google has you indexed without "www.", don't specify "www." within your site URL. // 'http://' is *not* required in the site variable. // Examples: // www.cnn.com search within www.cnn.com // www.cnn.com/tech/ search within www.cnn.com/tech/ // // You can also leave it blank to search the entire web // Colors $color_border = "#474747"; $color_title = "#6374BC"; $color_odd_results = "#D9DCE6"; $color_even_results = "#F0F0F0"; $q = stripslashes ($HTTP_GET_VARS['q']); $start = 0 + $HTTP_GET_VARS['start']; include ("header.php"); // Edit this file to make it easy to fit into your site's look and feel ini_set ("allow_url_fopen", "1"); if (!ini_get ("allow_url_fopen")) echo '<FONT COLOR=RED><B>Sorry, this PHP configuration does not allow for usage of <A HREF="http://www.php.net/manual/en/ref.filesystem.php#ini.allow-url-fopen" TARGET="_blank">fopen()</A>, which is required for this search engine script.</B></FONT><P>'; // Let's get the results $handle = @fopen ("http://search.digitalpoint.com/?q=" . urlencode ($q) . "&key=" . urlencode ($key) . "&site=" . urlencode ($site) . "&start=" . min (990, $start), "r"); while (!feof ($handle) && $handle) { $line .= fgets ($handle, 1024); } fclose($handle); eval ('$urls = ' . $line . ';'); echo '<TABLE BGCOLOR=' . $color_border . ' CELLSPACING=1 CELLPADDING=0><TR><TD><TABLE BGCOLOR=' . $color_odd_results . ' border=0 CELLSPACING=0 CELLPADDING=6><TR BGCOLOR=' . $color_title . '><TH COLSPAN=3>'; echo '<TABLE border=0 WIDTH=100%><TR><TH WIDTH=80 ALIGN=CENTER VALIGN=MIDDLE><FONT SIZE=-1><A HREF="http://www.digitalpoint.com/tools/search/">Add Search<BR>To Your Site</A></FONT></TH><TH ALIGN=CENTER>'; echo ' '; if ($urls['end'] - $urls['start'] < 9) $urls['results'] = $urls['end']; if ($urls['results'] > 10) { if ($start < 40) { $x = 0; } else { $x = round (max (0, min ($start - 40, $urls['results'] - 96) / 10)); } for ($i = $x; $i < $x + 10; $i++) { if ($i != round ($start / 10)) { echo '<A HREF="searchresult.php?q=' . urlencode($q) . '&start=' . ($i * 10) . '">' . ($i + 1) . "</A> "; } else { echo ($i + 1) . " "; } if (max (10, ($i + 1) * 10) >= $urls['results']) break; } echo '<BR>'; } echo '<FONT SIZE=+1>Estimated Total Results: ' . number_format ($urls['results']) . '</FONT></TH</TR>'; echo '</TH><TH WIDTH=80> </TH></TR></TABLE>'; $rownum = 1; $start = $urls['start']; if ($urls['error']) { echo "<TR COLSPAN=3><TD><BR><FONT SIZE=-1 COLOR=RED>" . $urls['error'] . "</FONT></TD></TR>"; } else { foreach ($urls['urls'] as $key => $url) { $rownum++; echo "<TR"; if ($rownum % 2 == 1) echo ' BGCOLOR=' . $color_even_results; echo "><TH ALIGN=RIGHT WIDTH=35>#" . ($key + $start) . ": </TH><TD><A HREF=\"$url\">" . $urls['titles'][$key] . "</A><BR>" . $urls['snippet'][$key] . "<BR><FONT SIZE=-1> <B>$url</B></FONT></TD><TD> </TD></TR>"; } } echo '</TABLE></TD></TR></TABLE>'; include ("footer.php"); ?> Som dere ser her ser det litt merkelig ut uten æ,ø og å: http://213.184.216.249/hf/searchresult.php Lenke til kommentar
LoS Skrevet 1. juni 2004 Rapporter Del Skrevet 1. juni 2004 Når jeg ser på siden din, så har google eller no byttet charset til utf-8, noe som tydeligvis ikke funker med æøå. Og jeg finner verken charset eller utf-8 i koden din, så kanskje det er google sin skyld? Lenke til kommentar
alex100 Skrevet 1. juni 2004 Forfatter Rapporter Del Skrevet 1. juni 2004 Når jeg ser på siden din, så har google eller no byttet charset til utf-8, noe som tydeligvis ikke funker med æøå. Og jeg finner verken charset eller utf-8 i koden din, så kanskje det er google sin skyld? Det er nok Google ja. Er det ikke noe jeg kan gjøre noe med da eller? Lenke til kommentar
LoS Skrevet 1. juni 2004 Rapporter Del Skrevet 1. juni 2004 Du kan jo str_replace(); det ut av stringen som kommer ut da. Veit lite om hvordan det funker det der, men str_replace(); fikser ihvertfall den biffen Lenke til kommentar
alex100 Skrevet 1. juni 2004 Forfatter Rapporter Del Skrevet 1. juni 2004 (endret) Du kan jo str_replace(); det ut av stringen som kommer ut da.Veit lite om hvordan det funker det der, men str_replace(); fikser ihvertfall den biffen Jeg er nok ikke helt med her. Tror jeg trenger det med teskjei Hvor og hva skal jeg sette inn? Endret 1. juni 2004 av alex100 Lenke til kommentar
LoS Skrevet 1. juni 2004 Rapporter Del Skrevet 1. juni 2004 (endret) Tror jeg hadde testet å bytte ut: $q = stripslashes ($HTTP_GET_VARS['q']); med: $q = str_replace("<meta HTTP-EQUIV=\"content-type\" CONTENT=\"text/html; charset=UTF-8\">", "", stripslashes($HTTP_GET_VARS['q'])); Dette er på ingen måte testet, men kom nå fram til det av en eller annen grunn edit: ble kanskje feil. Endret 2. juni 2004 av LoS Lenke til kommentar
alex100 Skrevet 2. juni 2004 Forfatter Rapporter Del Skrevet 2. juni 2004 Funket ikke Lenke til kommentar
LoS Skrevet 2. juni 2004 Rapporter Del Skrevet 2. juni 2004 (endret) Test litt rundt på andre variabler, det er ihvertfall på den måten det kan gjøres. eventuelt legge hele greia i en funksjon og heller str_replace hele funksjonen. Endret 2. juni 2004 av LoS Lenke til kommentar
alex100 Skrevet 2. juni 2004 Forfatter Rapporter Del Skrevet 2. juni 2004 Hjelper dette her noe? Fant det på Google siden om API key'er: http://www.google.com/apis/api_faq.html#tech26 26. How do I make queries in languages other than English? The Google Web APIs support requests and responses in UTF-8, allowing you to make requests in all of the world's languages. The original release included parameters <ie> and <oe> for inputEncoding and outputEncoding. These parameters are no longer used and will be removed in a future release. The APIs still do not always return complete results for Chinese, Japanese, and Korean; we are working to remedy this issue. Lenke til kommentar
LoS Skrevet 2. juni 2004 Rapporter Del Skrevet 2. juni 2004 I følge den der så har ikke denne støtte for annen charset enn utf-8, og det skal liksom komme i en ny versjon. Kunne jo ha testet å fiksa det for deg, men jeg har ingen API key eller hva det nå er Prøv å legg til f.eks function sok($HTTP_GET_VARS['q'], $HTTP_GET_VARS['start']) { på førsten og en } på slutten og bruk str_replace("<meta HTTP-EQUIV=\"content-type\" CONTENT=\"text/html; charset=UTF-8\">", "", sok($HTTP_GET_VARS['q'], $HTTP_GET_VARS['start'])); For å kalle opp søkefunksjonen. Lenke til kommentar
