PowerVR's nye kort
Blir kortet AGP eller PCI-express
Det jeg har hørt hittil er først og fremst AGP, men de vil nok komme med en PCI-X etterhvert.
Kom over en liste med "specs" som vistnok skal være rimelig troverdig. Enkelte har slaktet den, men mine kilder sier at den er rimelig grei.
Max Texture Height 4096 px
Max Texture Width 4096 px
Max Active Hardware Lights 8
Max Texture Blending Stages 8
Textures In Single Pass 16
Fixed Function
Max Texture Coordinates 8
Max Vertex Blend Matrices 98
Pixel Shader Version 3.0
Vertex Shader Version 3.0
DirectX Version Hardware Support 9.0C
Max User Clipping Planes 8
Memory And Core Clock 375 MHz synchro
VGA Core Codename PowerVR S5A2
Total Local Video Memory 256 MB
Total Local Texture Memory 254 MB
Max AGP Memory 256 MB
Rendering Bit Depths 16, 32
Z-Buffer Bit Depths 16
Direct3D Device Features
Additive Texture Blending Supported
AGP Texturing Supported
Anisotropic Filtering Supported
Bilinear Filtering Supported
Cubic Environment Mapping Supported
Cubic Filtering Supported
Decal-Alpha Texture Blending Supported
Decal Texture Blending Supported
Directional Lights Supported
DirectX Texture Compression Supported
DirectX Volumetric Texture Compression Supported
Dithering Supported
Dot3 Texture Blending Supported
Dynamic Textures Not Supported
Edge Antialiasing Supported
Environmental Bump Mapping Supported
Environmental Bump Mapping + Luminance Supported
Factor Alpha Blending Supported
Geometric Hidden-Surface Removal Supported
Guard Band Supported
Hardware Scene Rasterization Supported
Hardware Transform & Lighting Supported
Legacy Depth Bias Supported
Mipmap LOD Bias Adjustments Supported
Mipmapped Cube Textures Supported
Mipmapped Volume Textures Supported
Modulate-Alpha Texture Blending Supported
Modulate Texture Blending Supported
Non-Square Textures Supported
N-Patches Supported
Perspective Texture Correction Supported
Point Lights Supported
Point Sampling Supported
Projective Textures Supported
Quintic Bezier Curves & B-Splines Not Supported
Range-Based Fog Supported
Rectangular & Triangular Patches Not Supported
Rendering In Windowed Mode Supported
Scissor Test Supported
Slope-Scale Based Depth Bias Supported
Specular Flat Shading Supported
Specular Gouraud Shading Supported
Specular Phong Shading Supported
Spherical Mapping Supported
Spot Lights Supported
Stencil Buffers Supported
Sub-Pixel Accuracy Supported
Table Fog Supported
Texture Alpha Blending Supported
Texture Clamping Supported
Texture Mirroring Supported
Texture Transparency Supported
Texture Wrapping Supported
Triangle Culling Not Supported
Trilinear Filtering Supported
Two-Sided Stencil Test Supported
Vertex Alpha Blending Supported
Vertex Tweening Supported
Z-Bias Supported
Z-Test Supported
W-Buffering Supported
Z-Based Fog Supported
Vertex Fog Supported
W-Based Fog Supported
Blir veldig spennende...
PowerVR har alltid brukt en meget spessiel måte å "rendre" bildet på.
En meget avansert HSR-metode.
Husker selv at jeg hadde et PowerVR kort for lenge siden... Matrox m3D, var en god konkurent til Voodoo 1 :yes:
Kyro kortene til PowerVR som var i samme prissegnent som GeForce 2 MX og slo i mange tilfeller både Radeon 256 og GeForce 2 GTS, men de hadde ikke T&L, noe som både ATi og nVidia brukte mot dem...
Jeg må si at jeg aldri har hørt om PowerVR før........
Så skal det si at det eneste jeg visste om skjermkort for 1 og et halvt år siden var at jeg hadde et 9700pro... :)
kom forresten over dette:
As a graphics processor developer, PowerVR has not released anything new since early 2001 and analysts of the industry rarely take this firm into the account when talking about prospects for the industry. However, PowerVR reminds the world about itself by releasing some pieces information leading to assume about its new products indirectly.
I 2001 var den forrige chippen lansert.
Hvordan lå den an i ytelse i forhold til nVidia, matrox og 3dfx da? (tar ikke med ati fordi de var vel ikke helt inne i high end markedet da?)
Endret av TDK
Hehehe, KYRO er nok før din tid i så fall...
Når det gjelder uttalelsen fra de analytikerne... De kjenner litt til grafikk-markedet, men har enda ikke forstått at MBX fra PowerVR mye bedre enn hva ATI og nvidia har sluppet på markedet (mobil-grafikk)., noe som gjør at jeg ville tatt den (og lignende andre) kommentaren med en klype salt.
Men når det gjelder KYRO...
Som Raptor sa, så var det et kort som prismessig var blant de billigste, men ytelsesmessig var mye mye bedre. Her[/url} er en test som viser at KYROen lå ikke så værst an til å være så billig. Og den har et ganske stort potensiale
This is not going to be the card for the power user that will sacrifice life and limb for that next upgrade. It is for the “Joe Six-pack” crowd that wants some decent performance that does not require you make a trip to the pawnshop. Also we were told that there will be eight manufacturers of this card so the competition on the price level should be fun to say the least.
Something that really gets me excited about the Power VR 3D technology is this. What do we get if we apply Tile Based Rendering to a 200MHz chipset? Maybe we will see that come to pass but it did not sound to be happening any time soon. I would certainly like to see Imagination and ST Micro make a run for the top spot though.
Her finner du en test fra Beyond3D som også går litt mer i dybden når det gjelder forskjellen i teknologi mellom KYRO og andre "vanlige" kort.
Når det gjelder Series 5, så er det veldig mange som har store forhåpninger til denne, da chip-familien vil også bl.a. bli brukt til å drive SEGAs nye arkade maskiner. Det eneste virkelige store spørsmålet er hvem (hvis noen) som vil produsere chipene og produsere kortene.
PowerVR er nemlig et firma som "selger" IP, og gjør ikke som ATI og nvidia (som begge er ansvarlige for å produsere kjernene til sine kort). Dermed er det en enda større kostnad å komme i gang med å selge PowerVR kort i forhold til ATI og nvidia. (Men det blir også billigere i det lengere løp)
