Narmacil Skrevet 29. mai 2004 Del Skrevet 29. mai 2004 Fant denne på et Camaro forum jeg frekventerer ofte: * One Top Fuel dragster 500 cubic inch Hemi engine makes more horsepower than the first 4 rows at the Daytona 500. * Under full throttle, a dragster engine consumes 1½ gallons of nitromethane per second; a fully loaded 747 consumes jet fuel at the same rate with 25% less energy being produced. * A stock Dodge Hemi V8 engine cannot produce enough power to drive the dragster supercharger. * With 3000 CFM of air being rammed in by the supercharger on overdrive, the fuel mixture is compressed into a near-solid form before ignition. Cylinders run on the verge of hydraulic lock at full throttle. * At the stoichiometric 1.7:1 air/fuel mixture for nitromethane the flame front temperature measures 7050 degrees F. * Nitromethane burns yellow. The spectacular white flame seen above the stacks at night is raw burning hydrogen, dissociated from atmospheric water vapor by the searing exhaust gases. * Dual magnetos supply 44 amps to each spark plug. This is the output of an arc welder in each cylinder. * Spark plug electrodes are totally consumed during a pass. After 1/2 way, the engine is dieseling from compression plus the glow of exhaust valves at 1400 degrees F. The engine can only be shut down by cutting the fuel flow. * If spark momentarily fails early in the run, unburned nitro builds up in the affected cylinders and then explodes with sufficient force to blow cylinder heads off the block in pieces or split the block in half. * In order to exceed 300 mph in 4.5 seconds dragsters must accelerate at an average of over 4G's. In order to reach 200 mph well before half-track, the launch acceleration approaches 8G's . * Dragsters reach over 300 miles per hour before you have completed reading this sentence. * Top Fuel Engines turn approximately 540 revolutions from light to light! * Including the burnout the engine must only survive 900 revolutions under load. * The red-line is actually quite high at 9500 rpm. * The Bottom Line; Assuming all the equipment is paid off, the crew worked for free, and for once NOTHING BLOWS UP, each run costs an estimated US $1,000.00 per second. The current Top Fuel dragster elapsed time record is 4.441 seconds for the quarter mile (10/05/03, Tony Schumacher). The top speed record is 333.00 mph (533 km/h) as measured over the last 66' of the run (09/28/03 Doug Kalitta). Putting all of this into perspective: You are driving the average $140,000 Lingenfelter "twin-turbo" powered Corvette Z06. Over a mile up the road, a Top Fuel dragster is staged and ready to launch down a quarter mile strip as you pass. You have the advantage of a flying start. You run the 'Vette hard up through the gears and blast across the starting line and past the dragster at an honest 200 mph. The 'tree' goes green for both of you at that moment. The dragster launches and starts after you. You keep your foot down hard, but you hear an incredibly brutal whine that sears your eardrums and within 3 seconds the dragster catches and passes you. He beats you to the finish line, a quarter mile away from where you just passed him. Think about it, from a standing start, the dragster had spotted you 200 mph and not only caught, but nearly blasted you off the road when he passed you within a mere 1320 foot long race course. That, folks, is acceleration. Lenke til kommentar
bjaa Skrevet 29. mai 2004 Del Skrevet 29. mai 2004 Masse tøffe fakta om top fuel dragstere det der, men det står ikke noe om hvor mye de forurenser Lenke til kommentar
Nichlas Skrevet 30. mai 2004 Del Skrevet 30. mai 2004 Masse tøffe fakta om top fuel dragstere det der, men det står ikke noe om hvor mye de forurenser Det er fordi ingen av oss har godt av å vite det Lenke til kommentar
eab Skrevet 12. juni 2004 Del Skrevet 12. juni 2004 jeg DRITER i hvor mye de forurenser. Dessuten er fact nr1 litt dårli, fordi daytona er en såkalt restrictorplate track.. bilene er strupa til ca 450hk. 8*450=3600hk Lenke til kommentar
Gisle Skrevet 15. juni 2004 Del Skrevet 15. juni 2004 Masse tøffe fakta om top fuel dragstere det der, men det står ikke noe om hvor mye de forurenser Å hjelpe meg! Tror du at nitrometan som eksploderer i nesten fast form, forurenser? Dette er eksplosjonsmotorer vi snakker om, ikke forbrenningsmotorer som står i alle andre biler, racerbiler, F1-biler, rallybiler og dragracere. Hvor mye forurenser 1.stk dynamit når den eksploderer, da? Hallo? Lenke til kommentar
bjaa Skrevet 20. juni 2004 Del Skrevet 20. juni 2004 Hva om jeg faktisk trur det da? Det jeg skrev var ment som et spørsmål, ikke som en faktasettning. Hallo? Lenke til kommentar
X-Fiesta Skrevet 20. juni 2004 Del Skrevet 20. juni 2004 Dette er eksplosjonsmotorer vi snakker om, ikke forbrenningsmotorer som står i alle andre biler, racerbiler, F1-biler, rallybiler og dragracere. Hvor mye forurenser 1.stk dynamit når den eksploderer, da? Hallo? Det er nok eksplosjonsmotorer i ALLE biler,bortset fra elbiler da... Bensin-, Diesel-, eller Propan-, og alle andre forbrenningsmotorer er alle eksplosjonsmotorer! Og ja, jeg tror en 1.stk dynamit forurenser, akkurat som alt annet som brenner(eksplosjon er jo bare en hurtig forbrenning)... Lenke til kommentar
Opus Skrevet 20. juni 2004 Del Skrevet 20. juni 2004 Med mindre den går på ren hydrogen, er det nok forurensing av ett eller annet slag. Lenke til kommentar
eab Skrevet 20. juni 2004 Del Skrevet 20. juni 2004 http://auto.howstuffworks.com/question642.htm CH3NO2 er fomelen for nitrometan. Jeg regner med det vil dannes NO- og CO-gasser, som regnes som forurensing. Det står også forklart at en motor som går på slikt drivstoff fungerer på samme måte som en vilken somhelst annen ottomotor. Lenke til kommentar
