Kryptere passord...?
Hei...
Jeg har litt problemer med at andre kommer inn og endrer poll etc. pga. at jeg ikke kan kryptere passordene mine... er det mulig å få kryptert de slik at det ikke bare er å hente ned PHP-fila og leite etter det... har prøvd md5, men får det ikke til å virke...
<?php
$password = '699e8cc17ee4295382d101b3905722a1';
   if (!ini_get ("register_globals"))
   {//globals turned Off
   extract($HTTP_GET_VARS);
   extract($HTTP_POST_VARS);
   extract($HTTP_COOKIE_VARS);
   extract($HTTP_ENV_VARS);
   extract($HTTP_SERVER_VARS);
if(!isset($passwd) or md5($passwd)!=$password){
echo "<table width=\"303\" border=\"0\" cellspacing=\"1\" cellpadding=\"0\" height=\"169\" align=\"center\"><tr><td height=\"110\">
<table width=\"311\" border=\"0\" cellspacing=\"1\" cellpadding=\"0\" bgcolor=\"#FFFFFF\" height=\"136\">
<tr><td height=\"175\"><div align=\"center\"><font><b>Administrator logg inn</b></font><br>
</div><form name=\"form1\" method=\"post\" action=\"$PHP_SELF\"><div align=\"center\">
<input type=\"password\" name=\"passwd\"><br><input type=\"submit\" name=\"Submit\" value=\"Logg inn\">
</div></form></td></tr></table></td></tr></table>";
elseif (md5($passwd)==$password){
if (isset($submit)){
$fp=fopen($datafile, "w");
fputs($fp, $question."\n");
for($i=1; $i <=5000; $i++){
if($answer[$i]==""){ break;}
$input=$answer[$i]."][".$image[$i]."][".$votes[$i]."\n";
fputs($fp, $input);
fclose($fp);
$config="<?php\n";
$config.="\$textcolor='$textcolor';\n";
$config.="\$linkcolor='#FFFFFF';\n";
$config.="\$bgcolor='$bgcolor';\n";
$config.="\$tableborder='$tableborder';\n";
$config.="\$timeout='$timeout';\n";
$config.="\$ip_file='$ip_file';\n";
$config.="\$font='$font';\n";
$config.="\$fontsize='$fontsize';\n";
$config.="\$datafile='$datafile';\n";
$config.="\$option='$option';\n";
$config.="\$use_image='$use_image';\n";
$config.="\$image_for_vote='$image_for_vote';\n";
$config.="?>";
$fp=fopen($ip_file, "w");
fclose($fp);
$fp=fopen("config.php", "w");
fputs($fp, $config);
fclose($fp);
echo "<div align=\"center\"><b><font>Dine innstillinger har blitt oppdatert.</font></b></div>";
include('config.php');
$data=file($datafile);
$nb=count($data);
<html>
<head>
<title>alajepoll</title>
<meta http-equiv="Content-Type" content="text/html; charset=iso-8859-1">
<LINK href="alaje.css" rel=STYLESHEET type=text/css>
</head>
<body>
<form name="APP" method="post" action="">
 <b><i>Innstillinger for poll:</i></b><br>
             <table width="100%" border="0" cellspacing="1" cellpadding="3" align="center">
               <tr>
     <td width="116" height="15"><b>Spørsmål </b></td>
                 <td colspan="3" height="15">
                   <input type="text" name="question" size="50" maxlength="150" value="<?php echo $data[0]; ?>">
                 </td>
               </tr>
               <tr>
     <td width="116" height="15"><b>Bilde</b></td>
                   <input type="text" name="image_for_vote" size="50" maxlength="150" value="<?php echo $image_for_vote; ?>">
       <font size="1"><strong>Bruk bilde</strong></font>
       <input type="radio" name="use_image" value="1"<?if($use_image=="1"){echo " checked";}?>>
       <font size="1"><strong>Ikke bruk bilde </strong></font>
       <input type="radio" name="use_image" value="0"<?if($use_image=="0"){echo " checked";}?>></td>
               </tr>
               <tr>
                 <td colspan="4">Her skriver du inn svaralternativene som brukerene kan velge mellom når de stemmer. Fyll alltid ut 2 alternativ, og la de som du ikke trenger være blanke.</td>
               </tr>
               <tr>
                 <td width="116"> </td>
                 <td width="246">
                   <div align="center"><b>Svaralternativer</b></div>
                 </td>
                 <td width="200">
                   <div align="center"><b>Prosentbar farge</b></div>
                 </td>
     <td>
<div align="center"><b>Antall stemmer                </b></div>
                 </td>
for($i=1; $i<=$option; $i++){
$subdata=explode("][",$data[$i]);
echo "<tr><td width=\"116\">
<font face=\"Verdana, Arial, Helvetica, sans-serif\" size=\"2\"><b>Alternativ $i</b></font></td>
<td width=\"246\">
<div align=\"center\"><font face=\"Verdana, Arial, Helvetica, sans-serif\" size=\"2\">
<input type=\"text\" name=\"answer[$i]\" size=\"40\" maxlength=\"40\" value=\"$subdata[0]\"></font></div>
</td><td width=\"200\">
<div align=\"center\"><font face=\"Verdana, Arial, Helvetica, sans-serif\" size=\"2\" >
<input type=\"text\" name=\"image[$i]\" size=\"25\" maxlength=\"50\" value=\"$subdata[1]\">
</font></div></td><td width=\"181\">
<input align=\"center\" type=\"text\" name=\"votes[$i]\" size=\"4\" maxlength=\"4\" value=\"$subdata[2]\">
</font></div></td></tr>";
              </table>
             <hr width="95%" size="1" align="center" noshade>
 <table>
   <td width="248" height="22"><b>Farger</b></td>
   <td width="175" height="22"> </td>
   <td width="22" height="22"> </td>
   <td width="568" height="22" colspan="2"><b>Andre innstillinger</b></td>
   </tr>
   <tr>
     <td width="248">Antall timer før IP kan avgi ny stemme:</td>
     <td width="175"> <input type="text" name="timeout" size="3" maxlength="3" value="<?php echo $timeout; ?>">
     </td>
   </tr>
   <tr>
     <td width="248">Filen som lagrer</td>
     <td width="175"> <input type="text" name="datafile" size="25" maxlength="50" value="<?php echo $datafile; ?>">
     </td>
   </tr>
   <tr >
     <td width="248">Filen IP-adresser lagres i:</td>
     <td width="175"> <font> <input type="text" name="ip_file" size="25" maxlength="50" value="<?php echo $ip_file; ?>">
     </td>
   </tr>
   <td width="248">Antall svaralternativer:</td>
   <td width="175"> <input type="text" name="option" size="20" maxlength="100" value="<?php echo $option; ?>"></td>
   </tr>
     <td width="218">Fontstørrelse:</td>
                 <td width="205">
                   <input type="text" name="fontsize" value="<?php echo $fontsize; ?>" size="1" maxlength="1">
                 </td>
 </table>
   <input type="submit" name="submit" value="Lagre dine endringer">
             </div>
           </form>
</body>
</html>
Feilen som oppstår er:
Parse error: parse error in /home/petronas/www/alaje/cutenews/admin.php on line 162
Det er ingen linje 162 i koden...
Please HELP!
Linje 162 består av </html>
I Zend'en min får jeg unexpected end of file... Men jeg klarer ikke se noen manglende ?>.. Mystisk :hmm:
EDIT: FANT DET! Du hadde glemt å avslutte følgende elseif:
Mao. legg til en } etter den elseif-funksjonen
Endret av Loomy
Det er ikke problemet... koden virket før jeg satte inn:
i stedet for:
($passwd!=$password)
da var jo passordet gitt i $passord i toppen av koden...
uavhengig om ting ordnet seg, kan du godt telle over parentesene dine i meldingen her :)
