arve19 Skrevet 27. mai 2004 Del Skrevet 27. mai 2004 He he. Ser poenget ditt ja. Men........... hva er (var) revulosjonerende med ME??? Litt offtopic kanskje, men noe må vel skje mens vi venter. Skal slutte med denne..........................!! Lenke til kommentar
MistaPi Skrevet 27. mai 2004 Del Skrevet 27. mai 2004 (endret) Både skjermkort produsenter og spill utviklere er ganske begeistret over PCIe, dette er neppe noe som kommer til å forsvinne med det første. Merk at PCIe for skjermkort handler hovedsaklig om muliggjørelse av grafikk og funksjoner og ikke umiddelbar ytelseøkning. Det er opp til spill utviklerene å dra nytte av det. In my opinion, PCI-E will have a major impact on how games are designed because you should be able to finally read from the graphic chip memory without breaking the streaming of the transactions between the core logic and the GPU. PCI-E is a point to point bus meaning that it works just like HyperTransport (dedicated upstream/downstream). On AGP, when you switch between read and write, you have to turn around and that takes time. This should allow a new range of algorithms to be possible (like on consoles). You could use the GPU to calculate very quickly zone of dangers when the player is throwing a grenade (physic blast shadowing). The information could then by passed to your AI and Physics engine to help the AI makes a good decision on how to react to this event and to find out which objects should be impacted (where and how) by the blast. This kind of shadowing algorithm may or may not be efficient (compared to distributed ray casting) but it gives some ideas. So overall, PCI-E won't have direct impact on rendering but it will have a big impact on engine design (only programmers will notice but games are going to get better more quickly). All of this can be done on the CPU but people are going to start looking at the GPU to do other things than just graphics. All of this because of PCI-E. Dany Lepage Lead Programmer Splinter Cell - 3 UbiSoft Montreal Endret 27. mai 2004 av MistaPi Lenke til kommentar
kirjogra Skrevet 27. mai 2004 Del Skrevet 27. mai 2004 ja ja guttan sliter med og få x800pro til xt. http://forums.overclockers.co.uk/showthrea...30&pagenumber=5 Lenke til kommentar
Jakartabebopp Skrevet 27. mai 2004 Del Skrevet 27. mai 2004 jaja, da er det vel bare å vente til dette er ordentlig prøvd av noen på forumet Lenke til kommentar
ZkedaR Skrevet 28. mai 2004 Del Skrevet 28. mai 2004 (endret) Yeehaw! Skjekk det her da, de klarte det Radeon X800Pro@X800XT m\ 16 pipes Endret 28. mai 2004 av ZkedaR Lenke til kommentar
ZkedaR Skrevet 28. mai 2004 Del Skrevet 28. mai 2004 (endret) Og her er guiden Endret 28. mai 2004 av ZkedaR Lenke til kommentar
ZkedaR Skrevet 28. mai 2004 Del Skrevet 28. mai 2004 Og plutselig var det ingen grunn til å velge noe annet enn X800Pro OK, for folk som tørr å modde kortet sitt, jeg er ikke en av dem (enda) Lenke til kommentar
MrVilla Skrevet 28. mai 2004 Del Skrevet 28. mai 2004 Satser på å skaffe meg et x800pro selv, men kan ikke falle meg inn å modde det på noen som helst måte med det første. Modding er noe som jeg heller kommer til å tenke på å når kortet ikke strekker til lenger. Så lenge spilla mine kjører fint så er jeg egentlig ikke særlig interessert i hva 3dmark viser. Disse poengene bruker jeg mer for å sammenligne systemet med andre system og for å se at det yter som forventet. Når det er sagt så synes jeg det er morsomt å se hva andre klarer å presse ut av hardwaren sin Lenke til kommentar
ZkedaR Skrevet 28. mai 2004 Del Skrevet 28. mai 2004 Enig, 3dmark er egentlig ikke en test du skal stole på heller... Lenke til kommentar
Carnifex Skrevet 28. mai 2004 Del Skrevet 28. mai 2004 Og plutselig var det ingen grunn til å velge noe annet enn X800Pro OK, for folk som tørr å modde kortet sitt, jeg er ikke en av dem (enda) Tror jeg skal være fornøyd med default settings en stund. Er litt for mye penger til å kaste ut vinduet Dersom det viser seg at det er en enkel sak med svært høy success rate skal jeg vurdere det.. Lenke til kommentar
Stigma Skrevet 28. mai 2004 Del Skrevet 28. mai 2004 Dette er jo ikke noe avskrekkende i det hele tatt. Hvis du kan behandle kortet riktig, og har noengang gjort en AMD unlocking, så er jo dette barnemat egentlig. Mye værre med voltmods der man må lodde inn resistorer på kortet =) Men jeg lurer litt på, finnes det ingen pro kort med samme memory som xt? Hittil virker det som om de har fått til å aktivere de ekstra 4 pipelinene, og få klokkehastigheter som er like gode som XT stock, og litt høyere. Hvis du finer et kort med samme ram, burde man ikke med denne modden kunne klokke den like høyt som man kunne klokket en ekte XT? -Stigma Lenke til kommentar
Traxco Skrevet 28. mai 2004 Forfatter Del Skrevet 28. mai 2004 Det må nok flere inngrep til en en enkel BIOS flash for å aktivere de siste pipelines. AMD flashback anyone ? EDIT : Hvis noen er interreserte i slike ting, som meg f.eks, er det lurt å følge med på disse trådene : http://www.xtremesystems.org/forums/showth...=x800pro+x800xt http://forums.overclockers.co.uk/showthrea...30&pagenumber=1 ja,ser ut som man må gjøre inngrep i selve gpu,noen har prøvd og kutte av en av broene(1-4)slik at han fikk aktivisert alle pipelines(16) sitat: I know the first thing you'll ask is how I did it. Well, I got a very sharp knife and scraped off my previous conductive paintwork, then I used the knife to scrape away at the two points - we are using the right points after all. I scraped them away until there was some bare copper exposed, bright copper instead of the usual dull, then re-did the paint job, booted Windows up and ran ATITool, she now apparently has 16 pipes da fikk han 526mhz på gpu(default) og 573mhz(1146mhz)på rambrikkene http://forums.overclockers.co.uk/showthrea...40&pagenumber=5 Lenke til kommentar
Traxco Skrevet 28. mai 2004 Forfatter Del Skrevet 28. mai 2004 Omvendt vil jeg si men... omvent 4-1,jo kan hende..! Lenke til kommentar
ZkedaR Skrevet 28. mai 2004 Del Skrevet 28. mai 2004 Dt jeg mente var at ingen der har kuttet noen broer, snarere tvert imot. Lenke til kommentar
kirjogra Skrevet 28. mai 2004 Del Skrevet 28. mai 2004 jeg trur jeg venter til vexx har dette på norsk.hehe Lenke til kommentar
ZkedaR Skrevet 28. mai 2004 Del Skrevet 28. mai 2004 /me fikk velig lyst til å skrive en aldeles så liten guide når kortet mitt kommer... Blir det noe av, sikkert ikke, tror ikke jeg gidder å modde det engang. Lenke til kommentar
kirjogra Skrevet 28. mai 2004 Del Skrevet 28. mai 2004 men hva med og bare åpne 4 pipes går ikke det, og ikke klokke minne.? Lenke til kommentar
Robin B Skrevet 28. mai 2004 Del Skrevet 28. mai 2004 Det er en ganske enkel mod, men ser at det er flere som ikke klarer å aktivere de siste 4 pipes. Lenke til kommentar
