Debian og Nvidia-drivere
Hei!
Fiklet litt med driveren som jeg lastet ned fra nvidia.com, før jeg fant denne siden.
Men jeg får det ikke helt til å virke... pakkene heter mer enn det som står der (uname -r gir jo bare 2.6.6 som output)
# Processor type and features
CONFIG_X86_PC=y
# CONFIG_X86_ELAN is not set
# CONFIG_X86_VOYAGER is not set
# CONFIG_X86_NUMAQ is not set
# CONFIG_X86_SUMMIT is not set
# CONFIG_X86_BIGSMP is not set
# CONFIG_X86_VISWS is not set
# CONFIG_X86_GENERICARCH is not set
# CONFIG_X86_ES7000 is not set
# CONFIG_M386 is not set
# CONFIG_M486 is not set
# CONFIG_M586 is not set
# CONFIG_M586TSC is not set
# CONFIG_M586MMX is not set
# CONFIG_M686 is not set
# CONFIG_MPENTIUMII is not set
# CONFIG_MPENTIUMIII is not set
# CONFIG_MPENTIUMM is not set
# CONFIG_MPENTIUM4 is not set
# CONFIG_MK6 is not set
CONFIG_MK7=y
# CONFIG_MK8 is not set
# CONFIG_MCRUSOE is not set
# CONFIG_MWINCHIPC6 is not set
# CONFIG_MWINCHIP2 is not set
# CONFIG_MWINCHIP3D is not set
# CONFIG_MCYRIXIII is not set
# CONFIG_MVIAC3_2 is not set
# CONFIG_X86_GENERIC is not set
# CONFIG_X86_EMU486 is not set
CONFIG_X86_CMPXCHG=y
CONFIG_X86_XADD=y
CONFIG_X86_L1_CACHE_SHIFT=6
CONFIG_RWSEM_XCHGADD_ALGORITHM=y
CONFIG_X86_WP_WORKS_OK=y
CONFIG_X86_INVLPG=y
CONFIG_X86_BSWAP=y
CONFIG_X86_POPAD_OK=y
CONFIG_X86_GOOD_APIC=y
CONFIG_X86_INTEL_USERCOPY=y
CONFIG_X86_USE_PPRO_CHECKSUM=y
CONFIG_X86_USE_3DNOW=y
# CONFIG_HPET_TIMER is not set
# CONFIG_HPET_EMULATE_RTC is not set
# CONFIG_SMP is not set
# CONFIG_PREEMPT is not set
CONFIG_X86_UP_APIC=y
CONFIG_X86_UP_IOAPIC=y
CONFIG_X86_LOCAL_APIC=y
CONFIG_X86_IO_APIC=y
CONFIG_X86_TSC=y
# CONFIG_X86_MCE is not set
CONFIG_TOSHIBA=m
CONFIG_I8K=m
CONFIG_MICROCODE=m
CONFIG_X86_MSR=m
CONFIG_X86_CPUID=m
Package kernel-headers-2.6.6-1
unstable (devel): Header files related to Linux kernel version 2.6.6
2.6.6-1: alpha i386
Package kernel-headers-2.6.6-1-386
unstable (devel): Linux kernel headers 2.6.6 on 386
2.6.6-1: i386
Package kernel-headers-2.6.6-1-686
unstable (devel): Linux kernel headers 2.6.6 on PPro/Celeron/PII/PIII/PIV
2.6.6-1: i386
Package kernel-headers-2.6.6-1-686-smp
unstable (devel): Linux kernel headers 2.6.6 on PPro/Celeron/PII/PIII/PIV SMP
2.6.6-1: i386
Package kernel-headers-2.6.6-1-generic
unstable (devel): Linux kernel headers 2.6.6 on Alpha
2.6.6-1: alpha
Package kernel-headers-2.6.6-1-k7
unstable (devel): Linux kernel headers 2.6.6 on AMD K7
2.6.6-1: i386
Package kernel-headers-2.6.6-1-k7-smp
unstable (devel): Linux kernel headers 2.6.6 on AMD K7 SMP
2.6.6-1: i386
Package kernel-headers-2.6.6-1-smp
unstable (devel): Linux kernel headers 2.6.6 on Alpha SMP
2.6.6-1: alpha
Hvilken skal jeg laste ned?
Hva skal da symlinken hete?
Endret av meastp
"apt-get install kernel-headers-2.6.6-1-k7"
"sh NVIDIA-installer-pakke.run --kernel-include-path=/usr/src/kernel-headers-2.6.6-1-k7"
Tror det skulle fikse biffen. Mener å huske at --kernel-include-path har blitt byttet ut med noe annet, men installeren gir i tilfelle beskjed om det.
Det fungerte ikke... :(
får bare beskjed om å bruke --kernel-source-path på nytt fordi installeren ikke finner nvidia.ko eller noe...
jeg har riktig fil? det er kernel-headers og ikke en eller annen nvidia-fil som skal lastes ned?
Her er /usr/src/
-rw-r--r--    1 root     src       2573814 May 19 22:42 kernel-doc-2.6.3_Custom.1_all.deb
-rw-r--r--    1 root     src       2598176 May 24 22:19 kernel-doc-2.6.6_Custom.1_all.deb
-rw-r--r--    1 root     src       4912012 May 19 22:43 kernel-headers-2.6.3_Custom.1_i386.deb
drwxr-xr-x   16 root     root          496 May 26 16:21 kernel-headers-2.6.6-1
drwxr-xr-x    3 root     root          520 May 26 16:21 kernel-headers-2.6.6-1-k7
-rw-r--r--    1 root     src       5006620 May 24 22:20 kernel-headers-2.6.6_Custom.1_i386.deb
-rw-r--r--    1 root     src       6219842 May 19 22:43 kernel-image-2.6.3_Custom.1_i386.deb
-rw-r--r--    1 root     src       6195298 May 24 22:20 kernel-image-2.6.6_Custom.1_i386.deb
drwxr-xr-x    3 root     root           72 May 26 16:21 kernel-kbuild-2.6-3
drwxr-xr-x   20 root     root         1672 May 19 22:43 kernel-source-2.6.3
-rw-r--r--    1 root     root     33734882 Feb 22 22:32 kernel-source-2.6.3.tar.bz2
-rw-r--r--    1 root     src      34092722 May 19 22:42 kernel-source-2.6.3_Custom.1_all.deb
-rw-r--r--    1 root     src          1253 May 19 22:43 kernel-source-2.6.3_Custom.1_i386.changes
drwxr-xr-x   20 root     root         1792 May 26 23:29 kernel-source-2.6.6
-rw-r--r--    1 root     root     34419556 May 12 01:47 kernel-source-2.6.6.tar.bz2
-rw-r--r--    1 root     src      34919106 May 24 22:19 kernel-source-2.6.6_Custom.1_all.deb
-rw-r--r--    1 root     src          1253 May 24 22:20 kernel-source-2.6.6_Custom.1_i386.changes
lrwxrwxrwx    1 root     src            19 May 24 21:38 linux -> kernel-source-2.6.6
-rw-r--r--    1 root     root       862403 May  1 04:43 nvidia-kernel-source.tar.gz
Endret av meastp
nvidia-installer log file '/var/log/nvidia-installer.log'
creation time: Thu May 27 16:23:40 2004
option status:
 license pre-accepted    : false
 update                  : false
 force update            : false
 expert                  : false
 uninstall               : false
 driver info             : false
 no precompiled interface: false
 no ncurses color        : false
 query latest driver ver : false
 OpenGL header files     : false
 no questions            : false
 silent                  : false
 XFree86 install prefix  : /usr/X11R6
 OpenGL install prefix   : /usr
 Installer install prefix: /usr
 kernel source path      : /usr/src/kernel-headers-2.6.6-1-k7/
 kernel install path     : (not specified)
 proc mount point        : /proc
 ui                      : (not specified)
 tmpdir                  : /tmp
 ftp site                : ftp://download.nvidia.com
Using: nvidia-installer ncurses user interface
-> License accepted.
-> No precompiled kernel interface was found to match your kernel; would you li
  ke the installer to attempt to download a kernel interface for your kernel f
  rom the NVIDIA ftp site (ftp://download.nvidia.com)? (Answer: Yes)
-> No matching precompiled kernel interface was found on the NVIDIA ftp site;
  this means that the installer will need to compile a kernel interface for
  your kernel.
-> Using the kernel source path '/usr/src/kernel-headers-2.6.6-1-k7/' as
  specified by the '--kernel-source-path' commandline option.
-> Kernel source path: '/usr/src/kernel-headers-2.6.6-1-k7/'
-> Performing cc_version_check with CC="cc".
-> Cleaning kernel module build directory.
  executing: 'cd ./usr/src/nv; make clean'...
  rm -f -f nv.o os-agp.o os-interface.o os-registry.o nv.o os-agp.o os-interfa
  ce.o os-registry.o nvidia.mod.o
  rm -f -f build-in.o nv-linux.o *.d .*.{cmd,flags}
  rm -f -f nvidia.{o,ko,mod.{o,c}} nv_compiler.h *~
-> Building kernel module:
executing: 'cd ./usr/src/nv; make module SYSSRC=/usr/src/kernel-headers-2.6.
  6-1-k7/'...
  echo \#define NV_COMPILER \"`cc -v 2>&1 | tail -n 1`\" > /tmp/selfgz2703/NVI
  DIA-Linux-x86-1.0-5336-pkg1/usr/src/nv/nv_compiler.h
    CC [M]  /tmp/selfgz2703/NVIDIA-Linux-x86-1.0-5336-pkg1/usr/src/nv/nv.o
  In file included from include/linux/list.h:7,
                   from include/linux/wait.h:14,
                   from include/asm/semaphore.h:41,
                   from include/linux/sched.h:18,
                   from include/linux/module.h:10,
                   from /tmp/selfgz2703/NVIDIA-Linux-x86-1.0-5336-pkg1/usr/src
  /nv/nv-linux.h:52,
  /nv/nv.c:14:
  include/linux/prefetch.h: In function `prefetch_range':
  include/linux/prefetch.h:62: warning: pointer of type `void *' used in arith
  metic
  /tmp/selfgz2703/NVIDIA-Linux-x86-1.0-5336-pkg1/usr/src/nv/nv.c: In function
  `nvos_malloc_pages':
  /tmp/selfgz2703/NVIDIA-Linux-x86-1.0-5336-pkg1/usr/src/nv/nv.c:385: warning:
  use of cast expressions as lvalues is deprecated
  `nvos_create_alloc':
  /tmp/selfgz2703/NVIDIA-Linux-x86-1.0-5336-pkg1/usr/src/nv/nv.c:513: warning:
  /tmp/selfgz2703/NVIDIA-Linux-x86-1.0-5336-pkg1/usr/src/nv/nv.c:523: warning:
  /tmp/selfgz2703/NVIDIA-Linux-x86-1.0-5336-pkg1/usr/src/nv/nv.c: At top level
  /tmp/selfgz2703/NVIDIA-Linux-x86-1.0-5336-pkg1/usr/src/nv/nv.c:1185: warning
  : initialization from incompatible pointer type
  `nv_alloc_file_private':
  /tmp/selfgz2703/NVIDIA-Linux-x86-1.0-5336-pkg1/usr/src/nv/nv.c:1193: warning
  : use of cast expressions as lvalues is deprecated
  /tmp/selfgz2703/NVIDIA-Linux-x86-1.0-5336-pkg1/usr/src/nv/nv.c:1204: warning
  `nv_kern_open':
  /tmp/selfgz2703/NVIDIA-Linux-x86-1.0-5336-pkg1/usr/src/nv/nv.c:1265: warning
  `nv_kern_ctl_open':
  /tmp/selfgz2703/NVIDIA-Linux-x86-1.0-5336-pkg1/usr/src/nv/nv.c:1914: warning
    CC [M]  /tmp/selfgz2703/NVIDIA-Linux-x86-1.0-5336-pkg1/usr/src/nv/os-agp.o
  /nv/nv-linux.h:52,
  /nv/os-agp.c:24:
  metic
    CC [M]  /tmp/selfgz2703/NVIDIA-Linux-x86-1.0-5336-pkg1/usr/src/nv/os-inter
  face.o
  /nv/nv-linux.h:52,
  /nv/os-interface.c:26:
  metic
  /tmp/selfgz2703/NVIDIA-Linux-x86-1.0-5336-pkg1/usr/src/nv/os-interface.c: In
  function `os_alloc_contig_pages':
  /tmp/selfgz2703/NVIDIA-Linux-x86-1.0-5336-pkg1/usr/src/nv/os-interface.c:292
  : warning: use of cast expressions as lvalues is deprecated
  function `save_wb':
  /tmp/selfgz2703/NVIDIA-Linux-x86-1.0-5336-pkg1/usr/src/nv/os-interface.c:748
    CC [M]  /tmp/selfgz2703/NVIDIA-Linux-x86-1.0-5336-pkg1/usr/src/nv/os-regis
  try.o
  /nv/nv-linux.h:52,
  /nv/os-registry.c:14:
  metic
    LD [M]  /tmp/selfgz2703/NVIDIA-Linux-x86-1.0-5336-pkg1/usr/src/nv/nvidia.o
    Building modules, stage 2.
    MODPOST
    CC      /tmp/selfgz2703/NVIDIA-Linux-x86-1.0-5336-pkg1/usr/src/nv/nvidia.m
  od.o
    LD [M]  /tmp/selfgz2703/NVIDIA-Linux-x86-1.0-5336-pkg1/usr/src/nv/nvidia.k
  o
-> done.
-> Kernel module compilation complete.
ERROR: Unable to load the kernel module 'nvidia.ko'.  This is most likely
      because the kernel module was built using the wrong kernel source files.
      Please make sure you have installed the kernel source files for your
kernel; on Red Hat Linux systems, for example, be sure you have the
      'kernel-source' rpm installed.  If you know the correct kernel source
      files are installed, you may specify the kernel source path with the
-> Kernel module load error: insmod: QM_MODULES: Function not implemented
  insmod: cannot open /proc/ksyms No such file or directory
ERROR: Installation has failed.  Please see the file
      '/var/log/nvidia-installer.log' for details.  You may find suggestions
      on fixing installation problems in the README available on the Linux
      driver download page at www.nvidia.com.
