Siden validerer ikke, trenger litt hjelp!
Hei! Jeg bruker et poll script som heter dynamic poll.
Etter jeg brukte det kom det sef. masse masse feil :cry:
Lurte på om noen av dere kunne hjelpe meg litt.
Slik ser koden ut: poll.php:
include "config.php";
include $pollfile;
include "js_header.php";
if ($Vote) {
$ip = fopen($ipfile, "r");
$contents = fread($ip, filesize($ipfile));
$uip = $REMOTE_ADDR;
if (eregi("$uip", $contents)) {
   echo "Du har allerede stemt! Vent til neste avstemning<br><br>";   // just incase
else{
$ip = fopen($ipfile, "a");
fputs ($ip, "<? //$REMOTE_ADDR ?>\n");
fclose ($ip);
$file = fopen($pollfile, "w+");
fputs ($file, "<?\n");
fputs ($file, "\$answer[0] = \"$answer[0]\";\n");
fputs ($file, "\$answer[1] = \"$answer[1]\";\n");
fputs ($file, "\$answer[2] = \"$answer[2]\";\n");
fputs ($file, "\$answer[3] = \"$answer[3]\";\n");
fputs ($file, "\$answer[4] = \"$answer[4]\";\n");
fputs ($file, "\$answer[5] = \"$answer[5]\";\n");
fputs ($file, "\$answer[6] = \"$answer[6]\";\n");
fputs ($file, "\$answer[7] = \"$answer[7]\";\n");
fputs ($file, "\$answer[8] = \"$answer[8]\";\n");
fputs ($file, "\$answer[9] = \"$answer[9]\";\n\n");
if ($Vote == $answer[0]){
$increment = $votes[0] + 1;
   fputs ($file, "\$votes[0] = \"$increment\";\n");
else{
fputs ($file, "\$votes[0] = \"$votes[0]\";\n");
if ($Vote == $answer[1]) { $increment = $votes[1] + 1; fputs ($file, "\$votes[1] = \"$increment\";\n"); } else { fputs ($file, "\$votes[1] = \"$votes[1]\";\n"); }
if ($Vote == $answer[2]) { $increment = $votes[2] + 1; fputs ($file, "\$votes[2] = \"$increment\";\n"); } else { fputs ($file, "\$votes[2] = \"$votes[2]\";\n"); }
if ($Vote == $answer[3]) { $increment = $votes[3] + 1; fputs ($file, "\$votes[3] = \"$increment\";\n"); } else { fputs ($file, "\$votes[3] = \"$votes[3]\";\n"); }
if ($Vote == $answer[4]) { $increment = $votes[4] + 1; fputs ($file, "\$votes[4] = \"$increment\";\n"); } else { fputs ($file, "\$votes[4] = \"$votes[4]\";\n"); }
if ($Vote == $answer[5]) { $increment = $votes[5] + 1; fputs ($file, "\$votes[5] = \"$increment\";\n"); } else { fputs ($file, "\$votes[5] = \"$votes[5]\";\n"); }
if ($Vote == $answer[6]) { $increment = $votes[6] + 1; fputs ($file, "\$votes[6] = \"$increment\";\n"); } else { fputs ($file, "\$votes[6] = \"$votes[6]\";\n"); }
if ($Vote == $answer[7]) { $increment = $votes[7] + 1; fputs ($file, "\$votes[7] = \"$increment\";\n"); } else { fputs ($file, "\$votes[7] = \"$votes[7]\";\n"); }
if ($Vote == $answer[8]) { $increment = $votes[8] + 1; fputs ($file, "\$votes[8] = \"$increment\";\n"); } else { fputs ($file, "\$votes[8] = \"$votes[8]\";\n"); }
if ($Vote == $answer[9]) { $increment = $votes[9] + 1; fputs ($file, "\$votes[9] = \"$increment\";\n"); } else { fputs ($file, "\$votes[9] = \"$votes[9]\";\n"); }
$increment = $total + 1;
fputs ($file, "\$total = \"$increment\";\n");
fputs ($file, "\$ask = \"$ask\";\n");
fputs ($file, "?>");
fclose ($file);
echo "<script LANGUAGE=\"JavaScript\">window.location=\"$PHP_SELF\";</script>\n<noscript><A HREF=\"$PHP_SELF\">Continue...</A></noscript>";
if ($ask == ""){
echo "<b>$nopoll</b>";
else {
// start html code returning results.....................................
  $ask = stripslashes($ask);
  echo "<b>$ask</b><br>";
  echo "<small>$votedalready<br><br>$total ";
if ($total == "1"){
echo "Stemme";
else{
 echo "Stemmer";
echo "</small>\n\n";
include($pollfile);
for ($i = 0; $i < count($answer); $i++) {
$answer[$i] = stripslashes($answer[$i]);
 if ($answer[$i] == "" && $votes[$i] == ""){
 	echo "";
 else{
 $percentage = (round(($votes[$i] / $total) * 100, 1));
       echo "<br><b>$answer[$i]</b> <small>($votes[$i])</small><br>\n";
 echo "<img alt=\"$answer[$i] - $votes[$i] votes ($percentage%)\" style=\"border: 1 solid #000000\" src=$imgurl height=5 width=";
 echo (round(($votes[$i] / $total) * 80, 0));
 echo ">";
 	echo;
 	echo;
else {
echo "<b>$ask</b><br>\n\n";
echo "<table cellpadding=0 cellspacing=0 border=0>\n";
echo " <form name=form method=post><small>\n";
if ($answer[$i] == ""){
echo "";
else {
echo "  <tr>\n";
echo "    <td>\n";
echo "      <input type=radio name=Vote value=\"$answer[$i]\" id=\"$answer[$i]\">\n";
echo "    </td>\n";
echo "    <td>";
echo "<small><label for=\"$answer[$i]\">$answer[$i]</label></small>";
echo "</td>\n";
echo "  </tr>\n";
echo "</table>\n\n";
echo "<input type=submit value=\"Stem!\">\n";
echo "</form>\n\n";
Her er alle feilene: link
Hvis noen kunne hjulpet meg litt på vei hadde jeg blitt veldig glad. Takk!
include $pollfile;
if ($Vote) {
else{
fclose ($ip);
else{
fclose ($file);
if ($ask == ""){
else {
if ($total == "1"){
echo "Stemme";
else{
echo "Stemmer";
include($pollfile);
  echo "";
else{
echo ">";
  echo;
  echo;
else {
echo "  <tr>\n";
echo "    <td>\n"; /* Flyttet disse litt oppover. TR og TD må komme før noe annet i et table */
echo " <form name=form method=post action=""><small>\n";
echo "";
else {
echo "    </td>\n";
echo "    <td>";
echo "</td>\n";
echo "  </tr>\n";
echo "</form>\n\n";
Gjorde et par justeringer. Burde i hvert fall fjerne 2-3 av feilene.
EDIT: Endret litt mer
Endret av Loomy
Vel, for det første: Dette har da så og si ingenting med PHP å gjøre.
For det andre: Hvis du tar deg tid til å lese feilene, så ser du at det står utrolig grundig forklart hva feilen går ut på rett under.
OK! Unnskyld da.
Jeg har lest feilene, men vet ikke hvordan jeg skal "ordne" opp i koden.
Nesten alle feila forsvant, men nå viser ikke pollen lengre.
mld:
Parse error: parse error, unexpected T_CONSTANT_ENCAPSED_STRING, expecting ',' or ';' in /home/espendl/public_html/dynamicpoll/poll.php on line 133
