NIS 2004 Pro = 60 - 120.000 kb?
Hei.
Av og til i oppgave behandling går denne prosessen, ccproxy.exe,
opp i 60.000 til 120.000 kb. Jeg syns den tar litt mye ressurser.
Noen som kan si hvorfor den tar så mye?
Av og til går: Bruk av CPU - 100% Konstant når jeg ikke holder på med noen ting.
How to remove CC Proxy manually?
Step1. Launch CC Proxy -> Options: uncheck "Auto Startup" and "NT Service" -> Close CC Proxy.
Step2. Find the folder including ccproxy.exe, delete ccproxy.exe. If you can find a file named "unins000.exe", you can launch it to do uninstallation.
If you still cannot remove CC Proxy, please search if there is a file named runscr32.exe or hide.exe on your computer. If you find both of them or even one of them. Please delete them. Then you should remove CC Proxy from your computer permenantly. Many unregistered users have reported the same problem recently. All of them reported they actually didn't install CC Proxy at all. So this problem is probably incurred by some other program that is NOT the product from our company.
We will pay close attention to this unusual issue because it unfairly impaired our software's reputation. If you have any other questions, please contact us. We are here to help you!
Kilde: http://www.youngzsoft.net/ccproxy/install.htm#i13
Google is your friend... :thumbup:
