Javascript Dropdown
Har en dropdownmeny.. Funker.. Ikke helt opera vennlig men. Har et problem.
Når man holder over menyen kommer menyen ned, men det går også ann å trykk på den, og da blir det feil, fordi den viser til "menulite\services". Er det noen måte og få ordna slik at du ikke får trykt videre der, bare at menyen kommer ned..
Filene:
// write me if you have questions: [email protected]
// constants
var initX       = 201; // x-coordinate of top left corner of dropdown menu
var initY       = 125; // y-coordinate of top left corner of dropdown menu
var backColor   = '#E6E6E6'; // the background color of dropdown menu, set empty '' for transparent
var borderColor = 'black'; // the color of dropdown menu border
var borderSize  = '1'; // the width of dropdown menu border
var itemHeight  = 20;
var xOverlap    = 5;
var yOverlap    = 10;
menuContent     = new Array ();
menuContent [0] = new Array (
-1, // the id of parent menu, -1 if this is a first level menu
-1, // the number of line in parent menu, -1 if this is a first level menu
120, // the width of current menu list
-1, // x coordinate (absolute) of left corner of this menu list, -1 if the coordinate is defined from parent x-coordinate
-1, // y coordinate (absolute) of left corner of this menu list, -1 if the coordinate is defined from parent y-coordinate
new Array (
'Link 11', 'http://www.1.net',
'Link 12', 'http://www.2.net',
'Link 13', 'http://www.3.net'
menuContent [1] = new Array (
-1,
-1,
120,
new Array (
'Link 21', 'http://www.1.net',
'Link 22', 'http://www.2.net',
'Link 23', 'http://www.3.net'
menuContent [2] = new Array (
0,
1,
120,
new Array (
'Link 111', 'http://www.1.net',
'Link 112', 'http://www.2.net',
'Link 113', 'http://www.3.net'
menuContent [3] = new Array (
0,
0,
120,
new Array (
menuContent [4] = new Array (
1,
0,
120,
new Array (
menuContent [5] = new Array (
4,
0,
120,
new Array (
// Don't change these parameters
var delay        = 500; /////
var menuElement  = new Array ();
var usedWidth    = 0;
var numOfMenus   = 0;
// check browser version
isNC    = (document.layers) ? 1 : 0;
isOPERA = (navigator.userAgent.indexOf('Opera') >= 0)? true : false;
isIE    = (document.all && !isOPERA)? true : false;
isDOM   = (document.getElementById && !isIE && !isOPERA)? true : false;
var topID  = -1;
// constructor of menu elements
function menuConstructor (id, content)
this.ID            = id;
this.parentID      = content [0]*1;
this.parentItemID  = content [1]*1;
this.width         = content [2]*1;
this.timerID       = -1;
this.isOn          = false;
this.item          = new Array ();
this.currItemID    = -1;
this.x = content [3]*1;
if (this.x < 0 && this.parentID == -1)
 this.x = initX + usedWidth;
 usedWidth = usedWidth + this.width;
else if (this.x < 0 && this.parentID > -1)
 this.x =  menuElement [this.parentID].x
        + menuElement [this.parentID].width
        - xOverlap;
this.y = content [4]*1;
if (this.y < 0 && this.parentID == -1)
 this.y = initY;
else if (this.y < 0 && this.parentID > -1)
 this.y =  menuElement [this.parentID].y
         + itemHeight*this.parentItemID
        + yOverlap;
items = content [5];
layerBody = '<table width=' + this.width + ' cellpadding=3 cellspacing=' + borderSize + ' border=0>';
for (j = 0; j <= items.length - 2; j = j + 2)
 controlBlock = ' onMouseOver = "enterItem (' + this.ID + ', ' + ((j + 2)/2 - 1) + ');" onMouseOut = "exitItem (' + this.ID + ', ' + ((j + 2)/2 - 1) + ');" ';
 layerBody += '<td height=' + itemHeight + ' width=' + this.width + ' bgcolor=' + backColor + '><a class=subMenu href='+ items [j + 1] +' ' + controlBlock + '>' + items [j] + '</a></td>';
 if (j < items.length - 2)
 	layerBody = layerBody +  '<tr>\n';
 else
 	layerBody = layerBody + '\n';
if (!isNC)
 layerHeader = '<div id=Menu' + this.ID +
          ' onMouseOver="enterMenu (' + this.ID + ');" onMouseOut = "exitMenu (' + this.ID + ');"' +
             ' style="background:; width: ' + this.width + '; visibility: hidden; position: absolute; left: ' + this.x +
             '; top: ' + this.y + ';">';
else
 layerHeader = '<layer id=Menu' + this.ID +
       ' visibility=hide left=' + this.x +
       ' top =' + this.y + '>';
layerHeader += '<table width=' + this.width + ' cellpadding=0 cellspacing=0 border=0>' +
       '<td bgcolor=' + borderColor + '>';
layerFooter = '</table></td></table>';
if (!isNC)
 layerFooter = layerFooter + '</div>';
else
 layerFooter = layerFooter + '</layer>';
document.writeln (layerHeader + layerBody + layerFooter);
return this;
function enterTopItem (ID)
if (topID != ID && topID != -1)
 hideTree (topID);
releaseTree (ID);
topID = ID;
show (ID);
function exitTopItem (ID)
menuElement [ID].timerID = setTimeout ('hide (' + ID + ')', delay);
function enterItem (menuID, itemID)
var currItemID = menuElement [menuID].currItemID;
if (currItemID != i & currItemID > -1)
 hide (currItemID);
for (var i = 0; i < numOfMenus; i++)
 if (menuElement [i].parentID == menuID &&
     menuElement [i].parentItemID == itemID)
 	clearTimeout (menuElement [i].timerID);
 	menuElement [i].timerID = -1;
 	show (i);
 	return 0;
return -1;
function exitItem (menuID, itemID)
 	menuElement [i].timerID = setTimeout ('hide (' + i + ')', delay);
 	return 0;
function enterMenu (ID)
var parentID = menuElement [ID].parentID;
if (parentID == -1)
 clearTimeout (menuElement [ID].timerID);
 menuElement [ID].timerID = -1;
else
 releaseTree (ID);
function exitMenu (ID)
timeoutTree (ID);
function hideTree (ID)
hide (ID);
for (var j = 0; j < numOfMenus; j++)
 if (menuElement [j].parentID == ID &&
 	menuElement [j].isOn)
 	hideTree (j);
 	return 0;
function releaseTree (ID)
if (parentID > -1)
 releaseTree (parentID);
function timeoutTree (ID)
if (parentID > -1)
 timeoutTree (parentID);
function show (ID)
if (isDOM)
 document.getElementById('Menu' + ID).style.visibility = "visible";
   	else if (isIE)
 document.all['Menu' + ID].style.visibility = "visible";
     	else if (isNC)
 document.layers[ID].visibility = "show";
menuElement [ID].isOn = true;
if (menuElement [ID].parentID > -1)
 menuElement [menuElement [ID].parentID].currItemID = ID;
function hide (ID)
if (isDOM)
 document.getElementById('Menu' + ID).style.visibility = "hidden";
   	else if (isIE)
 document.all['Menu' + ID].style.visibility = "hidden";
     	else if (isNC)
 document.layers[ID].visibility = "hide";
menuElement [ID].isOn = false;
 menuElement [menuElement [ID].parentID].currItemID = -1;
function createMenuTree ()
for (var i = 0; i < menuContent.length; i++)
 menuElement [i] = new menuConstructor (i, menuContent [i]);
 numOfMenus++;
createMenuTree ();
Btw: det er ikke mulig og få denne meny til å funke som den skal opera?
Takker! :yes:
