Zimyc Skrevet 23. mai 2004 Rapporter Del Skrevet 23. mai 2004 (endret) Her er en fin liten liste over hvor mye m³/dB viftene på microplex blåser. Håper jeg har regnet alt riktig, og btw. Det er varenr'a til Microplex på viftene. uansett her er listen: 20x20mm TFD2008L12S = 0,041 25x25mm TFD2510L12C = 0,130 252N = 0,200 30x30mm TFD3007L12S = 0,250 40x40mm PC4010L12S = 0,210 TFD4007L12C = 0,304 412F = 0,307 412FH = 0,310 412FM = 0,315 412H = 0,482 412 = 0,555 45x45mm TFD4510L12B = 0,500 50x50mm PC5010L12S = 0,200 TFD501012CT = 0,500 TFD5015L12C = 0,500 512F = 0,666 60x60mm TFD601012CT = 0,592 TFD6010L12S = 0,592 612FH = 1,064 612F = 1,074 TFD602012CT = 1,076 612NGN = 1,171 612N2GN = 1,171 612FL = 1,187 612N2GH = 1,210 612NGH = 1,210 612N2GM = 1,250 612N2GHH = 1,302 612NGHH = 1,302 612N2GL = 1,312 612N2GML = 1,315 TFD6025M12C = 1,428 TFDA6025M12C = 1,428 FFB0612EHE = 1,574 70x70mm TFD7015L12C = 1,653 TFD7025L12C = 2.000 80x80mm TFD8025L12S = 1,826 ZMF1 = 1,882 PC8015L12C = 1,904 SBUVFBL = 1,928 SBUVFGR = 1,928 SBUVFRE = 1,928 SBUVFYE = 1,928 SBLF2B2RRPM = 1,933 SBLF4BRPM = 1,933 SBLF4GRPM = 1,933 SBLF4RRPM = 1,933 PC8020L12C = 1,960 TFD802512CT = 1,964 UC8FAB = 2,093 8412N2GH = 2,135 8412N2G = 2,156 TFDA8025M12C = 2,200 8412N2GME = 2,230 KOVS2B = 2,285 AD0812DBA70GL = 2,323 8412N2GMLE = 2,368 SCLFM1580T = 2,238 KOVS2L = 2,346 SCLFZ1580M = 2,368 KOVS2P = 2,419 FFB0812EHE = 2,615 A1468 = 2,666 A1357 = 2,687 A1506 = 2,687 KOVS1 = 2,704 8412N2GL = 2,750 92x92mm TFD9225L12S = 2,080 TFDA9225M12C = 2,500 ZMF2 = 2,500 3412NGM = 2,571 3412NGH = 2,611 3412NGHH = 2,615 3412NG = 2,625 3412NGL = 2,652 UC9FAB = 2,781 SCLFZ1592M = 2,818 120x120mm MIST120LSLEBL = 2,763 MIST120LSLEGR = 2,763 MIST120LSLERE = 2,763 MIST120LSNLCL = 2,763 UC12FAB = 3,512 4412FGML = 3,562 4412FGL = 3,615 4412FGM = 3,684 SCLFZ1512M = 3,814 TFD1202512CT = 4,187 TFD12025L12C = 4,379 KD1212PMB16A = 4,380 TFDA12025M12C = 4,466 Edit: Fikset listen i m3/dB rekkefølge. Edit2: Fikset helt ny liste. Endret 23. mai 2004 av Zimyc Lenke til kommentar
ace_ventuora Skrevet 23. mai 2004 Rapporter Del Skrevet 23. mai 2004 (endret) Bra liste MEn hvordan kan det ha seg at Titan vifta på 120 mm bråker mest i sin klasse, mens Titan 80 mm bråker nesten minst av 80 mm-erne? Editerte litt.. Endret 23. mai 2004 av ace_ventuora Lenke til kommentar
Zimyc Skrevet 23. mai 2004 Forfatter Rapporter Del Skrevet 23. mai 2004 listen er ikke i rekkefølge, tok bare etter lista nedover på microplex, kan godt lage den i rekkefølge, minst per desibel først. Tar ikke mye tid Lenke til kommentar
kverna Skrevet 23. mai 2004 Rapporter Del Skrevet 23. mai 2004 og at deltaen ikke bråker mest av 80mm ? trudde den var overlegen der jeg Lenke til kommentar
Zimyc Skrevet 23. mai 2004 Forfatter Rapporter Del Skrevet 23. mai 2004 den bråker da mest og den blåser mest, men den blåser ikke mest per desibel. f.eks, den blåser 135m3 eller no sånnt, men bråker 52 dB, altså 135/52 blir ikke så mye som på noen av de andre viftene. Lenke til kommentar
Zimyc Skrevet 23. mai 2004 Forfatter Rapporter Del Skrevet 23. mai 2004 (endret) funnet ut at det er en del feil i listen, mekker det når jeg får tid. Edit: Mekket listen nå Endret 23. mai 2004 av Zimyc Lenke til kommentar
White_Tiger Skrevet 23. mai 2004 Rapporter Del Skrevet 23. mai 2004 Bra liste MEn hvordan kan det ha seg at Titan vifta på 120 mm bråker mest i sin klasse, mens Titan 80 mm bråker nesten minst av 80 mm-erne? Editerte litt.. Den bråker minst per db da, ikke mest... desto høyere tall desto bedre må det jo være siden man deler på db, høyere db gir da lavere tall. Lenke til kommentar
Toddy Skrevet 23. mai 2004 Rapporter Del Skrevet 23. mai 2004 Du bør jo regne om litt, går dårlig å dele m^3 på db som følger en logaritmist skala Lenke til kommentar
Zimyc Skrevet 23. mai 2004 Forfatter Rapporter Del Skrevet 23. mai 2004 hva mener du med det? Lenke til kommentar
Toddy Skrevet 23. mai 2004 Rapporter Del Skrevet 23. mai 2004 (endret) dB skalaen ikke er linær. Den er slik som ph skalaen. se på dette bildet: edit: her sammenlignes to lydnivåer. Med andre ord er ikke 40dB det samme som 2*20dB. si at 10 dB tilsvarer verdien 10, da blir 20dB = 100 og 60dB = 1000000 Endret 23. mai 2004 av Toddy Lenke til kommentar
ace_ventuora Skrevet 23. mai 2004 Rapporter Del Skrevet 23. mai 2004 Bra liste MEn hvordan kan det ha seg at Titan vifta på 120 mm bråker mest i sin klasse, mens Titan 80 mm bråker nesten minst av 80 mm-erne? Editerte litt.. Den bråker minst per db da, ikke mest... desto høyere tall desto bedre må det jo være siden man deler på db, høyere db gir da lavere tall. dontgetit Lenke til kommentar
arnosmith Skrevet 23. mai 2004 Rapporter Del Skrevet 23. mai 2004 (endret) ok, mye luft m^3 er bra, mye db er dårlig. Masse sjokolade er bra, mange personer å dele med er dårlig... 10kg sjokolade/ 5 personer = 2kg/pers 10kg sjokolade/ 10 personer = 1kg/pers 10kg sjokolade/ 2 personer = 5kg/pers altså m^3 er sjokolade () mens db er personer () DESTO HØYERE TALL (MER SJOKOLADE PER PERSON ) DESTO MER EFFEKTIV ER KJØLEREN! mmmm, fikk lyst på sjokolade *løper bort på shell og kjøper en japp* edit: seks smilys, ny rekord eh... syv... Endret 23. mai 2004 av arnosmith Lenke til kommentar
kverna Skrevet 23. mai 2004 Rapporter Del Skrevet 23. mai 2004 (endret) tøff vri Endret 23. mai 2004 av kverna Lenke til kommentar
White_Tiger Skrevet 24. mai 2004 Rapporter Del Skrevet 24. mai 2004 ok, mye luft m^3 er bra, mye db er dårlig. Masse sjokolade er bra, mange personer å dele med er dårlig... 10kg sjokolade/ 5 personer = 2kg/pers 10kg sjokolade/ 10 personer = 1kg/pers 10kg sjokolade/ 2 personer = 5kg/pers altså m^3 er sjokolade () mens db er personer () DESTO HØYERE TALL (MER SJOKOLADE PER PERSON ) DESTO MER EFFEKTIV ER KJØLEREN! mmmm, fikk lyst på sjokolade *løper bort på shell og kjøper en japp* edit: seks smilys, ny rekord eh... syv... Takker *løpe og kjøpe sjokolade* Lenke til kommentar
Olle P Skrevet 24. mai 2004 Rapporter Del Skrevet 24. mai 2004 (endret) altså m^3 er sjokolade () mens db er personer () DESTO HØYERE TALL (MER SJOKOLADE PER PERSON ) DESTO MER EFFEKTIV ER KJØLEREN! För en korrektare jämförelse krävs formeln: Luftflöde [m3/h] / (10^(Ljudnivå [dB(A)]/10)) Två exempel: Delta 80mm Luftflöde: 136 m3/h Ljudnivå: 52 dB(A) 136 / 10^5,2 = 0,000858 ADDA 80mm Luftflöde: 34,85 m3/h Ljudnivå: 15 dB(A) 34,85 / 10^1,5 = 1,102 Alltså stöyer Deltan mycket mer än Adda-viften, per luftflöde! (Ett annat sätt att visa det på är att ta 4 Adda-vifter; Luftflöde: 34,85 m3/h * 4 = 139,4 m3/h Ljudnivå: 15 dB(A) * 4 = 21 dB(A) alltså mer flöde till betydligt lägre ljudnivå!) Observera dock att värdena endast gäller vid fritt flöde. Vid minsta extra luftmotstånd ökar ljudet och flödet minskar, och flödet minskar mest för "tysta" vifter. /Olle Endret 24. mai 2004 av Olle P Lenke til kommentar
baronKanon Skrevet 24. mai 2004 Rapporter Del Skrevet 24. mai 2004 Svensken har talt, og han talte vel! Lenke til kommentar
arnosmith Skrevet 24. mai 2004 Rapporter Del Skrevet 24. mai 2004 Svensken har talt, og han talte vel! dette er kanskje ikke så hyggelig å si, men jeg forstod ikke en døyt av språket altså, forstod matematikken... men nå er jeg jo ikke veldig språklig av meg heller da Lenke til kommentar
baronKanon Skrevet 24. mai 2004 Rapporter Del Skrevet 24. mai 2004 flöde = flyt ljud = lyd tyst = stille Observera dock att värdena endast gäller vid fritt flöde Verdiene gjelder kun ved fri luftflyt Skakke være såå vanskelig å forstå svensk! forstod matematikken... da er jo alt greit Lenke til kommentar
White_Tiger Skrevet 25. mai 2004 Rapporter Del Skrevet 25. mai 2004 Da er det bare opp til noen å redigere om hele listen da Lenke til kommentar
Olle P Skrevet 26. mai 2004 Rapporter Del Skrevet 26. mai 2004 Jag har gjort nya beräkningar enligt formeln 10000 * (Luftflöde) / (10^((Ljudnivå) / 10)). Enheten blir ungefär m^5/W*h. - Multiplikationen med 10000 är bara för att slippa en massa decimaler. - För fläktar med variabel hastighet har jag valt maxvärdena (som ger sämst resultat). - Mikroplex anger alla värden avrundade till heltal, vilket ger stora felmarginaler. Därför anger jag både "rakt" värde (med två värdesiffror) och intervall. - Jag har bara räknat på de fläktar vars värden anges på Mikroplexs sammanställningssida för varje storlek. - Större värde är, som tidigare, bättre. 20x20mm TFD2008L12S = 40 (18-67) 25x25mm TFD2510L12C = 150 (112-200) 252N = 950 (700-1240) 30x30mm TFD3007L12S = 1010 (780-1270) 40x40mm PC4010L12S = 500 (390-640) TFD4007L12C = 350 (290-420) 412F = 200 (170-240) 412FH = 113 (95-134) 412FM = 755 (620-920) 412H = 180 (150-210) 412 = 1600 (1340-1900) 45x45mm TFD4510L12B = 690 (590-810) 50x50mm PC5010L12S = 400 (310-510) TFD501012CT = 220 (190-260) TFD5015L12C = 330 (280-380) 512F = 200 (170-230) 60x60mm TFD601012CT = 320 (280-370) TFD6010L12S = 320 (280-370) 612FH = 260 (230-300) 612F = 580 (510-660) TFD602012CT = 700 (620-800) 612NGN = 130 (114-147) 612N2GN = 130 (114-147) 612FL = 4800 (4100-5500) 612N2GH = 73 (64-83) 612NGH = 73 (64-83) 612N2GM = 560 (490-630) 612N2GHH = 28 (25-32) 612NGHH = 28 (25-32) 612N2GL = 5300 (4600-6100) 612N2GML = 3100 (2700-3600) TFD6025M12C = 630 (560-720) TFDA6025M12C = 630 (560-720) FFB0612EHE = 3,4 (3,0-3,8) 70x70mm TFD7015L12C = 1080 (950-1230) TFD7025L12C = 1310 (1150-1480) 80x80mm TFD8025L12S = 2100 (1900-2400) ZMF1 = 260 (230-290) PC8015L12C = 3200 (2800-3600) ******* PC8020L12C = 1600 (1370-1800) TFD802512CT = 870 (770-990) UC8FAB = 420 (370-480) 8412N2GH = 160 (140-180) 8412N2G = 440 (390-490) TFDA8025M12C = 1700 (1500-2000) 8412N2GME = 1460 (1290-1600) KOVS2B = 3800 (3400-4300) AD0812DBA70GL = 11000 (9800-12400) 8412N2GMLE = 5700 (5000-6400) SCLFM1580T = 3700 (3300-4200) KOVS2L = 1500 (1350-1700) SCLFZ1580M = 5700 (5000-6400) KOVS2P = 600 (530-670) FFB0812EHE = 8,6 (7,6-10,0) ******* KOVS1 = 47 (42-53) 8412N2GL = 21000 (18000-24000) 92x92mm TFD9225L12S = 1600 (1450-1900) TFDA9225M12C = 1600 (1440-1800) ZMF2 = 230 (200-260) 3412NGM = 1140 (1010-1290) 3412NGH = 240 (210-270) 3412NGHH = 128 (114-145) 3412NG = 530 (470-600) 3412NGL = 3100 (2700-3500) UC9FAB = 560 (500-630) SCLFZ1592M = 3900 (3500-4400) 120x120mm ********* UC12FAB = 170 (150-190) 4412FGML = 720 (640-810) 4412FGL = 2400 (2100-2700) 4412FGM = 220 (200-250) SCLFZ1512M = 2100 (1800-2300) TFD1202512CT = 850 (750-950) TFD12025L12C = 1600 (1400-1800) KD1212PMB16A = 116 (103-131) TFDA12025M12C = 1340 (1190-1500) - Vi ser att det största spannet finns i 80mm-gruppen (följt av 60mm-gruppen); från 8,6 till 21000, en faktor mer än 2440! Jag är inte förvånad, eftersom 80mm är den vanligaste storleken och utbudet därför också är störst. - Tvärtemot gängse uppfattning ligger inte 12cm-fläktarna i topp. Ljudnivån är ju redan filtrerad efter örats upplevelse, så de lägre varvtalen är inräknade. - Papst 8412N2GL är både tystast och "effektivast" av alla. Detta förklaras av det (relativt) extremt låga varvtalet. Ljudnivån sjunker ju som bekant snabbare än flödet när man minskar hastigheten hos en fläkt. Alla andra fläktar i 8412-serien får samma värde om man sänker hastigheten till samma nivå. Så fort man ger fläkten lite mottryck att jobba mot sjunker flödet, och därmed effektiviteten, snabbt. /Olle Lenke til kommentar
