Read only on every file
On both my dics, 80gb and 40gb, one parted up in C: and D: - every file on each dics is read only, if i try to remove it to all subfolders and so on, it will just reset itself and be back to the way it was.. For example, if i try to change a skin or something at a game it will work one time, but when it closes and i start it up again, it will reset to default or the way it has always been.
Help.
P.S Format doesn't work.. Tried that ;)
ATTRIB [+R | -R] [+A | -A ] [+S | -S] [+H | -H] [[drive:] [path] filename]
      [/S [/D]]
 +   Sets an attribute.
 -   Clears an attribute.
 R   Read-only file attribute.
 /S  Processes matching files in the current folder
     and all subfolders.
 /D  Processes folders as well.
Try this on the game-folder you have problems saving a skin:
attrib -r "Path" /S /D
where Path is eg. C:\Games\Tetris
We had some problems at work with a data-folder resetting to Read-only and this solved the problem.
