Omega 4.5 ute nå
F!!! Nå må jeg bytte driver IGJEN! 3-4 gang denne mnd.
Stod at det skulle være "mye" nytt. Poster readme-fila når jeg er ferdig med DL.
Vent 2 min.
EDIT: finner ikke Readme'n jeg, men en nyhet er jo at atitool 0.0.20 følger med.
Endret av Lautsprecher
OMEGADRIVE here!
These are my "optimized" drivers for the ATI Radeon family of video cards.
What's New? (2k/XP 2.5.44)
* Based on the Catalyst 4.5 drivers.
* Updated the Omega version of RadLinker (1008), now the Profiler include options
 to enable TAA modes and to establish the desired TAA Threshold for D3D apps.
* Added and removed a LOT of tweaks, ATI changed some internal settings and some
 old tweaks won't work anymore from now on.
* Fixed support for Mobility 9700.
* Fixed the "Hibernation not working" problem in laptops.
* Added support for the Following laptop wide screen resolutions: 800x480,
 960x600, 1024x600, 1024x480, 1280x600, 1280x768, 1280x800, 1680x1050, 1920x1200
* Re-enabled a desktop wide resolution: 1280x768
* Added an EXCLUSIVE new Omega utility which adds the ability to SWAP between
 the soft-mod and the normal driver without the need to re-install the whole
 drivers. (Thanks to Chris W, Author of RadLinker)
* Removed Artifact Tester 5 from the package. (Sorry Alberto)
* Included the latest version of ATITool. (Thanks W1zzard)
* Since the package has grown in size I will be distributing the installer in
 compressed CAB format to save some bandwidth, it must be decompressed using one
 of these tools (latest version): WinAce, WinRAR or WinZip. Then run the extracted
 file to start installation of the drivers.
Important Notes:
1. If you are using an Omega soft-mod and you are experiencing crashes, black
  screens, artifacts or the "check board effect" during game play, run the new
  included Driver Swapper utility and select the Normal driver, the reason is
  that your card is not accepting the soft-mod due to broken/incompatible
  hardware.
REMINDERS:
1- If you have the normal ATI drivers installed, uninstall the ATI Control Panel
  BEFORE upgrading to these drivers, the Omega Drivers already have the CP
  integrated and another CP will cause conflicts or other problems.
2- There is no need to uninstall ANY previous drivers (ATI or OMEGA) when
  installing these, the new ones will overwrite any previous settings, but if
  you still want to uninstall them completely, is ok.
3- In Windows 2k/XP, ALWAYS disable DDC in the ATI "Displays/Monitor" CP after
  installing drivers to be able to use ALL the refresh rates and resolutions
  your monitor supports, also this is the best way to avoid the 60Hz RR bug.
4- The WDM drivers for VIVO and AIW cards are not included, but they can be
  downloaded separately from a link in my drivers page.
5- The Radeon cards do support FastWrites and they will work with it on
  (on some machines), but it is not recommended, there is NO SPEED gain
  when using FW, and this option will affect your PC's stability a LOT,
  most game crashes and problems are because FW is enabled.
6- Install the included Multires utility to have access to ALL the available
  resolutions in the Omega Drivers, standard Windows doesn't show all of them.
7- Always uninstall the previous version of RadLinker before installing the new
  one included in the latest Omega Drivers.
I don't recommend the use of ANY external tweakers with my drivers (specially
Rage3D Tweaker), as they override my special settings and will make my work
useless.  The only time I recommend a tweaker is when you have a specific
problem with a specific tweak and need to change it in order to make the drivers
work correctly.  Also if you use a tweaker for overclocking, FSAA, Gamma or
Aniso settings, is just fine, but you'll be better off using the integrated ATI
CP for that (which is ok by me if you change any setting in it).
If you have any problems with this drivers please go to my webpage and look in
the ATI help section for answers.  If still have problems look for the drivers
thread in www.driverheaven.net forums and let me know what is going on.
If you happen to find a new tweak or fix for a specific game or many games
and it proves that it works then drop me an E-Mail (don't post it in the
forums), I'll make sure credit will be granted to that person in this INFO file.
IMPORTANT: Don't bother ATI about these drivers as they are unsupported by them!
May GOD bless everybody!
O M E G A D R I V E
"Don't mess with the Best!"
http://www.omegacorner.com
for meg så funker Omega sine drivere bedre enn Ati sine.
Samme her, har ikke sett noen negative deler med Omega-driverene, eller jeg fikk problem med å kjøre et spill en gang, men det spillet var jo totalt ukjent uansett.
hehe, ukjente spill er alltid gøy :thumbs:
Jeg har aldri hatt noen problemer med Omega, bortsett fra at jeg scorer heftig bra i 3dmark 03 til min hardware å være :w00t:
Endret av Troy Henrik
Er ikke noen unormal score du har da.... Er det helt uten OC?
Omega gjør mye rart på gammel maskinvare.
Jeg scorer f.eks. kun 1500 i 3DMark03, men i 01 får jeg 18 000, takket være Omega. :)
er ikke det p.g.a. at 3dmark 01 går mest på cpu og 03 går på skjermkort?
Kan godt hende det, er ikke akkurat umulig, siden skjermkortet mitt henger litt bak CPU. :p
ja, vilke har du da? jeg får vertfall grei score i 03, men dårlig i 01... dette er igjen pga svak cpu (se profil).
Jeg sa score tidligere i tråden og maskinvare er på profilen min.
Dette er farlig mye off-topic nå, tror vi ska bevege oss on-topic.
