Zindre- Skrevet 31. mai 2004 Rapporter Del Skrevet 31. mai 2004 Alma mener du? BEST WEAPON USED: Dragon Sword. Nanchaku work well here too. BEST NINPO USED: Art of the Inferno (A huge key here) BOSS ATTACKS: Various quick attacks, slashes, and a powerful grab move. DIFFICULTY: Hard at first. Easy when you figure out a good method. My Strategy: The first time you face Alma, you are going to get obliterated, fast. Hitting her seems next to impossible, since she is the quickest boss you will experience so far, so you'll have to time your attacks to defeat her. Start off the battle having Art of the Inferno Ninpo equiped, for it is your best method of winning this battle. As the battle begins, charge up your Ninpo, and hit her with a fireball. She will immedtially be stunned, so quickly hit her with some sword or a Nanchaku combo to take down some nice precentage of her health. You most likely have 2 Ninpo at this point, and hopefully a few devil elixirs. Be sure to time your Ninpo, because Alma's speed allows her to dodge the fireball, which will not fare very well in defeating her. Keep stunning her with your Ninpo, and attempt to get her down to 3/4 of her health, give or take. If you run dry of Ninpo, the battle will get harder. You will have to work around her, and dodge around her attacks, jumping into the air and pressing the 'A' button works well in getting off some moderately powerful quick shots. Don't bother the lunge jump + Y attack, because you will go right through her, however, the jump + y downard attack does hit her, and does some nice damage as well. If managed to get her down with your Ninpo, then finished her off with some quick aerial attacks, this battle will be way easier than it looks. Other tips: The Bow and Arrow really helps. Just as you dodge her magic attack, hit her with the arrow. It doesn't cause much damage, but a few good hits can add up. Try to stay in mid range. If you get too far, she'll constantly use her magic and dash attacks. If you stay too close, she's lift you up and take out nearly half of your health. Sometimes, it helps have a more clear view of the battleground because the camera moves so fast. I suggest that you let her destroy all the surrounding pillars before you start attacking her. It will really open up the place. Lenke til kommentar
Asmodean Skrevet 31. mai 2004 Rapporter Del Skrevet 31. mai 2004 Fanta Boy Skrevet 30/05/2004 : 19:35 Lurer på om noen har greid og slå NG, tviler på at noen har gjort det, eller noen som kan greie det. Litt usikker på hva du mener, men hvis du lurer på om noen har klart spillet, så ja. Mange har klart spillet, til og med på Very Hard vanskelighetsgrad. Jeg har bare klart normal til nå. Lenke til kommentar
Asmodean Skrevet 31. mai 2004 Rapporter Del Skrevet 31. mai 2004 tentackle bossen var den letteste hittil. men jeg er inne i kirken og har vært inne i archive der jeg finner en golden scarabe osv men hvor skal jeg gå etter det? Gå til andreetasjen i archive og kikk oppover. Du ser at det er en tredje etasje. For å komme dit må du løpe oppetter veggen. Der må du bruke Incendiary Shurikens for å lage en åpning i døra og denge noen flere imps. På motsatt side av rommet er det et annet rom med en safe. Let på bordet etter en lapp som sier hvordan du skal åpne safen. (Ikke glem å ta statuetten som står på en pidestall der også.) Når du har åpnet boken skal du gå tilbake til hovedrommet i Katedralen og bruke det du fant i safen på alteret. Lenke til kommentar
Laman Skrevet 31. mai 2004 Rapporter Del Skrevet 31. mai 2004 Er på chapter 9 nå og skal slosse mot noen tankser, hvor mange er det? Jeg blir drept når den andre tanksen kommer. Lenke til kommentar
Asmodean Skrevet 31. mai 2004 Rapporter Del Skrevet 31. mai 2004 To. Et tips. Hvis du står helt på siden av den, like inntill, vil den kjøre rundt deg uten å kunne treffe deg (ved å kjøre på deg direkte, altså). For å ta den, så bruker du først en explosive arrow for å ta knerten på føreren og så et par APPSDS-piler etterpå før det kommer en ny fører. Gjenta dette. Burde være plankekjøring. Lenke til kommentar
Laman Skrevet 31. mai 2004 Rapporter Del Skrevet 31. mai 2004 To. Et tips. Hvis du står helt på siden av den, like inntill, vil den kjøre rundt deg uten å kunne treffe deg (ved å kjøre på deg direkte, altså). For å ta den, så bruker du først en explosive arrow for å ta knerten på føreren og så et par APPSDS-piler etterpå før det kommer en ny fører. Gjenta dette. Burde være plankekjøring. Virket bra det. Lenke til kommentar
Laman Skrevet 31. mai 2004 Rapporter Del Skrevet 31. mai 2004 Hvor finner man det store sverdet? Har så lyst på det og er redd for at jeg har gått forbi det. Er på chapter 9 nå, hvilket chapter kan man finne det på? Har sett en video fra Ninja Gaiden der han har sverdet da kirka fortsatt er hel - og da hadde han sverdet. Lenke til kommentar
Wyldelife Skrevet 31. mai 2004 Rapporter Del Skrevet 31. mai 2004 To. Et tips. Hvis du står helt på siden av den, like inntill, vil den kjøre rundt deg uten å kunne treffe deg (ved å kjøre på deg direkte, altså). For å ta den, så bruker du først en explosive arrow for å ta knerten på føreren og så et par APPSDS-piler etterpå før det kommer en ny fører. Gjenta dette. Burde være plankekjøring. Har du runna spillet?? Lenke til kommentar
Magus Skrevet 1. juni 2004 Rapporter Del Skrevet 1. juni 2004 Hvor finner man det store sverdet? Har så lyst på det og er redd for at jeg har gått forbi det. Er på chapter 9 nå, hvilket chapter kan man finne det på? Har sett en video fra Ninja Gaiden der han har sverdet da kirka fortsatt er hel - og da hadde han sverdet. Du får det av Muramasa når du har funnet et visst antall scarabs, husker ikke hvor mange. Lenke til kommentar
Laman Skrevet 1. juni 2004 Rapporter Del Skrevet 1. juni 2004 (endret) Hvor finner man det store sverdet? Har så lyst på det og er redd for at jeg har gått forbi det. Er på chapter 9 nå, hvilket chapter kan man finne det på? Har sett en video fra Ninja Gaiden der han har sverdet da kirka fortsatt er hel - og da hadde han sverdet. Du får det av Muramasa når du har funnet et visst antall scarabs, husker ikke hvor mange. Fett! edit : Noen som vet? Endret 1. juni 2004 av Laman Lenke til kommentar
mad2003 Skrevet 1. juni 2004 Rapporter Del Skrevet 1. juni 2004 Selgeren i Ninja gaiden Lenke til kommentar
Laman Skrevet 1. juni 2004 Rapporter Del Skrevet 1. juni 2004 Haha! Ich bin sehr glucklich! Jeg har fått sverdet og OPPGRADERT det til lvl.2! Når man oppgraderer det ser det annerledes ut. Skal oppgradere til lvl. 3 men det koster 20k. 20 scarabs må du gi Muramasa for å få det. Lenke til kommentar
Deathie Skrevet 1. juni 2004 Rapporter Del Skrevet 1. juni 2004 Haha!Ich bin sehr glucklich! Jeg har fått sverdet og OPPGRADERT det til lvl.2! Når man oppgraderer det ser det annerledes ut. Skal oppgradere til lvl. 3 men det koster 20k. 20 scarabs må du gi Muramasa for å få det. Hvor langt er du kommet nå egentlig? Jeg er på Chapter 7, og har gitt Maramusa 15 Scarabs... Har på følelsen at jeg har hoppet over noe Lenke til kommentar
Thewiz Skrevet 1. juni 2004 Rapporter Del Skrevet 1. juni 2004 Hvor mange Scarabs må man gi til muramasa for å få det sverdet? Lenke til kommentar
Asmodean Skrevet 1. juni 2004 Rapporter Del Skrevet 1. juni 2004 Hvor finner man det store sverdet? Har så lyst på det og er redd for at jeg har gått forbi det. Er på chapter 9 nå, hvilket chapter kan man finne det på? Har sett en video fra Ninja Gaiden der han har sverdet da kirka fortsatt er hel - og da hadde han sverdet. Dette er ikke mulig. Du må ha 20 Golden Scarabs for å få Dabiliharo og det får du først i kapittel 8. Du kan maks ha 19 Golden Scarabs i kapittel 7. Lenke til kommentar
Deathie Skrevet 1. juni 2004 Rapporter Del Skrevet 1. juni 2004 Hvor finner man det store sverdet? Har så lyst på det og er redd for at jeg har gått forbi det. Er på chapter 9 nå, hvilket chapter kan man finne det på? Har sett en video fra Ninja Gaiden der han har sverdet da kirka fortsatt er hel - og da hadde han sverdet. Dette er ikke mulig. Du må ha 20 Golden Scarabs for å få Dabiliharo og det får du først i kapittel 8. Du kan maks ha 19 Golden Scarabs i kapittel 7. Er dette på slutten av kapittel 7? Jeg har 15 og er på begynnelsen nå.. Lenke til kommentar
Asmodean Skrevet 1. juni 2004 Rapporter Del Skrevet 1. juni 2004 Les hva jeg sier da.. Du kan MAKS ha 19 Golden Scarabs i kapittel 7. Så ja, du har missa opptil 4 stk. Lenke til kommentar
Laman Skrevet 1. juni 2004 Rapporter Del Skrevet 1. juni 2004 (endret) Er på chapter 10 og har sverdet nå. edit : snart er denne tråden den største på "Diskuter Spill og tilbehør - Konsoll" . Endret 1. juni 2004 av Laman Lenke til kommentar
Deathie Skrevet 1. juni 2004 Rapporter Del Skrevet 1. juni 2004 Les hva jeg sier da.. Du kan MAKS ha 19 Golden Scarabs i kapittel 7. Så ja, du har missa opptil 4 stk. Har lest hva du sier... Men har man disse 19 Scarabsene på slutten eller begynnelsen av Chapter 7? Lenke til kommentar
