Mono er ute i første betaversjon
Novell is proud to introduce the first Beta release of Mono, an open source implementation the .NET framework for use on Linux, Unix and Windows System.
It includes a C# compiler, an implementation of the Common Language Infrastructure and two stacks of APIs: a Unix, Linux, GNOME, Mono stack for APIs that takes the most advantage of your Unix server and desktop and a set of APIs compatible with the Microsoft .NET Framework 1.1 that provides support for ASP.NET (web services and web forms), ADO.NET and many other components.
Incorporating key .NET compliant components: a C# compiler, and a portable execution system (that includes Just-in-Time and pre-compilation support), the Mono Project:
Provides a superior development environment for writing Linux applications with unprecedented productivity.
Allows developers to write rich client, web services and server-side applications and deploy them on Linux, Solaris, MacOS X, Windows NT/XP and various other Unix systems on a variety of architectures.
Delivers tools that facilitate the creation of product APIs and SDKs that are language independent across multiple operating systems.
Nyttige lenker:
Den offisielle Mono siden
MonoDevelop
Artikkel hos ItAvisen
Artikkel hos Digi.no
  • 1 måned senere...
