ilex Skrevet 9. april 2002 Rapporter Del Skrevet 9. april 2002 det heter fane.. akkurat som det heter skriveleif. f ordet skrevet riktig er passé. dessuten blir det sensurert =]. [ Denne Melding var redigert av: ilex på 2002-04-09 19:44 ] Lenke til kommentar
Mastbert Skrevet 9. april 2002 Rapporter Del Skrevet 9. april 2002 Prøv denna sida: http://www.xp-erience.org/sections.php?op=...ticle&artid=141 og kanskje denne sida også: http://www.tweakxp.com/tweakxp/display.asp?id=214 Lenke til kommentar
Kjellis Skrevet 9. april 2002 Rapporter Del Skrevet 9. april 2002 Har løsningen på problemet ditt, men hjelper ikke campere. Hater campere... :wink: rush - rush -rush! Lenke til kommentar
decker Skrevet 9. april 2002 Rapporter Del Skrevet 9. april 2002 SJEKK DETTE : Mouse acceleration tweak Written By: Ronnie | Authors Website: Visit | Views: 10743 | Print Tweak | 1/16/2002 Hi, Today I Found a tweak from "yiNXs" (who should get all the credit) wich actually resolves the "xp mouse acceleration bug". Most people who play games like quake3 and counterstrike know what I mean. There were some workarounds, but they never satisfied me. If you don't believe it; try it yourself! Here is the tweak: Background (yiNXs) The tweak was found by finding a logic order in the 64-bit hexa-decimal values at the below regestry-entries. When trying different values, you should come up with a diagram wich displays a curve, this is the unwanted acceleration. Adjusting the values that the curve becomes a straight line rosolves the mouse-acceleration. 1. Safe the following text to a .reg file and doubleclick it: Windows Registry Editor Version 5.00 [HKEY_CURRENT_USERControl PanelMouse] "SmoothMouseXCurve"=hex:00,00,00,00,00,00,00,00,00,a0,00,00,00,00,00,00,00,40, 01,00,00,00,00,00,00,80,02,00,00,00,00,00,00,00,05,00,00,00,00,00 "SmoothMouseYCurve"=hex:00,00,00,00,00,00,00,00,66,a6,02,00,00,00,00,00,cd,4c, 05,00,00,00,00,00,a0,99,0a,00,00,00,00,00,38,33,15,00,00,00,00,00 2. Reboot your computer Eller, last ned fix fila hær! http://www.unitednerds.com/files/mousefix.reg så skal du se allt blir SÅ MYE MYE bedre.. :wink: hehe, å slutt å camp! decker! Lenke til kommentar
Ullsokk Skrevet 9. april 2002 Forfatter Rapporter Del Skrevet 9. april 2002 Den linken funka ikke og jeg gidde ikke gjøre alt det andre drittet!!! Det jeg sa var: Den dagen skulle være EN CAMPEDAG! ikke 4ever..vanligvis er jeg som rambo! Lenke til kommentar
Ullsokk Skrevet 11. april 2002 Forfatter Rapporter Del Skrevet 11. april 2002 Hvor annet sted kan jeg laste ned den mousefix.reg fila?? linken funker ikke! Lenke til kommentar
Squeegie Skrevet 11. april 2002 Rapporter Del Skrevet 11. april 2002 Quote: On 2002-04-09 20:24, Kjellis skrev:Har løsningen på problemet ditt, men hjelper ikke campere. Hater campere... :wink: rush - rush -rush! newb Lenke til kommentar
Gabriel_X Skrevet 11. april 2002 Rapporter Del Skrevet 11. april 2002 Camper! (Hmmm - hvorfor bryr jeg meg egentlig om en CS-camper - jeg spiller jo bare Strike Force alikevel :wink: ) Første gang jeg spilte etter å ha lagt inn XP snudde jeg meg 5-6 ganger rundt bare jeg skulle snu meg til venstre (bruker BoomSlang 2000 innstilt på høy følsomhet). Av en eller annen grunn lar ikke mouse-acceleration seg fjerne helt (ihvertfall ikke hos meg) selv om man velger det bort i mouse-properties. Å disable mouse-acceleration hjalp ganske mye men det føltes alikevel litt merkelig - hvis man flyttet musa samme avstand ble det forskjellig resultat avhengig av hvor fort man flyttet den. Anbefaler deg å kjøre mousetweaken som er nevnt ovenfor (søk bare på 'win xp mouse acceleration tweak' hvis du ikke gidder å bruke et minutt på å punche inn verdiene ovenfor). Etter at jeg kjørte mousetweaken fungerer alt 'som før'. Forøvrig er det ingen av mine spill som fungerer dårligere i XP synes jeg. Lenke til kommentar
normal Skrevet 11. april 2002 Rapporter Del Skrevet 11. april 2002 Quote: On 2002-04-09 18:57, sanoj_20 skrev:Hvorfor er det egentlig så veldig populært med mellomrom mellom hver bokstav i "faen": F A E N.Eks.F A E N TA TELENORF A E N ta NextGenTelF A E N TA XPFinnes ikke disse da, eller husker jeg feil?Er "F A E N" mote? litt mer kraft i uttrykket da vet du Lenke til kommentar
