Hvordan åpne .dll -filer?
Steps to Use an Extension DLL
There are following steps required to perform by a client to use an extension dll.
1. Copy your extension class's header file to your project directory.
2. Link your project to the lib file of your dll.
3. Include header file of your class in your project's stdafx.h or cpp file.
4. Create Object of the class and call its member functions.
See how to create an extension dll in third part of this tutorial for more details.
Steps to Use a Regular DLL
1. Link to the Library. Copy your lib file to your test project directory. Or if you don't want to copy the lib file then enter your lib file with the path in Object/library modules text box.
2. Import functions. Import functions using __declspec. Write this code in the beginning of your cpp file.
extern "C" __declspec(dllimport) long AddTwoNumbers( long val1, long val2);
extern "C" __declspec(dllimport) long MultiplyTwoNumbers( long val1, long val2);
3. Call Functions. Add these public members to your dialog's header class.
int lSum = AddTwoNumbers( 12, 65 );
int lMultiplyRes = MultiplyTwoNumbers(12, 65) ;
Edit: link
http://www.mindcracker.com/mindcracker/c_c...l/dll_tut1l.asp
Endret av syar2003
Finner ikke noe om denne fila , så den kan du trygt unregistrere .
Antagelig noe som er fjernet/avinstallert som ligger igjen .
Åpne ett msdos prompt vindu og skriv:
regsvr32 /u C:\windows\system\F3RESTUV.DLL
Rett opp stien til filen , med riktige data for der den ligger lagret.
