..[fannt løsning selv].. (typelist-stuff)
GCC 3.4 (linux)
Edit:
Fannt løsning selv - og rettet opp koden under.
#include <iostream>
#define M_typelist1(T1) ::Oxymora::Typelist::Typelist<T1, ::Oxymora::NullT>
#define M_typelist2(T1, T2) ::Oxymora::Typelist::Typelist<T1, M_typelist1(T2) >
#define M_typelist3(T1, T2, T3) ::Oxymora::Typelist::Typelist<T1, M_typelist2(T2, T3) >
using namespace std;
namespace Oxymora {
/// Null type.
class NullT {};
namespace Typelist {
 /// Typelist.
 template<typename T, typename U>
 struct Typelist {
 	typedef T HEAD;
 	typedef U TAIL;
 }; // struct Typelist
 /// typeAt
 /** Return type at INDEX in TLIST as inner type result. */
 template<class TLIST, unsigned int INDEX>
 struct typeAt;
 template<typename HEAD, class TAIL>
 struct typeAt<Typelist<HEAD, TAIL>, 0> {
 	typedef HEAD result;
 }; // struct typeAt
 template<typename HEAD, class TAIL, unsigned int I>
 struct typeAt<Typelist<HEAD, TAIL>, I> {
 	typedef typename typeAt<TAIL, I - 1>::result result;
 }; // struct typeAt
 /// replace
 /** Replace T with U in TLIST, result is inner type result. */
 template<class TLIST, typename T, typename U>
 struct replace;
 struct replace<NullT, T, U> {
 	typedef NullT result;
 }; // struct replace
 template<typename T, class TAIL, typename U>
 struct replace<Typelist<T, TAIL>, T, U> {
 	typedef Typelist<U, TAIL> result;
 template<typename HEAD, class TAIL, typename T, typename U>
 struct replace<Typelist<HEAD, TAIL>, T, U> {
 	typedef Typelist<HEAD, typename replace<TAIL, T, U>::result> result;
}; // namespace Typelist
}; // namespace Oxymora
int main()
typedef M_typelist3(char, double, int) T1;
// Should replace int in T1 with char const* .. right?
typedef Oxymora::Typelist::replace<T1, int, char const*>::result T2;
Oxymora::Typelist::typeAt<T2, 2>::result cstr = "blah"; /* test.cpp:72: error: invalid conversion from `const char*' to `int' */
cout << cstr << endl;
return(0);
} // main()
Trøtt i trynet og ser ikke feilen - noen som ser noe?
Her er en versjon i farger:
http://nostdal.net/paste/b932305ba685d5041...6ce2d88c2a.html
(feilmeldnig er pastet som kommentar i koden)
Endret av søppel
