jvik Skrevet 14. mai 2004 Del Skrevet 14. mai 2004 http://www.gamespot.com/news/2004/05/14/news_6098402.html The Sapphire Toxic Radeon X800 cards will have a distinctive bright blue PCB (printed circuit board) and a large orange cooling fan. According to Sapphire, the cooling solution offers near silent performance while in operation. We didn’t get a chance to see or, more importantly, to listen to a sample card in action, but the fan unit does look like a low RPM design made for quiet operation. Cards will also feature copper plates and ramsinks for additional cooling. The fan unit will have an opening to accept a thermal diode for temperature monitoring, but users will have to purchase a 5.25” drive-bay LCD temperature display to take advantage of the feature. Sapphire Toxic cards will also offer an Automated Performance Enhancement (APE) software program that allows users to overclock the video card memory. Currently, ATI’s Overdrive technology only allows users to overclock the core graphics chip --Sapphire’s APE technology will give users access to the memory side. Sapphire will pre-qualify all the memory going onto Toxic boards, and the APE system will allow users to overclock the memory up to factory pre-tested speeds. Er dette noe du kommer til å kjøpe? Lenke til kommentar
Troy Henrik Skrevet 14. mai 2004 Del Skrevet 14. mai 2004 (endret) virka jo allright det der, men unødvendig å betale mer for å få et blått og orange kort, når man kan kjøpe lik kjøling for 169kr hos microplex (med mindre man syns at det kortet var abnormt tøft ) Endret 15. mai 2004 av Troy Henrik Lenke til kommentar
Manx Skrevet 14. mai 2004 Del Skrevet 14. mai 2004 Det så jo noe porno ut, og da mener jeg bra porno. Lenke til kommentar
PureTamil Skrevet 15. mai 2004 Del Skrevet 15. mai 2004 Hver sin smak, jeg synes det var litt småharry jeg Lenke til kommentar
Sneglen Skrevet 15. mai 2004 Del Skrevet 15. mai 2004 (endret) Jeg forbinder ordet Toxic med to ting, Britney Spears og fargen grønn. Tror jeg ville likt kortet bedre om knøledelen hadde vert grønn. Dessuten virket PCB fargen FOR blå. En lysere blå kunne gjordt seg. Konklusjon: Mangler de rette fargene. Edit: Oi! Knøledelen = Kjøledelen Endret 15. mai 2004 av -NeoRag- Lenke til kommentar
bearcarlsen Skrevet 15. mai 2004 Del Skrevet 15. mai 2004 Den var stygg! Nedstemt - neste takk *elske mitt blodrøde Sapphire 9800XT kort* Lenke til kommentar
genesis Skrevet 15. mai 2004 Del Skrevet 15. mai 2004 enda ingen som har kommet med dualv-dvi kort? hmm, kanskje det ikke skal gå rette veien alikevell. mangel på det derre shader 3 greiene, men den rolige og effektive kjølingen er bare positiv. da slipper man å bruke penger på det etterpå. (men videre ser man jo at slike kort er xtremt overpriset.....) Lenke til kommentar
Pansergnom Skrevet 15. mai 2004 Del Skrevet 15. mai 2004 (endret) enda ingen som har kommet med dualv-dvi kort? hmm, kanskje det ikke skal gå rette veien alikevell. mangel på det derre shader 3 greiene, men den rolige og effektive kjølingen er bare positiv. da slipper man å bruke penger på det etterpå. (men videre ser man jo at slike kort er xtremt overpriset.....) Hva skal man med pixelshader nu, når alle spill nå for tiden bruker 2.0...? Kommer ikke spille som vil ta i bruk pixelshader 3.0 før til neste år... Unreal engine 3 blant annet... Har hørt at farcry holder på å implementere dette i en patch men at den ikke gir noen vesentlig forskjell enda, og at de hadde noen andre problemer... x800 er ikke ren px 2.0 heller da, en slags "oppgradert" versjon med noen 3.0 funksjoner kan vi vel kalle det .... Dessuten EIER Ati Nvidia når d gjelder AA .. d + AF teller mye for meg Endret 15. mai 2004 av MetiCx Lenke til kommentar
BeFs Skrevet 15. mai 2004 Del Skrevet 15. mai 2004 -NeoRag-; Toxic har vel ingen ting med grønn å gjøre? Hvis atomavfall lyser, så lyser det svakt rosa/lilla/blå. Lenke til kommentar
Dazem Skrevet 15. mai 2004 Del Skrevet 15. mai 2004 (endret) oooh den så SEXY ut!! tror det blir mitt neste kort jah.. Edit: (bare ett utrykk!!!) ikke tro jeg er geek.. jeg har liv til de grader da så ;p Endret 15. mai 2004 av Dazem Lenke til kommentar
jokki Skrevet 15. mai 2004 Del Skrevet 15. mai 2004 Kortet virket litt for mye eeeeh "photoshop" spør du meg. Fargene i bakgrunnen ødela pluss at PCB virker litt for blå. Bright blue stod det i teksten øverst. Kommer nok ikke til å kjøpe dette kortet, ettersom jeg like gjerne kan kjøpe samme kjøling for 150 kr på netshop. Lenke til kommentar
TDK Skrevet 15. mai 2004 Del Skrevet 15. mai 2004 JUKS! DEt er jo akkurat samme kjøleren som HIS sitt X800pro IceQ 2. HIS hjemmeside Lenke til kommentar
Kingy Skrevet 15. mai 2004 Del Skrevet 15. mai 2004 JUKS!DEt er jo akkurat samme kjøleren som HIS sitt X800pro IceQ 2. HIS hjemmeside så likheten med engang, kanskje de har kjøpt rettighetene...(er det en patentert kjøleløsning?) ser bra ut og vil sikkert se bedre ut i opplyste kabinetter men ikke noe for almennheten. Lenke til kommentar
Robin B Skrevet 15. mai 2004 Del Skrevet 15. mai 2004 Vel den type kjøle-løsning er noe jeg kan tenke meg slik at jeg kan få varmluften utav kabinettet. Så da har jeg 2 leverandører å velge mellom om det blir et nytt kort fra Ati. Lenke til kommentar
notarget Skrevet 15. mai 2004 Del Skrevet 15. mai 2004 Synes det var stilig. a 5.25-inch drive-bay LCD temperature display to take advantage of the feature Lenke til kommentar
bureaucrator Skrevet 15. mai 2004 Del Skrevet 15. mai 2004 Man kunne besten få inntrykk av at det var noen som gikk og ventet på å kjøpe nytt grafikkort om dagen... Lenke til kommentar
TheDarkListener Skrevet 15. mai 2004 Del Skrevet 15. mai 2004 Ganske tøfft, digg bundle og Lenke til kommentar
Holmesdale End Skrevet 15. mai 2004 Del Skrevet 15. mai 2004 Man kjøper da vel ikke grafikkort etter fargene! Makan. Lenke til kommentar
