wiak Skrevet 13. mai 2004 Del Skrevet 13. mai 2004 (endret) se bare her så? :=) http://ocfaq.com http://www.akiba-pc.com/article.php?41.0 ------------- ------------- hva har dere lært i dag? at ATITool clocker best ny ATITool versjon i dag http://atitool.ocfaq.com 13 May 2004 Version 0.0.20 Position of the main window is saved now Rendering in a remote desktop session is now disabled Added info box: "ATITool will not work with TemporalAA enabled" Added "dump bios" function - please report back with which cards this is not working Sliders now default to 0.4x to 1.6x of frequency Hotkey in profile properties shows "none" if no hotkey is set Radeon 9100 IGP is no longer incorrectly detected as supported chip - this fixes a bluescreen/reboot issue, thanks Valar Fixed sys driver problem where bios address would be incorrectly detected - this fixes a bluescreen/reboot issue, thanks Gaston Made the background a bit less red on non-ps 2.0 cards. Added support for R420 overclocking Fixed 'load on windows startup' not working when your installation path had a space in it. Fixed disappearing entry in taskbar when settings are active. Fixed small tooltip typo. Changed code to reduce big frequency jumps (which sometimes results in crashes), max. change is 16 Mhz in 10 ms. Changing AA/AF settings now resets display adapter. Added temperature monitoring for 9600XT, 9800XT, X800 Fixed frequencies not switching back when leaving 3D mode. A quick fix for this is in earlier versions is to enable 'play sound when leaving 3d mode'. List clock speeds with profile in combobox Fixed buggy characters in comment of auto-created default profile. Code cleanup Endret 13. mai 2004 av wiak Lenke til kommentar
klikko Skrevet 15. mai 2004 Del Skrevet 15. mai 2004 har du i det hele tatt lest de sidene du legger ut? den høye klokken der skyldes jo at han kjøler kortene med tørris.... og ikke ati-tool --- ville jeg tro hvertfall.. Lenke til kommentar
AvIOn Skrevet 24. mai 2004 Del Skrevet 24. mai 2004 Klikko: Er vel ikke Atitool som skal ha skryt for det resultatet der nei. Heller en kombinasjon av en av de råeste i verden til å sette opp data med helt sjuke kjøleløsninger og konge Hardware. Lenke til kommentar
arnosmith Skrevet 24. mai 2004 Del Skrevet 24. mai 2004 nå dreit du deg så veldig ut asså! *ler seg skakk* Lenke til kommentar
Nikkor Skrevet 24. mai 2004 Del Skrevet 24. mai 2004 (endret) Visst jeg bruker R9800Pro kan jeg klokke kortet mitt til 400/364, visst jeg bruker AtiTool kan jeg klokke det til 600/1000 =O Jeg sier bare AtiTool ruler. Edit: *IRONI*, noen folk som ikke skjønner sånnt, så måtte bare si ifra. Endret 24. mai 2004 av Nikkor Lenke til kommentar
arnosmith Skrevet 24. mai 2004 Del Skrevet 24. mai 2004 (endret) Visst jeg bruker R9800Pro kan jeg klokke kortet mitt til 400/364, visst jeg bruker AtiTool kan jeg klokke det til 600/1000 =OJeg sier bare AtiTool ruler. dette er nesten urkomiskt... gidder ikke bruke tid på å kommentere det nærmere... Endret 24. mai 2004 av arnosmith Lenke til kommentar
Lufen Skrevet 24. mai 2004 Del Skrevet 24. mai 2004 Visst jeg bruker R9800Pro kan jeg klokke kortet mitt til 400/364, visst jeg bruker AtiTool kan jeg klokke det til 600/1000 =OJeg sier bare AtiTool ruler. men har du da testa kortet? nei fordi jeg jo også sette mitt kort opp til 1000/1000000000 men det vil ikke funke fordi kortet ikke klarer det samme som du kan jo vri på spedometeret slik at det viser mer en det du kjører i men du kjører jo ikke fortere Lenke til kommentar
Axentrix Skrevet 24. mai 2004 Del Skrevet 24. mai 2004 Visst jeg bruker R9800Pro kan jeg klokke kortet mitt til 400/364, visst jeg bruker AtiTool kan jeg klokke det til 600/1000 =OJeg sier bare AtiTool ruler. du er herved nominert til ok.no`s avstemning på tåpligst innleg ever Du kan jo stille opp på det, men du kan jo prøve å trykke "set clock".............. Lenke til kommentar
Axentrix Skrevet 24. mai 2004 Del Skrevet 24. mai 2004 Jeg tulla da. det håper jeg indelig for ditt eget beste må si jeg lo godt av posten din iallefall Lenke til kommentar
Lautsprecher Skrevet 24. mai 2004 Del Skrevet 24. mai 2004 (endret) Jeg tulla da. Du "brær deg unna i velkjent tater-stil" som en kompis av meg ville sagt. Endret 24. mai 2004 av Lautsprecher Lenke til kommentar
Axentrix Skrevet 24. mai 2004 Del Skrevet 24. mai 2004 Jeg tulla da. Du vrir deg unna "i velkjennt tater-stil" som en kompis av meg ville sagt. Lenke til kommentar
mistabeen Skrevet 24. mai 2004 Del Skrevet 24. mai 2004 Er vel heller de som ikke skjønte ironien som burde melde seg på hw.no's "tåpeligste innlegg konkurransen"... (Bare til en liten opplysning, det her var også ironi...) Lenke til kommentar
Axentrix Skrevet 24. mai 2004 Del Skrevet 24. mai 2004 for en ironi-fylt tråd.... Lenke til kommentar
Nikkor Skrevet 24. mai 2004 Del Skrevet 24. mai 2004 (endret) Jeg tulla da. Du vrir deg unna "i velkjennt tater-stil" som en kompis av meg ville sagt. Seriøst? *redd* Endret 24. mai 2004 av Nikkor Lenke til kommentar
arnosmith Skrevet 24. mai 2004 Del Skrevet 24. mai 2004 Jeg tulla da. Du vrir deg unna "i velkjennt tater-stil" som en kompis av meg ville sagt. Seriøst? *redd* tja, du burde iallefall være forsiktig med slike hodeløse kommentarer... Lenke til kommentar
Lautsprecher Skrevet 24. mai 2004 Del Skrevet 24. mai 2004 Hodeløs kommentar? Jeg? No irony here. Lenke til kommentar
arnosmith Skrevet 24. mai 2004 Del Skrevet 24. mai 2004 Hodeløs kommentar?Jeg? No irony here. haha, nei ikke deg, men personen som påsto at han bare tulla, jeg er helt enig med deg, lol Lenke til kommentar
Lautsprecher Skrevet 24. mai 2004 Del Skrevet 24. mai 2004 (endret) Ja, han har mye bra kommentarer han kompisen min. Endret 24. mai 2004 av Lautsprecher Lenke til kommentar
