Robin B Skrevet 7. mai 2004 Del Skrevet 7. mai 2004 Overklokket til 715/639 http://www.beyond3d.com/forum/viewtopic.php?t=12227 BARCELONA, Spain -- May 7, 2004 -- ATI Technologies (NASDAQ:ATYT - News; TSX:ATY - News) demonstrated the awesome graphics power of the RADEON X800 XT Platinum Edition visual processing unit (VPU) by setting new graphics speed records(i) in a variety of games and industry-leading graphics benchmarks. The event took place at System Builders' Summit in Barcelona. Notably, a new world record score of 15,738 was set in Futuremark's 3DMark2003 graphics benchmark, easily breaking the previous score of 10,008, which was also set using ATI graphics technology. The record score of 15,738 in 3DMark2003 was set using the default screen resolution of 1024x768 pixels with 32-bit color depth, as required by Futuremark for eligibility in Futuremark's Hall of Fame. A record score of 33,484 was also set in Futuremark's popular 3DMark2001 benchmark at the same resolution. "The RADEON X800 XT Platinum Edition is clearly the weapon of choice for setting graphics speed records," said graphics enthusiast Sami Makinen, who designed, assembled and operated the PC used to set the record graphics scores. "ATI truly delivers monster performance with their latest generation of graphics technology." Scores in UT2004 (147 fps) and Tomb Raider (76 fps) were posted using the most demanding image quality settings commonly used by the gaming community: 1600x1200 pixels with 32-bit color depth using 4X anti-aliasing and 8X anisotropic filtering. "Record scores in some of the world's most visually advanced games at the highest image quality settings is proof that with ATI's RADEON X800 XT Platinum Edition, users no longer need to sacrifice speed to get impeccable image quality," said Peter Edinger, Vice President, ATI Europe, Middle East and Africa. All applications were run on a system featuring an overclocked RADEON X800 XT Platinum Edition running at 715 MHz engine clocks and 639 MHz memory clocks, an overclocked Intel® Pentium® 4 Processor, 1 GB of DDR SDRAM, a 40 GB IDE hard drive, proprietary cooling technology, and CATALYST drivers that conform to the Futuremark specification for posting Hall of Fame benchmark scores. Also this year at Systems Builders' Summit, ATI took home three prestigious awards including Best Presentation, Best Hardware and Best Vendor. Lenke til kommentar
Troy Henrik Skrevet 7. mai 2004 Del Skrevet 7. mai 2004 (endret) VILT her er noen bilder fra "the event" Ser at noen lurer på hvorfor de ikke bruker Flytende nitrogen, det er vel 2 gode grunner til det. 1. TørrIS koster 29kr pr.kg (har kjøpt selv) i Norge og man trenger ikke noe dyrere transport middel for TørrIs enn en vanlig kjølebag 2. Flytende Nitrogen koster mer en 100kr litern (som ikke er så dyrt) men derimot hvis du skal frakte det så må du ha en beholder som ikke er rent billig, rundt 10'000kr eller mer koster det for sånne beholdere + at det er litt skumlere å bruke noe som holder -196 grader imot noe som holder -76 grader Men igjen VILT Endret 8. mai 2004 av Troy Henrik Lenke til kommentar
Goophy Skrevet 7. mai 2004 Del Skrevet 7. mai 2004 x800 kjølt med tørris før det kom i butikken, jaja, ikke dårlig det. Skulle gjerne sett bilder av den faktiske scoren da... Får se om jeg kan slå den med tørrisprosjektet mitt på r9800p neste uke da Lenke til kommentar
bamsefar Skrevet 7. mai 2004 Del Skrevet 7. mai 2004 Ser ut som om det ikke kommer en eneste molex på PCI-E versjonen. Lenke til kommentar
Malvado Skrevet 7. mai 2004 Del Skrevet 7. mai 2004 Hmm, da er spørsmålet hvor mye kortet kan klokkes med en vannkjøling, 24/7. Er vell egentlig det som er mest spennende og ikke hva som er mulig i 1/2 time maks... Blir ikke akkurat så mye spilling ut av det... Lenke til kommentar
Debauchery Skrevet 7. mai 2004 Del Skrevet 7. mai 2004 Stilig Men svarte til kjøling Lenke til kommentar
Gjest Slettet-80wCWpIM Skrevet 7. mai 2004 Del Skrevet 7. mai 2004 imponerende score, men jeg er egentlig mer opptatt av hva kortet får når det overklokkes med luft og vannkjøling.. Lenke til kommentar
rener Skrevet 7. mai 2004 Del Skrevet 7. mai 2004 <Drooling> Tenk da det dei kan få til med LN2-kjøling (-196º Celsius)... Ojojojojojjo, X800XT-PE med PCI-Express og LN2..... <Drooling status="continous"> Lenke til kommentar
Admin'c Skrevet 7. mai 2004 Del Skrevet 7. mai 2004 tenk hva de kunne klart med flytende nitrogen/helium eller hva de bruker. Tror nvidia er på rett spor men litt sent igjen Lenke til kommentar
Goophy Skrevet 7. mai 2004 Del Skrevet 7. mai 2004 (endret) <Drooling>Tenk da det dei kan få til med LN2-kjøling (-196º Celsius)... Ojojojojojjo, X800XT-PE med PCI-Express og LN2..... <Drooling status="continous"> Joda hadde vært noe det. Men noe jeg ikke skjønner er at de ikke bruker flytende hydrogen istedet for nitrogen. Det er jo 70-80 grader kaldere. Når de bruker så mye ressurser kan de uansett koste på seg litt dyrere kjøling... Edit: Ojda, litt off-topic, men det går vel greit? Endret 7. mai 2004 av Goophy Lenke til kommentar
Gjest Slettet-10579 Skrevet 7. mai 2004 Del Skrevet 7. mai 2004 Damer, drinker og fet hardware.... Damn - jeg er i feil yrke ser det ut til. Lenke til kommentar
Lacim Skrevet 7. mai 2004 Del Skrevet 7. mai 2004 PCIe-utgaven hadde også en vesentlig svakere kjøler... Lenke til kommentar
rener Skrevet 7. mai 2004 Del Skrevet 7. mai 2004 Kan vere et tegn på mindre varmeutvikling... Noke som er bra for overklokkere.. Lenke til kommentar
rener Skrevet 7. mai 2004 Del Skrevet 7. mai 2004 (endret) EDIT: Trippelpost... Internette klikka litt Endret 7. mai 2004 av rener Lenke til kommentar
oblivian Skrevet 7. mai 2004 Del Skrevet 7. mai 2004 Utrolig, tenk på hva de kunne få til på Pluto!! Da kunne jeg spillt hele natten Lenke til kommentar
cyberho Skrevet 7. mai 2004 Del Skrevet 7. mai 2004 (endret) PCIe-utgaven hadde også en vesentlig svakere kjøler... hvis du tenker på bildene som det er linket til tidligere i posten var det et R380 Pro, hvis jeg ikke husker helt feil. Endret 7. mai 2004 av cyberho Lenke til kommentar
