AGP/PCI lock
either its the max of your cpu, you need to increase the vcore, or you need to increase the vdimm. so you may up ending needing a new 2.4 if you want to go higher. might be a need a 3:2 divider but i doubt it since the ram isnt running much over 200mhz. also you need to check your bios options... lock the agp/pci (66/33) if you didnt - things like that.
if you try these things and they dont work then i have a 2.4 that can go to 290 or so that ill sell to you. PM if you interested.... try those things above first. the vcore is good up to 1.7 for p4.
Er det riktig?
Endret av marcen
