Windoge Skrevet 4. mai 2004 Del Skrevet 4. mai 2004 Hva synes dere om dette : http://www4.ncsu.edu/~eghalley/ace.jpg Lenke til kommentar
Zeph Skrevet 4. mai 2004 Del Skrevet 4. mai 2004 Er det med ein desktop mod eller? Lenke til kommentar
Windoge Skrevet 4. mai 2004 Forfatter Del Skrevet 4. mai 2004 Er det med ein desktop mod eller? I følge det jeg har lest skal det være med 4.5 driveren, altså ikke en mod. Lenke til kommentar
Gjest Slettet-80wCWpIM Skrevet 4. mai 2004 Del Skrevet 4. mai 2004 fra rage3d.com (gammelt intervju) LR: You are the MAN when it comes to software so what can we expect to see in the near future. Can you drop us any hints as to what is in store in the near Future. Terry: Something big is coming for CATALYST in the next 2-3 months. It will take graphic drivers to a brand new level, and of course will be another ATI first. It will be interesting to see how long before other companies will copy the concept after we launch it. LR: Many readers have asked us when they can expect equal-quality driver support for GNU/LINUX systems as they get with Windows systems. What is ATI's plan for driver support for LINUX-based operating systems? Terry: Well, if you look at installed base of PC users I think Windows accounts for roughly 95 per cent of the users out there. We have to balance our resources in a similar manner. Having said that, Linux is very important for us and we are committed to supporting it.. Recently we brought Linux support under the CATALYST marketing umbrella, and with this increased visibility you can expect higher quality Linux drivers from ATI in the next 6-12 months. Lenke til kommentar
TDK Skrevet 4. mai 2004 Del Skrevet 4. mai 2004 FETT design! Håper driverne gir bedre ytelse også Lenke til kommentar
Jakartabebopp Skrevet 4. mai 2004 Del Skrevet 4. mai 2004 jajaja, håper de er like bra som de ser bra ut, da Lenke til kommentar
*Magnus* Skrevet 4. mai 2004 Del Skrevet 4. mai 2004 KONGE display håper Omega vill beholde de og Lenke til kommentar
Windoge Skrevet 4. mai 2004 Forfatter Del Skrevet 4. mai 2004 KONGE display håper Omega vill beholde de og Mest sannsynelig vil Omega beholde det Lenke til kommentar
MuD Skrevet 4. mai 2004 Del Skrevet 4. mai 2004 FETT design!Håper driverne gir bedre ytelse også jepp... Lenke til kommentar
OgnOmm Skrevet 4. mai 2004 Del Skrevet 4. mai 2004 Omega med xp utseende.. Men for all del.. blir sikkert lekende lett å sette opp flerskjerm systemer med tv o.l. med dem. Skulle vært mulig å brukt 2 skjermer OG tv samtidig Lenke til kommentar
notarget Skrevet 4. mai 2004 Del Skrevet 4. mai 2004 Fint med utseende, men jeg holder alltid en knapp på ytelse når det dreier seg om drivere. Lenke til kommentar
Kultom Skrevet 4. mai 2004 Del Skrevet 4. mai 2004 Jeg for min del håper nyere drivere fra ATI kan forbedre multi-display mulighetene til Grafikk-kortene deres. Lenke til kommentar
tivolieselet Skrevet 4. mai 2004 Del Skrevet 4. mai 2004 mitt håp er at de kommer med linux driver som går ann å instalere,, de har rotet alt for mye på linux siden til at de fortjener noe posetiv kritikk. Lenke til kommentar
