DirectX nettverks problemer
Hei!
Jeg har problemer med å spille Rise Of Nations. "Unable to establish a network connection. Please check your network connection and try again". Så jeg søkte litt om omkring på google og fant ut at jeg måtte forwarde en del porter. Ja alt er gjort nå, og det siste jeg skulle gjøre var å sjekke directx sin nettverktab om det fantes noen error der. Og det var det ja. 4 forskjellige errors. Jeg hadde DX90a så innstallerte jeg DX90B og fortsatt er feilmeldingene her.
Her er errorloggen
System Information
Time of this report: 5/4/2004, 14:47:11
Machine name: LTT-WONDER
Operating System: Windows XP Professional (5.1, Build 2600) (2600.xpclient.010817-1148)
Language: English (Regional Setting: Norwegian (Bokmål))
System Manufacturer: NVIDIA
System Model: AWRDACPI
BIOS: Phoenix - AwardBIOS v6.00PG
Processor: AMD Athlon XP, MMX, 3DNow, ~1.8GHz
Memory: 512MB RAM
Page File: 176MB used, 1073MB available
Windows Dir: E:\WINDOWS
DirectX Version: DirectX 9.0b (4.09.0000.0902)
DX Setup Parameters: Not found
DxDiag Version: 5.03.0001.0902 32bit Unicode
DxDiag Notes
DirectX Files Tab: No problems found.
Display Tab 1: No problems found.
Sound Tab 1: No problems found.
Music Tab: No problems found.
Input Tab: No problems found.
Network Tab: The registry information for the service provider 'DirectPlay8 TCP/IP
Service Provider' is missing or damaged. You should reinstall DirectX. The registry
information for the service provider 'DirectPlay8 IPX Service Provider' is missing or
damaged. You should reinstall DirectX. The registry information for the service provider
'DirectPlay8 Modem Service Provider' is missing or damaged. You should reinstall DirectX.
The registry information for the service provider 'DirectPlay8 Serial Service Provider' is
missing or damaged. You should reinstall DirectX. You should reinstall DirectX to get the
latest version. Problems were found in the system registry. Details are available in the
saved text file.
DirectX Debug Levels
Direct3D: 0/4 (n/a)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (n/a)
DirectMusic: 0/5 (n/a)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
DirectPlay Service Providers
DirectPlay8 TCP/IP Service Provider - Registry: Error, File: ()
DirectPlay8 IPX Service Provider - Registry: Error, File: ()
DirectPlay8 Modem Service Provider - Registry: Error, File: ()
DirectPlay8 Serial Service Provider - Registry: Error, File: ()
Internet TCP/IP Connection For DirectPlay - Registry: OK, File: dpwsockx.dll
(5.03.0000.0900)
IPX Connection For DirectPlay - Registry: OK, File: dpwsockx.dll (5.03.0000.0900)
Modem Connection For DirectPlay - Registry: OK, File: dpmodemx.dll (5.03.0000.0900)
Serial Connection For DirectPlay - Registry: OK, File: dpmodemx.dll (5.03.0000.0900)
DirectPlay Voice Wizard Tests: Full Duplex: Not run, Half Duplex: Not run, Mic: Not run
DirectPlay Test Result: Not run
Registry Errors Found:
Key 'HKCR\DirectPlay8Address.Address.1\CLSID' is missing.
Key 'HKCR\DirectPlay8Address.Address.1' is missing.
Key 'HKCR\DirectPlay8Address.Address\CurVer' is missing.
Key 'HKCR\DirectPlay8Address.Address\CLSID' is missing.
Key 'HKCR\DirectPlay8Address.Address' is missing.
Key 'HKCR\CLSID\{934A9523-A3CA-4BC5-ADA0-D6D95D979421}\VersionIndependentProgID' is missing.
Key 'HKCR\CLSID\{934A9523-A3CA-4BC5-ADA0-D6D95D979421}\ProgID' is missing.
Key 'HKCR\CLSID\{934A9523-A3CA-4BC5-ADA0-D6D95D979421}\InprocServer32' is missing.
Key 'HKCR\CLSID\{934A9523-A3CA-4BC5-ADA0-D6D95D979421}' is missing.
Key 'HKCR\DirectPlay8Lobby.LobbiedApplication.1\CLSID' is missing.
Key 'HKCR\DirectPlay8Lobby.LobbiedApplication.1' is missing.
Key 'HKCR\DirectPlay8Lobby.LobbiedApplication\CurVer' is missing.
Key 'HKCR\DirectPlay8Lobby.LobbiedApplication\CLSID' is missing.
Key 'HKCR\DirectPlay8Lobby.LobbiedApplication' is missing.
Key 'HKCR\CLSID\{667955AD-6B3B-43CA-B949-BC69B5BAFF7F}\VersionIndependentProgID' is missing.
Key 'HKCR\CLSID\{667955AD-6B3B-43CA-B949-BC69B5BAFF7F}\ProgID' is missing.
Key 'HKCR\CLSID\{667955AD-6B3B-43CA-B949-BC69B5BAFF7F}\InprocServer32' is missing.
Key 'HKCR\CLSID\{667955AD-6B3B-43CA-B949-BC69B5BAFF7F}' is missing.
Key 'HKCR\DirectPlay8Lobby.LobbyClient.1\CLSID' is missing.
Key 'HKCR\DirectPlay8Lobby.LobbyClient.1' is missing.
Key 'HKCR\DirectPlay8Lobby.LobbyClient\CurVer' is missing.
Key 'HKCR\DirectPlay8Lobby.LobbyClient\CLSID' is missing.
Key 'HKCR\DirectPlay8Lobby.LobbyClient' is missing.
Key 'HKCR\CLSID\{3B2B6775-70B6-45AF-8DEA-A209C69559F3}\VersionIndependentProgID' is missing.
Key 'HKCR\CLSID\{3B2B6775-70B6-45AF-8DEA-A209C69559F3}\ProgID' is missing.
