Hvor raskt er Bluetooth?
Hvor raskt er bluetooth på mobil/mobil og mobil/pc?
jeg fant dette etter å google:
Q. What is the bandwidth of Bluetooth wireless technology?
A.  Bluetooth wireless technology is designed to support a data rate that provides more than enough bandwidth for the designated usage models.
Bluetooth wireless technology has raw data rate of up to 1Mbps
Bluetooth requires that a low-cost transceiver chip be included in each device. The tranceiver transmits and receives in a previously unused frequency band of 2.45 GHz that is available globally (with some variation of bandwidth in different countries). In addition to data, up to three voice channels are available. Each device has a unique 48-bit address from the IEEE 802 standard. Connections can be point-to-point or multipoint. The maximum range is 10 meters. Data can be exchanged at a rate of 1 megabit per second (up to 2 Mbps in the second generation of the technology). A frequency hop scheme allows devices to communicate even in areas with a great deal of electromagnetic interference. Built-in encryption and verification is provided.
distansen er jo 100m med enkelte enheter... jaja resten ser ok ut
her er samenligning med andre netverksenheter http://www.thetravelinsider.info/roadwarri...t/bluetooth.htm
Endret av Admin'c
For å sitere meg selv:
Til telefon: 14.4 kilobyte/sek.
Fra telefon: 24.2 kilobyte/sek.
Telefonen er en Nokia 3650 som lå ca. tre meter fra PC. Signaltyrken lå stabilt på god. Testfilen var på 13MB og ble overført med PC-Suite. Bloetoothadaperet var et MSI BToes med Vidcomm 1.4.2.B10 software.
Antar at det på telefonen er begrenset av at det emuleres en serieport. Med en iPAQ og LAN-profilen har jeg sett opp mot ca. 45KB/s effektivt.
