Ny ver. av Patje's Mobility Modding
Finnes her: http://www.driverheaven.net/patje/
Fikk følgende mail:
Hi, This is a mass mail to all Modtool users who ever mailed me about a problem or just a friendly thanks.
Driverheaven, my hometown, celebrates their 2 year existence today (1th of May)
The 2 year anniversary of DH called for something special.
This version is the most complete modder you will find.
I'll hit you straight with it:
- Changed the setup files, now the Catalyst files installs the way it was meant to be, including the control panel.
- Added support for the Mobility Radeon 9700.
- You now have the option to mod the files only for your card, which speeds up the modding.
- And with the new layout (Credit goes to Craig5320!) people who where experiencing *.ocx errors, those are gone as well.
- Possible resolution fixes for some cards. (Did not have the chance to test on all cards, send me some laptops and I will )
If there are any suggestions you have about the tool let me know.
Info fra hjemmesiden:
This page will tell you all about the DH Mod tool V2.0
This program modifies certain files from the catalyst set so you can install the latest catalyst set on your laptop.
Supported cards:
- Mobility Radeon 9600
- Mobility Radeon 9700
- Mobility Fire GL 9000
- Mobility Radeon 9000
- Mobility Radeon 9200
- Radeon Mobility
- Radeon Mobility 7500
- Radeon Mobility 7800 GL
- IGP 340M /345M
- IGP 320M
- ATI MOBILITY FIRE GL T2
kan jeg med 320IGP fra Ati, øke oppløsningen på skjermen til ,mer  enn 1024 x 768 ??
Det er vel skjermen som setter begrensningen.... du kan sette den større men får ikke sett hele skjermen
EDIT:
Skaven: UTEN patje's modder?
Endret av JEG76
  • 3 uker senere...
  • 3 uker senere...
  • 4 måneder senere...
La inn Omegadrivere men vil helst kjøre ATIs drivere... Er det bare meg som har problemer med å modde ATI driverene? Har prøvd begge versjonene man kan laste ned fra www.ati.com og har prøvd å modde dem flere ganger. Har mobililty radeon 9700
  • 2 uker senere...
jeppp jeg har også problem med å modde den nyeste ati driverene, var ikke noe problem å modde de gamle ati driverne, men ver 4.10 får jeg ikke til å virke i det hele tatt etter å ha moddet dem. Er derfor tvunget til å bruke omega driverne selv om jeg helst ville bruke de originale ati driverne, hmm er litt frustrert jeg nå da.
mvh nerd-light
mvh nerd-light
Er en guide til hvordan du fikser dette på driverheaven.
