Spragleknas Skrevet 1. mai 2004 Del Skrevet 1. mai 2004 (endret) -> POST SVAR HER <- Finnes her: http://www.driverheaven.net/patje/ Fikk følgende mail: Hi, This is a mass mail to all Modtool users who ever mailed me about a problem or just a friendly thanks. Driverheaven, my hometown, celebrates their 2 year existence today (1th of May) The 2 year anniversary of DH called for something special. This version is the most complete modder you will find. I'll hit you straight with it: - Changed the setup files, now the Catalyst files installs the way it was meant to be, including the control panel. - Added support for the Mobility Radeon 9700. - You now have the option to mod the files only for your card, which speeds up the modding. - And with the new layout (Credit goes to Craig5320!) people who where experiencing *.ocx errors, those are gone as well. - Possible resolution fixes for some cards. (Did not have the chance to test on all cards, send me some laptops and I will ) If there are any suggestions you have about the tool let me know. Info fra hjemmesiden: This page will tell you all about the DH Mod tool V2.0 This program modifies certain files from the catalyst set so you can install the latest catalyst set on your laptop. Supported cards: - Mobility Radeon 9600 - Mobility Radeon 9700 - Mobility Fire GL 9000 - Mobility Radeon 9000 - Mobility Radeon 9200 - Radeon Mobility - Radeon Mobility 7500 - Radeon Mobility 7800 GL - IGP 340M /345M - IGP 320M - ATI MOBILITY FIRE GL T2 Endret 3. mai 2004 av JEG76 Lenke til kommentar
Rebel-Rider Skrevet 3. mai 2004 Del Skrevet 3. mai 2004 Kvalifiserer dette som en nyhet?? Lenke til kommentar
Novec Skrevet 3. mai 2004 Del Skrevet 3. mai 2004 Jada, gjør det sikkert. Jeg hadde ikke hørt om programmet i det hele tatt, må jeg dessverre innrømme... Lenke til kommentar
Spragleknas Skrevet 3. mai 2004 Forfatter Del Skrevet 3. mai 2004 ... det vil jeg si! Det er en nye (og bedre?) ver. av et prg. som modder Catalyst drivere slik at du kan bruke de i bærbare datamaskiner. Driverene til bærbare oppdateres sjelden, og kan kun skaffes gjennom produsenten (ikke via ATI). Dette er a) en nyhet b) et modde-tool ... og hører vel da hjemme under overklokking og nyhet. Har postet den under bærbare datamaskiner og ... håper det er ok. Dette skyldes at de med bærbare sjeldent kikker inn på OKs sider (siden de ENDA ikke har hatt en guide ang. klokking og modding av bærbare - rart egentlig! - les denne tråden: http://forum.hardware.no/index.php?showtopic=168659&hl= ) Lenke til kommentar
Spragleknas Skrevet 3. mai 2004 Forfatter Del Skrevet 3. mai 2004 -> Hva om vi fortsetter tråden her? <- Lenke til kommentar
Novec Skrevet 3. mai 2004 Del Skrevet 3. mai 2004 Godt forslag, JEG76. Denne tråden stenges, da det er mer liv i den andre. Lenke til kommentar
