Robin B Skrevet 1. mai 2004 Del Skrevet 1. mai 2004 (endret) Da kan man vel også slå fast at X800XT kommer til å bli fryktelig dyrt. Det eneste vi mangler nå er klokke hastigheten på Gpu/Minne. http://www.allstarshop.com/shop/product.as...C71XN9HSTJ27C2# ATi RADEON X800 PRO 256MB DDR AGP8X TVO/DVI (Retail) Built by ATi 12 parallel pixel pipelines 256-bit quad-channel GDDR3 memory Interface 8 extreme parallel pixel pipelines 6 parallel vertex processing engines Our Price: $499.00 Pre-Order (ETA:05/07/2004) The ATI RADEON™ X800 PRO delivers frame rates that surpass any previous graphics processor making it the world’s most powerful VPU. With up to two times the performance of the acclaimed RADEON™ 9800 PRO, the RADEON™ X800 PRO provides an extremely smooth, responsive HD gaming experience, putting capable gamers in complete control of even the most demanding game titles. A radically new architecture based on the latest .13 micron, low-k manufacturing process with ultra fast and efficient GDDR3 memory combine to produce extreme data rates and unbelievable acceleration in a quiet, cool, single-slot solution. BREAKTHROUGH IMAGE QUALITY The RADEON™ X800 PRO defines a totally new High-Definition Gaming experience for the avid gamer by maximizing performance and image quality in higher detail and at higher resolutions than ever before. ATI‘s new and revolutionary 3Dc™ image enhancement technology brings characters to life and scenery to greater realism by enabling significant improvements to the image detail of character art with increased performance and lower memory usage. 3Dc™ is slated to become the industry standard to support more complex high-definition visual effects in real time. ADVANCED 3D ARCHITECTURE The RADEONTM X800 PRO features SMARTSHADER™ HD, the most advanced pixel shader engine with 12 parallel pixel pipelines capable of an incredible 6 igapixels/second fill rate in full precision! With six programmable vertex shader pipelines, capable of up to 7000 million vertices per second and an overall capability of over 140 million floating point operations per second(Giga FLOPS), the RADEON™ X800 PRO delivers the most beautifully rendered high-definition 3D animation for the ultimate in intense, interactive game play. CUTTING EDGE VIDEO TECHNOLOGY The RADEON™ X800 PRO gives you more than just a great gaming experience. It also has sophisticated video processing, filtering and acceleration features that make multimedia applications more efficient, inspiring and fun. With VIDEOSHADER™ HD, the RADEON™ X800 PRO takes advantage of its advanced shader processing engine for user programmable video effects, video quality enhancement, and encoding and decoding of many video standards, including MPEG1/2/4, Real Media, DivX and WMV9. The RADEON™ X800 PRO also supports the latest high-definition and wide display formats, giving users bigger and more vivid movie, gaming and Internet experiences. SMARTSHADER™ HD Support for Microsoft® DirectX® 9.0 programmable vertex and pixel shaders in hardware Direct X 9.0 Vertex Shaders Vertex programs up to 65,280 instructions with flow control Single cycle trigonometric operations (SIN & COS) Direct X 9.0 Extended Pixel Shaders Up to 1,536 instructions and 16 textures per rendering pass 2nd generation F-buffer technology accelerates multi-pass pixel shader programs with unlimited instructions 32 temporary and constant registers Facing register for two-sided lighting 128-bit, 64-bit & 32-bit per pixel floating point color formats Multiple Render Target (MRT) support Complete feature set also supported in OpenGL® via extensions SMOOTHVISION™ HD 3Dc™ - Normal map image compression technology resulting in high detail image quality 2x/4x/6x Anti-Aliasing modes Sparse multi-sample algorithm with gamma correction, programmable sample patterns, and centroid sampling Lossless Color Compression (up to 6:1)at all resolutions, including widescreen HDTV resolutions Temporal Anti-Aliasing 2x/4x/8x/16x Anisotropic Filtering modes Up to 128-tap texture filtering Adaptive algorithm with bilinear (performance) and trilinear (quality) option 3DC™ High quality 4:1 Normal Map Compression Works with any two-channel data format HYPER Z™ HD 3-level Hierarchical Z-Buffer with Early Z Test Lossless Z-Buffer Compression (up to 48:1) Fast Z-Buffer Clear Z Cache optimized for real-time shadow rendering Optimized for performance at high display resolutions, including widescreen HDTV resolutions VIDEOSHADER™ HD Seamless integration of pixel shaders with video in real time FULLSTREAM™ video de-blocking technology for Real, DivX, and WMV9 formats VIDEOSOAP™ noise removal filtering for captured video MPEG1/2/4 decode and encode acceleration DXVA Support Hardware Motion Compensation, iDCT, DCT and color space conversion All-format DTV/HDTV decoding YPrPb component output for direct drive of HDTV displays Adaptive Per-Pixel De-Interlacing and Frame Rate Conversion (temporal filtering) Specifications Controller ATi RADEON X800 PRO Bus Type AGP 4X / 8X Memory 256MB 256-bit GDDR3 RAMDAC Dual 400MHz Monitors Supported Dual Max Resolution 2048x1536 @ 85Hz Connector (s) 15-pin VGA DVI-I S-Video Out TV-Out Yes Video-In No Built-in TV Tuner No Additional Information Windows Me/2000/XP The above specifications are for reference only. Please contact the original manufacturer for the most updated specifications Endret 1. mai 2004 av Robin B Lenke til kommentar
Dollar Skrevet 1. mai 2004 Del Skrevet 1. mai 2004 (endret) Lurer på om Half-Life 2 kuppong følger med Endret 1. mai 2004 av Dollar Lenke til kommentar
Templar Skrevet 1. mai 2004 Del Skrevet 1. mai 2004 Skjønner ikke dette.. 8 parallel Xtreme pipelines og så 12 Parallel pipelines. Simon Lenke til kommentar
kirjogra Skrevet 1. mai 2004 Del Skrevet 1. mai 2004 står klar til og bestille nu men er litt usikker om jeg skal vente til x800xt kommer. Lenke til kommentar
Ducky Skrevet 1. mai 2004 Del Skrevet 1. mai 2004 dette er forhånds bestilling. Det er vel dyrere å fohånds bestille korte? Lenke til kommentar
MistaPi Skrevet 1. mai 2004 Del Skrevet 1. mai 2004 Skjønner ikke dette.. 8 parallel Xtreme pipelines og så 12 Parallel pipelines. Simon 8 av de 12 pipelinene er ekstreme? Vel, jeg tror nok ikke det er langt ifra sannheten. Lenke til kommentar
genesis Skrevet 1. mai 2004 Del Skrevet 1. mai 2004 skuffende at ATi kjører så xtreme priser. Får vente en stund ja....... jeg har troen på at dette kortet(og XT) vil knekke hva Nvidia har vist oss til nå. Estimert tid før dette koster under 2500kr? Lenke til kommentar
Lacim Skrevet 1. mai 2004 Del Skrevet 1. mai 2004 $499 for det kortet... Det tror jeg blir dyrt per FPS... Lenke til kommentar
kirjogra Skrevet 1. mai 2004 Del Skrevet 1. mai 2004 bare ikke kortet koster over 15 000-, fikk igjen på skatten . menjeg vil ha xt NU Lenke til kommentar
Robin B Skrevet 1. mai 2004 Forfatter Del Skrevet 1. mai 2004 Ser ut til at X800Pro og 6800U blir liggende i samme prisklasse, med X800XT til en pris på rundt 6000+ her til lands? Er dette tilfellet så bør X800Pro slå 6800U for å rettferdig gjøre prisen. Lenke til kommentar
genesis Skrevet 1. mai 2004 Del Skrevet 1. mai 2004 nå som PCI ekspress kommer, vil det jo ikke være en hovedport for grafikk kortet slik det er med en stk AGP port per.idag (eller?) vil man da kunne kjøre 2stk(++) slike grafikk kort (ja jeg har kraftig nok PSU) ? Kan man utnytte VPU/GPU i det ene skjermkortet sammen med den andre, for å få bedre ytelse? Kan man kjøre 2stk programmer? på 2(/4) skjermer? eks. dobbelt opp med flihtsimulator. Dette er jo mye dødtid i dette spillet uansett...... Lenke til kommentar
capy Skrevet 1. mai 2004 Del Skrevet 1. mai 2004 5000 norske kroner er ikke mer enn det eldre toppmodeller har kostet før, så det er jo ikke så dyrt. Lenke til kommentar
kirjogra Skrevet 1. mai 2004 Del Skrevet 1. mai 2004 bu hu jeg får ikke til og bestille det. Lenke til kommentar
Robin B Skrevet 1. mai 2004 Forfatter Del Skrevet 1. mai 2004 Pricewatch melder at de er klar til å sende det om 3-4 dager til samme pris som ovenfor. Håper at ingen forhånds-bestiller før de har sett kortet i aksjon. http://www.pricewatch.com/1/37/6017-1.htm Lenke til kommentar
Bruun Skrevet 1. mai 2004 Del Skrevet 1. mai 2004 Blir ikke kortet lansert om 4 dager? jeg venter til jeg ser en test før jeg eventuelt bestiller noe... Lenke til kommentar
kirjogra Skrevet 1. mai 2004 Del Skrevet 1. mai 2004 ok trur jeg venter da. men vil helst ha xt Lenke til kommentar
sub1343 Skrevet 1. mai 2004 Del Skrevet 1. mai 2004 Lurer på om Half-Life 2 kuppong følger med denne gangen er sikkert halflife 3 kupong med Lenke til kommentar
Lex-Icon Skrevet 1. mai 2004 Del Skrevet 1. mai 2004 (endret) Åh....begynner å bli utålmodig. Venter på hw.no's test av 6800U og venter på lansering av ATi-kortene og venter på tester av disse! EDIT: Tror R500 har kommet før half-life 2 har kommet. (Venter også på Half-life 2) Endret 1. mai 2004 av Lex-Icon Lenke til kommentar
SuperDeformed Skrevet 1. mai 2004 Del Skrevet 1. mai 2004 Når det står ETA - 05/07 <- betyr det 5. juli eller 7. mai? Lenke til kommentar
Cthulhu Dawn Skrevet 1. mai 2004 Del Skrevet 1. mai 2004 Når det står ETA - 05/07 <- betyr det 5. juli eller 7. mai? 7. mai Lenke til kommentar
