Komplett med 250Gb kort fra Epox
Sneglen
Ser slettes ikke verst ut dette hovedkortet:
Specifications of mainboard
• 6x PCI slots
• 1 x AGP 8 x Slot colour coded purple
• 3 x DDR400 DIMM slots
• 4 SATA ports by Sil3114 including RAID 0, 1, 10 & 5
• 1 Floppy drive controller - 2 serial ports - 1 parallel port
• 2 standard IDE ports for ATA-133, backwards compatible with ATA-33/66/100
• 8 USB 2.0 ports (4 by rear panel, 4 by front panel option)
• Onboard sound, 8 channel Jack Sensing ALC850 Audio with environmental effects
• Onboard SATA with nVRAID utility for 2 ports (allows combining SATA & PATA drives for RAID configuration through unified driver)
• Standard ATX format 305 x 245mm
• Onboard NVidia Gigabit LAN thru Cicada 8201 PHY with Network Access Manager
• Onboard hardware firewall with driver access
• Onboard P80P diagnostics LED
• 12v adapted power scheme for CPU voltage
• Onboard Coaxial and Optical SPDIF outputs
• Ability to run both 32bit and 64bit operating systems natively
Power BIOS features
• Fully adjustable Voltage scheme with VDimm and VccCore as well as VDD
• Fully adjustable Frequency scheme and fine memory hone and AGP/PCI Lock
• Magic Flash for web BIOS update
• Magic Screen for custom boot display
• Magic Health for quick reading of vital measurements at POST
Les mer om det her:
http://www.epox.org/products/mainboards/8kda3/]
Endret av snorreh
Bør vel vente til jeg ser en review med nyeste BIOS. Så ikke så imponerende ut, iom at Epox K8T800 er "andrevalget" mitt. Har meget lyst på nForce3 250Gb kort, men om det ikke er bedre enn dette så vet jeg sannelig ikke om det er verdt det. Som sagt, får vente på BIOS update og andre tester. :yes:
