theDurkan Skrevet 29. april 2004 Del Skrevet 29. april 2004 Jeg har neotrace, og jeg skjønt eikke alt som var der. jeg pinge rn ip, men den viser meg bare informasjon om de som levere nettet til personen. Jeg pinget meg selv, og jeg får bare en linje mellom Bergen og Oslo. Og den gir meg info om NGT sine lokaler osv... Dessuten er det ikke alle jeg får info om. Hvorfor ikke? NOTICE AND TERMS OF USE: You are not authorized to access or query our WHOIS database through the use of high-volume, automated, electronic processes. The Data in Network Solutions' WHOIS database is provided by Network Solutions for information purposes only, and to assist persons in obtaining information about or related to a domain name registration record. Network Solutions does not guarantee its accuracy. By submitting a WHOIS query, you agree to abide by the following terms of use: You agree that you may use this Data only for lawful purposes and that under no circumstances will you use this Data to: (1) allow, enable, or otherwise support the transmission of mass unsolicited, commercial advertising or solicitations via e-mail, telephone, or facsimile; or (2) enable high volume, automated, electronic processes that apply to Network Solutions (or its computer systems). The compilation, repackaging, dissemination or other use of this Data is expressly prohibited without the prior written consent of Network Solutions. You agree not to use high-volume, automated, electronic processes to access or query the WHOIS database. Network Solutions reserves the right to terminate your access to the WHOIS database in its sole discretion, including without limitation, for excessive querying of the WHOIS database or for failure to otherwise abide by this policy. Network Solutions reserves the right to modify these terms at any time. ---------------------------------------------------------------------------- You agree that you will not reproduce, sell, transfer, or modify any of the data presented in response to your search request, or use of any such data for commercial purpose, without the prior express written permission of Domaininfo AB - <a href= http://domaininfo.com/default.asp?ref=100 >domaininfo.com</a> Register your name in 200+ top level domains at http://www.domaininfo.com <a href= http://domaininfo.com/default.asp?ref=100 >domaininfo.com</a> ---------------------------------------------------------------------------- Registrar:domaininfo.com Domain Name: NEXTGENTEL.COM [Owner of domain name] NextGenTel AS P.O. Box 3 Sandsli Bergen, N-5861 NO [Administrative contact] Nilsen, Bj rn Postboks 3 Sandsli 5861 Bergen NO Email: [email protected] Phone: +47 55 527900 [Technical contact] Aune, Cato NextGenTel AS Verftsgata 4 N-7014 Trondheim NO Email: [email protected] Phone: +47 73 54 23 95 [Zone contact] Aune, Cato NextGenTel AS Verftsgata 4 N-7014 Trondheim NO Email: [email protected] Phone: +47 73 54 23 95 Record created: 17 Nov 1999 Record last changed: 28 Oct 2002 Record expires: 17 Nov 2005 Name servers according to DNS : dns01.nextgentel.net dns02.nextgentel.net The previous information has been obtained either directly from the registrant or a registrar of the domain name other than Network Solutions. Network Solutions, therefore, does not guarantee its accuracy or completeness. Dette er infoen når jeg pinger meg selv. Kan jeg poste infoen jeg får når jeg pinger hw.no? slik at deer får to forskjellige eksempler på infoen jeg får? Lenke til kommentar
PureTamil Skrevet 29. april 2004 Del Skrevet 29. april 2004 Neotrace er primært laget for å traceroute, altså spore ruten, til en server. Dette er grunnen til at du får opp en linje mellom Oslo og Bergen på kartet. Videre gjør den oppslag i ymse whois-databaser (domener, RIPE etc.) og gir deg informasjonen du har limt inn i innlegget ditt. Hvis du bare skal pinge en server for å teste responstid, evt. pakketap etc. anbefaler jeg deg heller å bruke "ping"-kommandoen i Windows' kommandolinje eller det utmerkede programmet Pingplotter (søk på Google for å finne det, orker ikke finne frem URL til deg). Lenke til kommentar
gspr Skrevet 29. april 2004 Del Skrevet 29. april 2004 Jeg har neotrace, og jeg skjønt eikke alt som var der. jeg pinge rn ip, men den viser meg bare informasjon om de som levere nettet til personen. Jeg pinget meg selv, og jeg får bare en linje mellom Bergen og Oslo. Og den gir meg info om NGT sine lokaler osv...Dessuten er det ikke alle jeg får info om. Hvorfor ikke? Du kan ikke traceroute deg selv til din egen lokalisasjon. ISPene binder ikke informasjon om DEG til din IP, og bra er det. IPen din er eid av NGT, og du "sporer" derfor deg selv til NGTs hovedkontor i Bergen, siden det er NGT som eier IPen din. Lenke til kommentar
jocke Skrevet 29. april 2004 Del Skrevet 29. april 2004 Du kan ikke traceroute deg selv til din egen lokalisasjon. ISPene binder ikke informasjon om DEG til din IP, og bra er det. IPen din er eid av NGT, og du "sporer" derfor deg selv til NGTs hovedkontor i Bergen, siden det er NGT som eier IPen din. Vel, det beror litt på. Jeg har pinget mange IP'er selv med traceroute, og fått omtrent plassering - selv på "private" ip'er. Lenke til kommentar
