PS2..
For PS/2 communications, there are bandwidth considerations, primarily for absolute data
reporting. In relative mode, VersaPad (and every Microsoft compatible mouse) sends 40
reports per second through the PS/2 port to a Microsoft compatible driver. Each report
consists of 3 bytes of data. Each byte consists of 1 start bit, 8 bits of data, 1 parity bit and
1 stop bit, for a total of 11 bits. Thus, the data throughput required is:
PS/2 Relative Mode
40 reports x 3 bytes x 11 bits = 1,320 bits per second
To communicate Absolute mode data requires 5 times as much data. In Absolute mode,
VersaPad sends 100 reports per second through the PS/2 port to the VersaPad driver.
Each report consists of 6 bytes. Each byte consists of 1 start bit, 8 bits of data, 1 parity bit
and 1 stop bit, for a total of 11 bits. Thus the data throughput required is:
PS/2 Absolute Mode
100 reports x 6 bytes x 11 bits = 6,600 bits per second
The normal maximum throughput of a PS/2 port is 10,000 bits per second, shared
between the PS/2 port and the keyboard port. If every PS/2 port, from every
manufacturer, made available the full 10,000 bits per second, then the complete Absolute
mode communications would always function properly.
http://66.102.9.104/search?q=cache:T51RmlK...d&hl=en&start=2
