hvem har best ruting til usa
har firstmile vdsl:
Pinging 64.37.104.103 with 32 bytes of data:
Reply from 64.37.104.103: bytes=32 time=146ms TTL=112
Tracing route to Cisco1.VSK.GS-103 [64.37.104.103]
over a maximum of 30 hops:
1 1 ms <1 ms <1 ms 192.168.1.1
2 3 ms 3 ms 4 ms GigabitEthernet-P8.NH13.firstmile.no [217.199.56.1]
3 5 ms 5 ms 4 ms ge-0-1-1.2937.no-oslms001-pe-1.utfors.net [217.199.46.253]
4 13 ms 13 ms 13 ms ge-0-1-0.dk-glpms001-pe-1.tu.telenor.net [212.105.101.110]
5 14 ms 13 ms 13 ms ge-1-2-0.200.ar2.CPH1.gblx.net [208.51.198.173]
6 14 ms 13 ms 14 ms pos8-0-2488M.cr1.CPH1.gblx.net [67.17.65.197]
7 44 ms 44 ms 44 ms pos0-0-2488M.cr1.LON3.gblx.net [67.17.64.34]
8 45 ms 44 ms 45 ms so6-0-0-2488M.ar2.LON3.gblx.net [67.17.66.2]
9 36 ms 36 ms 37 ms Level-3public-peering.ge-5-0-0.ar2.LON3.gblx.net [208.51.239.162]
10 36 ms 37 ms 36 ms ae-0-54.mp2.London1.Level3.net [212.187.131.146]
11 111 ms 111 ms 111 ms as-0-0.bbr1.NewYork1.Level3.net [4.68.128.106]
12 145 ms 145 ms 146 ms so-0-0-0.mp2.StLouis1.Level3.net [64.159.0.57]
13 145 ms 145 ms 146 ms ge-7-2.hsa2.StLouis1.Level3.net [64.159.4.138]
14 146 ms 146 ms 146 ms Level3GigE.cybercon.com [63.208.32.186]
15 146 ms 146 ms 147 ms Cisco1.VSK.GS-103 [64.37.104.103]
Trace complete.
Pinging 69.56.170.199 with 32 bytes of data:
Reply from 69.56.170.199: bytes=32 time=219ms TTL=51
Reply from 69.56.170.199: bytes=32 time=225ms TTL=51
Reply from 69.56.170.199: bytes=32 time=232ms TTL=51
Tracing route to 69-56-170-199.theplanet.com [69.56.170.199]
1 1 ms 1 ms 1 ms 192.168.1.1
2 4 ms 4 ms 4 ms GigabitEthernet-P8.NH13.firstmile.no [217.199.56.1]
3 4 ms 4 ms 4 ms ge-0-1-1.2937.no-oslms001-pe-1.utfors.net [217.199.46.253]
5 14 ms 14 ms 13 ms ge-1-2-0.200.ar2.CPH1.gblx.net [208.51.198.173]
6 13 ms 14 ms 13 ms pos8-0-2488M.cr1.CPH1.gblx.net [67.17.65.197]
7 149 ms 150 ms 148 ms pos9-0-2488M.cr1.DAL1.gblx.net [67.17.94.6]
8 150 ms 150 ms 149 ms so0-0-0-2488m.ar1.dal2.gblx.net [67.17.73.30]
9 243 ms 246 ms 248 ms The-Planet.ge-0-2-1.ar1.DAL2.gblx.net [64.213.176.150]
10 252 ms 249 ms 256 ms car1-2-v1.dllstx2.theplanet.com [12.96.160.12]
11 243 ms 248 ms 244 ms 69-56-170-199.theplanet.com [69.56.170.199]
Trace complete.
Endret av opticus
Odin sa:
EN SAK VIL JEG SI HAWKIE.DE OPPLYSNINGENE DU KOMMER MED ER VEL IKKE ALLMENN KUNNSKAP?
Mente ikke å kalle deg idiot, ser senere at det kanskje kunne se sånn ut. Ville bare lære deg at det er et dumt spørsmål, men det er jo ikke lett å vite når man ikke kan alt dette med routing osv.
Grei løsning da er jo å gjøre som du nå har gjort å legge ut de IP addressene som du skal connecte mest til og be om traceroutes, men husk at du bør be bare de i ditt nærområde å legge ut traceroutes, siden de er de som vil gi det riktigste bildet.
2 brukere med samme ISP som ligger på forskjellige områder kan nemlig få helt vanvittig foskjellige resultater avhengig av:
1. Hvilken utenlands gateway som brukes fra det området. Eksempel her er Tele2 som på sørlandet bruker en gateway til danmark fra kristiansand, mens Oslo området får en gateway som går over stockholm.
2. Hvor godt oppsatt det lokale routing oppsettet er, noe som kan variere stort etter kunnskapen til den lokale routing administratoren.
Vel lykke til uansett.
Får over 160 når jeg pinger.
Bor i Drammen her (ngt)
Sjekk ut om noen med Catch kan pinge her.
Jobbet med en som hadde catch sdsl før.han spilte mye på engelske servere og sa han hadde knallbra ping.
Endret av Mio
takk mio.ja av en eller annen grunn er min ping også veldig bra i england,er veldig glad for det men spiller hovedsakelig i usa.det som er litt synd er at pingen min bare går oppover for tiden her hjemme.virker som at noe er litt ustabilt en eller annen plass,vet bare ikke hva.
