C/windows/system 32/system 32.exe
Hei søkte litt på google (google is ur friend ;))
og kom fram til dette:
Had this problem myself and got rid of it this way. I've used an antivirus to cleanup my disks any demo version will do, mine was Panda. then go to startup/ execute and type: regedit you will now see your registry in the menu bar go to edit/ find and type in: system 32.exe that will locate the keys you should clean. it is in Hkey_Local_machine/software/Microsoft/Windows NT/WinLogon/ on the right panel locate the key: shell explorer.exe c:\windows\system32\systeme32exe double click on shell and leave only explorer.exe there you go next time you reboot the bug will be gone.
Håper det hjelper....
edit: Velkommen til forumet foresten...
Endret av _Finch_
