hvordan vise FPS i FC?
\r_displayinfo 1 i console for å vise FPS
edit: søkte litt på google.com og fant console commandoer til FC server hvis noen er interisert i dem:
Farcry Server Comands (2 reactions)
FC: Console Commands For admin.
I’ve seen lots of new admins asking me what do I have to download to be a admin?
-Well you don’t download anything, You just have to know some syntax command’s.
You enter these commands in console.
-To access console press the ~ button on the upper left side of your keyboard.
-You should now have a green looking screen that pops down. If you so it then your in console.
Here are the list of Rcon commands For admins
\cl_rcon_serverip "yourserversip" (this command is used to type rcon commands, from in the game,but off of the server, this command is useful if your server is full)
\cl_rcon_password "your rcon password" Type this on the server by itself, or off of the server after typing the above cl_rcon_server_ip command.
\rcon listplayers (gives list of ips)
\rcon kickid id <-the second id being the actual number.
\rcon banid id <-to ban someone ingame.
*note you can also ban by cd key , and IP using punkbuster. The info is obtained from log file.
\rcon pb_sv_banguid guid <-guid being the guid assigned to the players ip address
\rcon pb_sv_banmask ip <-ip being the players ip address
To change the map:
\rcon sv_changemap map gametype
example: \rcon sv_changemap mp_dune assault , will change the map to mp_dune with assault gametype.
map names are:
assault:
mp_dune
mp_airstrip
mp_dam
mp_mangoriver
mp_jungle
mp_freighter
TDM/FFA
mp_monkeybay
mp_monkeybay_n
mp_surf
mp_radio
mp_cliffside
\rcon sv_restart will restart the map
\rcon sv_restart 10 <-will restart the map in ten seconds, any number may be used.
Game Rule commands:
\rcon gr_timelimit "time"
\rcon gr_scorelimit "score"
\rcon gr_friendlyfire "1" for on "0" for off
\rcon gr_nextmap "mapname" to set the next map
*note gr_ commands require a map restart.
__________________________________________________
________________
Color Codes (for Names and Servernames)
$0 (Black)
$1 (White)
$2 (Blue)
$3 (Green)
$4 (Red)
$5 (Light blue)
$6 (yellow)
$7 (Pink)
$8 (Orange)
$9 (Grey)
Endret av _Finch_
  • 2 uker senere...
To change the map:
map names are:
assault:
mp_dune
mp_airstrip
mp_dam
mp_mangoriver
mp_jungle
mp_freighter
TDM/FFA
mp_monkeybay
mp_monkeybay_n
mp_surf
mp_radio
mp_cliffside
Game Rule commands:
________________
$0 (Black)
$1 (White)
$2 (Blue)
$3 (Green)
$4 (Red)
$5 (Light blue)
$6 (yellow)
$7 (Pink)
$8 (Orange)
$9 (Grey)
Hva skriver jeg i console for å fjerne "vise FPS i FC"? Jeg skrev " \r_displayinfo 1" og det funket fint. Men neste gang jeg tok inn Far Cry var det der fortsatt...
Hilsen han som ikke har hele roen... :roll:
