Ueland Skrevet 24. april 2004 Rapporter Del Skrevet 24. april 2004 //////////////////////////////////////// // system: VikingBoard // version: 0.1 alpha // author: Tor Henning Ueland // website: www.vikingboard.com // //////////////////////////////////////// //================================ // USER CLASS | PARSES AND GETS THE USER INFORMATION //================================ class user { var $name; var $id; var $auth; var $loggedin; var $title; var $new_pms; var $use_smiley; var $use_sig; var $use_emailer; var $show_sig; var $show_avatars; var $show_smileys; var $warnlevel; var $show_pmpopup; var $done_pmpopup; //Session function, checking the sid function session() { session_start(); if ($_COOKIE[''.global_config('cookie').'']) { $this->session = $_COOKIE[''.global_config('cookie').'']; } else { $this->session = session_id(); } return $this->session; } //session updater function sessupdater($t) { global $db; //The session isn`t there | inserting if ($t =='insert') { $db->db_query("INSERT INTO forum_sessions (sid, time, ip) VALUES ('".$this->session()."', '".forumtime()."', '".$_SERVER['REMOTE_ADDR']."')"); } //Session exists, let`s update it if ($t == 'update') { $db->db_query("UPDATE forum_sessions SET time ='".forumtime()."', ip ='".$_SERVER['REMOTE_ADDR']."' WHERE sid ='".$this->session()."'"); } } //The user data function, parses and gets the info about the user function user() { global $db; //so, now we got enough information to get some info about him/her/dragon/alien, wathever dude. $db->db_query("SELECT s.uid, m.name, m.auth, m.title, m.new_pms, m.use_smiley, m.use_sig, m.use_emailer, m.show_sig, m.show_avatars, m.show_smileys, m.warnlevel, m.show_pmpopup, m.done_pmpopup FROM forum_sessions s, forum_member m WHERE s.sid = '".$this->session()."' AND m.id = s.uid LIMIT 1"); $usr_sess = $db->db_row(); //Data from the logged in user.. if ($usr_sess->uid) { $this->name = $usr_sess->name; $this->id = $usr_sess->uid; $this->auth = $usr_sess->auth; $this->loggedid = "1"; $this->title = $usr_sess->title; $this->new_pms = $usr_sess->new_pms; $this->use_smiley = $usr_sess->use_smiley; $this->use_sig = $usr_sess->use_sig; $this->use_emailer = $usr_sess->use_emailer; $this->show_sig = $usr_sess->show_sig; $this->show_avatars = $usr_sess->show_avatars; $this->show_smileys = $usr_sess->show_smileys; $this->warnlevel = $usr_sess->warnlevel; $this->show_pmpopup = $usr_sess->show_pmpopup; $this->done_pmpopup = $usr_sess->done_pmpopup; } //Default guest data else { $this->name = "test"; $this->id = "0"; $this->auth = "0"; $this->loggedid = "0"; $this->title = "0"; $this->new_pms = "0"; $this->use_smiley = "0"; $this->use_sig = "0"; $this->use_emailer = "0"; $this->show_sig = "0"; $this->show_avatars = "0"; $this->show_smileys = "0"; $this->warnlevel = "0"; $this->show_pmpopup = "0"; $this->done_pmpopup = "0"; } //running a sessions update if ($db->db_rows() =="0") { $this->sessupdater(insert); } else if ($db->db_rows() !="0") { $this->sessupdater(update); } } } Lenke til kommentar
