PHP highligt test
Ueland
<?PHP
// system: VikingBoard
// version: 0.1 alpha
// author: Tor Henning Ueland
// website: www.vikingboard.com
// USER CLASS | PARSES AND GETS THE USER INFORMATION
class user
var $name;
var $id;
var $auth;
var $loggedin;
var $title;
var $new_pms;
var $use_smiley;
var $use_sig;
var $use_emailer;
var $show_sig;
var $show_avatars;
var $show_smileys;
var $warnlevel;
var $show_pmpopup;
var $done_pmpopup;
//Session function, checking the sid
function session()
session_start();
if ($_COOKIE[''.global_config('cookie').''])
$this->session = $_COOKIE[''.global_config('cookie').''];
else
$this->session = session_id();
return $this->session;
//session updater
function sessupdater($t)
global $db;
//The session isn`t there | inserting
if ($t =='insert')
$db->db_query("INSERT INTO forum_sessions (sid, time, ip) VALUES ('".$this->session()."', '".forumtime()."', '".$_SERVER['REMOTE_ADDR']."')");
//Session exists, let`s update it
if ($t == 'update')
$db->db_query("UPDATE forum_sessions SET time ='".forumtime()."', ip ='".$_SERVER['REMOTE_ADDR']."' WHERE sid ='".$this->session()."'");
//The user data function, parses and gets the info about the user
function user()
global $db;
//so, now we got enough information to get some info about him/her/dragon/alien, wathever dude.
$db->db_query("SELECT s.uid, m.name, m.auth, m.title, m.new_pms, m.use_smiley, m.use_sig, m.use_emailer,
m.show_sig, m.show_avatars, m.show_smileys, m.warnlevel, m.show_pmpopup, m.done_pmpopup
FROM forum_sessions s, forum_member m
WHERE s.sid = '".$this->session()."' AND m.id = s.uid LIMIT 1");
$usr_sess = $db->db_row();
//Data from the logged in user..
if ($usr_sess->uid)
$this->name = $usr_sess->name;
$this->id = $usr_sess->uid;
$this->auth = $usr_sess->auth;
$this->loggedid = "1";
$this->title = $usr_sess->title;
$this->new_pms = $usr_sess->new_pms;
$this->use_smiley = $usr_sess->use_smiley;
$this->use_sig = $usr_sess->use_sig;
$this->use_emailer = $usr_sess->use_emailer;
$this->show_sig = $usr_sess->show_sig;
$this->show_avatars = $usr_sess->show_avatars;
$this->show_smileys = $usr_sess->show_smileys;
$this->warnlevel = $usr_sess->warnlevel;
$this->show_pmpopup = $usr_sess->show_pmpopup;
$this->done_pmpopup = $usr_sess->done_pmpopup;
//Default guest data
else
$this->name = "test";
$this->id = "0";
$this->auth = "0";
$this->loggedid = "0";
$this->title = "0";
$this->new_pms = "0";
$this->use_smiley = "0";
$this->use_sig = "0";
$this->use_emailer = "0";
$this->show_sig = "0";
$this->show_avatars = "0";
$this->show_smileys = "0";
$this->warnlevel = "0";
$this->show_pmpopup = "0";
$this->done_pmpopup = "0";
//running a sessions update
if ($db->db_rows() =="0")
$this->sessupdater(insert);
else if ($db->db_rows() !="0")
$this->sessupdater(update);
Gjest
