Avspilling + Opptak -> Samtidig
Noen som vet om dette er mulig med 'vanlige' lydkort i prisklasse under 1000,-?
Jeg tenker å kjøpe et Terratec Sixpack kort, men må liksom vite om jeg har mulighet til å bruke f.eks Logic Audio og den typen programmer. Altså; Record mens jeg spiller av et tidligere innspilt spor.
Det står i spec'en at det støtter full duplex, men dette står riktignok under "Digital Audio"
Det er derfor jeg er litt usikker..fordi det gjelder vel kanskje kun optisk/spdif inn/utgangene.
se selv:
hva tror du?
TerraTec SiXPack 5.1 + - Details
Compatibility:
· DirectSound / 3D
· Sensaura 3D
· A3D 1.0*
· A3D 2.0 compatible
· EAX 1.0, EAX 2.0*
· MacroFX*
· EnvironmentFX*
· MultiDrive*
· ZoomFX* (under development)
· I3DL2*
· General MIDI (GM)
· DLS 1.0
· MPU-401
· SoundBlaster / Pro
· AC’97
· PC 2001
· PCI Specification Rev. 2.1, 2.2
· PCI Bus Power Management Interface Specification 1.0
Digital Audio:
· 8/16-bit playback & recording with up to 48kHz (mono/stereo)
· Extended Full Duplex at playback & recording (mono/stereo)
· Recording and playback of all audio sources
· Sensaura 3D
· MultiDrive
· MacroFX
· EnviromentFX
· ZoomFX (under development)
Wavetable Synthesizer:
· Up to 1024 voices
· High quality 8MB sound-set
· DLS 1.0 compatible
Audio Mixer:
· Individual volume control of all audio sources
· 10-Band stereo equalizer with presets
MIDI/Joystick Interface:
· DirectInput-acceleration
· Analogue / Digital joystick interface
· MPU-401 compatible (UART mode)
· SoundBlaster compatible MIDI interface
External connectors:
· Digital-Out, optical, 48kHz (TOS link)
· Digital-In, optical , 32 kHz, 44,1 kHz, 48 kHz (TOS-Link)
· 3 x Line-Out, stereo (3,5 mm)
· Line-In/Headphone-Out (switchable), stereo (3,5 mm)
· Mic In, mono (3,5mm)
· MIDI/Joystick Interface (IBM 15 pin Sub-D)
Onboard connectors.
· Digital-In, 32, 44.1 and 48kHz
· 2 x CD audio In, stereo (MPC3)
· Aux In, stereo (MPC3)
· Wavetable connector (WaveBlaster pin compatible)
Amplifier.
· Headphone amplifier, 2 x 60mW
___________________________________________
Grunnen til at jeg bruker Logic er vel at jeg ikke vet om noe særlig andre programmer av denne typen..
Når det står Digital Audio mener de nok heller intern håndtering, uavhengig av hvilken inngang/utgang du bruker.
Og, det er ingen grunn til å la være å bruke Logic Audio, men et program i toppklassen burde kanskje ha et passende kort?
Alle lydkort som er noe særlig nyere enn SB16 er full duplex, så det er ikke noe problem... Hvis man får asio-drivere til SB Audigy er det bra til opptak.
Du bør finne ut hva du kommer til å bruke kortet mest til. Skal du gjøre mikrofonopptak ville jeg prioritert skikkelig mikser, kabler og mikrofon fremfor et dyrt avansert lydkort. Skal du ha hi-fi lyd i stuen er lydkortet viktigere.
