brenning av .iso filer i nero
Quote:
On 2002-04-04 12:52, ShizzleDizzle skrev:
når jeg brenner .iso filer under "CD-ROM Mode 1" så virker de ikke, men står det "Joliet" eller "ISO 9660 (bootable)" så funker de greit, altså under "Kind of track" i "write" vinduet. skal man kunne velge dette for det får jeg ikke til...?
>>With Nero Burning Rom:
Open Nero.
Close the wizard if it is started automatically.
Go to "File"
then to "Burn Image...".
In the next dialog, click on "Image Files (*.nrg)" and select "All files
Choose the .iso file and accept.
In the following dialog make sure:
- Type of Image is: Data Mode 1
- Block size: 2048
- Image header: 0
- Image trailer: 0
- All the checkboxes are unactive.
Click "OK".
In the next dialog check that the "write" and "finalize" option are active.
Click on "Write".
tommelomsk
