HJELP! får ikke Asus WL-300G til å funke!
Har nå siste uken testa 2 stk ifra Komplett på en SMC7008ABR,, men jeg får det bare ikke til!
En SMC2804WBR V.2 jeg testa nå funket ifra første tastetrykk!!
Forsøker å finne nye firmware oppdateringer på ASUS, men hvordan er det meningen at GPL source code for firmware version 1.7.5.6 på 166.17 MB skal kunne nyttes til dette?
ref:
http://www.asus.com.tw/support/download/it...delName=WL-300G
Tom har testet den og sa bla følgende:
Port forwarding can be set in in the Port Mapping and Virtual Server pages. But here, ASUS' documentation fails, not providing a good explanation of the difference between the two modes. A single DMZ server can also be set.
Unfortunately, as I tried to run a simple Qcheck test—which requires a number of ports to be opened—I found none of the port forwarding options worked! I also found that no Internet functions worked (by using domain names at least) until I entered my ISP's DNS server IP address into the 300g's DHCP server page. Apparently the 192.168.1.1 default DNS IP handed out wasn't getting my wireless client hooked up with real DNS info.
Once I corrected the DNS IP problem, I was able to access the Internet. But it's clear from the other problems I found, that routing is not the strongest feature of the 300g.
NOTE: Shortly before I posted this review, ASUS sent me 1.6.5.3 BETA firmware to replace the version 1.6.4.7 latest release firmware that I tested with to see if it cured some of the problems I was seeing. I'm happy to report that it cured my port forwarding problem and clarified the Port Mapping / Virtual confusion (Port Mapping is now Port Triggering with an entry for Trigger port). "
ref:
http://www.tomsnetworking.com/Reviews-64-ProdID-WL300G-2.php
Noen tips før jeg blir forbannet?
GPL koden som asus har lagt ut er kildekoden til firmwaren. Det vil si at om du har lyst å endre på den kan du gjøre det der da den kjører linux.
Asus er nødt til å legge det ut pga de bruker åpen kildekode som skal være lovlig å endre. WL-300g har router funksjonalitet, men bare en port, noe som gjør den ganske ubruklig til en router.
Du kan laste ned siste firmwaren, men da den som er på 2-4 MB og ikke over 100 MB. Når jeg testet denne enheten i sommer hadde jeg ingen problemer med port forwarding med en Telenor ADSL linje.
Vår test finner du her: http://www.barbara.no/art.php?artikkelid=954
Siste firmware du kan legge inn kan du laste ned her: http://www.asus.com.tw/support/download/se...00g.zip~zaqwedc
